Page 127 of 127 FirstFirst ... 2777117123124125126127
Results 2,521 to 2,535 of 2535
    Dec 2017
    #2521
    Quote Originally Posted by SRGuy View Post
    Peeps, ano gamit nyo pang linis ng dumi/libag around the gas tank cover? di maalis ng car shampoo...
    Thank you.
    Try using a rubbing compound. That should do the trick.
    #2522
    Thank you.
    toothbrush and/or small version nitong nasa pic para sa singit singit ..
    sakin kasi di na umaabot sa sobrang dumi kaya cotton buds lang ok na
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    May 2007
    #2523
    Takot ako gumamit ng rubbing compound lolz
    May tulong kaya degreaser? paint safe ba degreaser?
    #2524
    you can use dishwashing soap as degreaser
    wag ka matakot sa rubbing compound, sa gumagamit ka matakot lol
    if uncomfortable ka, via hand application mo para di maubos clearcoat
    Jan 2008
    #2525
    Thank you.
    pwede din WD40 with soft brush, just let soak muna para lumambot yung libag...
    #2526
    Thank you.
    try a little car wax/polish like turtle wax.
    Nov 2019
    #2527
    Question lang.
    How to maintain piano black finish?
    Yung side door pillars is piano black finish po kasi.
    Kahit anong ingat, na scratch pa rin.
    Galing na ako sa detailing to remove the scratches nito.
    Paano to tanggalin hairline scratches niya at ano maganda product to protect piano black materials?
    Dec 2017
    #2528
    Quote Originally Posted by carxynogen View Post
    Question lang.
    I just put wax on it. Just lately, I tried using my polisher with the blue pad. The watermarks are all gone. You might want to "remind" your passengers to avoid placing their hands on them when closing the doors.
    Nov 2019
    #2529
    May wax na po, dalawang layers.
    turtle wax ice seal n shine improved formula + collinite as a toper.
    Nagka scratch parin.
    Yung hairline scratch na usually visible sa piano black.
    Yung shiny black na wrap, same lang din ba ng piano black material na madaling ma scratch? Im thinking ipa wrap nalang if visible at malalim na talaga yung scracth niya.
    The scratch I mean is the hairline scratch that you usually see sa piano black finish, not the major scratch.
    Dec 2017
    #2530
    Your wife, or girlfriend, of whoever is your passenger, must have a long, sharp, pointy, fingernails!
    You might want to consider putting this to protect the piano finish.
    You can just cut it. I have intended to put it on the door sill but I've been "lazy" for the last three years that I haven't opened it yet. In fact, I remembered I have that because of this post.
    [emoji3]
    Nov 2019
    #2531
    [emoji3]
    Nice, eto yung hinahanap ko dati but for the door cup.
    Parang applicable din ata to sa part na yun.
    Para kang naginstall ng tint, need to study paano to iapply.
    Thanks for this, I will check and consider.
    Dec 2017
    #2532
    I think it will be too difficult to apply this as a door cup. I suggest buying it separately. Here's the link but you can find a cheaper one to practice on installing it.
    https://shopee.ph/product/21594805/4...8-1620985075.9
    Nov 2019
    #2533
    Need pala to i cut ng maayos para ma install sa pillar.
    Cutting at precise cut is not I am good at.
    Better to leave it to professional nalang, will look near my area kayang mag install with correction.
    Yupp, sa door cup, naghahanap pa ako ng specific product fit sa car ko.
    Nov 2017
    #2534
    Just wrap those piano gloss scratch prone trims
    Mazda 3 Trim Removal and Carbon Fiber Vinyl Install - YouTube
    Jan 2016
    #2535
    Thank you.
    Bareta na sabon, sureball yan bro, pati sa itim ng hood tanggal
    Sent from my Mi A1 using Tsikot Forums mobile app
Detailing Thread [For Newbies][continued 3]
