sir, maraming possibilities yan, either marumi na at hirap na flow kaya may overheating or pdeng sa water pump din or within sa engine na mismo. critical na part yan so better have it checked para ma identify talaga
Originally Posted by n_spinner06
Any of you guys have an idea how long an engine can run without coolant before it overheats? The plastic drain plug of my radiator is broken/leaks and the radiator cannot hold water in longer than 3mins(parang gripo talaga). Sad thing is the plug broke in two such that half of the screw is stuck inside(handle broke off) so i cannot plug the leak...not sure kung aabot pa sa shop mga 20mins away and i dont want to risk overheating the car. Thanks!
Sir, kung ako sa sitwasyon mo ipa-home service ko na lang sasakyan ko kesa ibiyahe ko.. Mahirap isapalaran yan.. Bilis uminit nyan..
