View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 520 of 580 FirstFirst ... 420470510516517518519520521522523524530570 ... LastLast
Results 10,381 to 10,400 of 11582
    #10381
    Quote Originally Posted by abszm View Post
    Toyota Vios 1.3e check engine line always on.
    ask ko lang mga sir.may masamang epekto po ba kung laging naka on ang check engine at abs light ng toyota.
    pasensya na po baguhan lang sa sasakyan.
    Are you near pasig? I can scan it for you if you want. CEL means there's a problem obviously lalo na daw pag blinking CEL.
    Sent from my E5553 using Tapatalk
    Mar 2016
    #10382
    Eto ba yun kuya? Meron sa ace or concorde pr blade?
    Go to ace hardware tomorrow, look for a sachet of rubbing compound, around 40-50pesos, apply some on the scratch, use a microtowel, rub in a circular motion, viola....la na yan, apply a coat of wax after youre done
    Quote Originally Posted by timo07 View Post
    The paint transfer looks very minor. A Formula 1 Scratch Remover will be more than sufficient and will be less harsh on the clear coat than a rubbing compound. Try muna scratch remover bago magrubbing compound. That's what I usually do and 99% of the time eh nawawala naman.
    Dec 2007
    #10383
    Yes, that's the one. Concorde available.
    Jul 2015
    #10384
    Quote Originally Posted by lorgue View Post
    Thats toooo much, you just need a sachet, around 40 pesos.
    Apr 2008
    #10385
    May nakapagpagana na ba ng USB flashdrive na may laman na movies sa touch-screen type na head unit ng mga 2015 and up na models ng Vios and Yaris? I've been trying to get ours to work by using FAT32 as the filesystem, removing directories so that all of the files are in the root directory, but it looks like the HU is not able to detect the drive.
    It also does not have the option to select USB as the source as mentioned in the user's manual even when the USB drive is plugged in.
    I plugged in an iPhone through a USB cable and it was able to detect it as an iPod without any issues.
    Thoughts?
    May 2016
    #10386
    salamat ng marami sa offer mo sir pero malayo ako.d2 ko ilocos.i already try to reset by removing the battery but still bumabalik p rin sya after a few days.
    Dec 2007
    #10387
    Quote Originally Posted by rpacis View Post
    Thoughts?
    It might be that your system can only recognize Audio files through the USB port. Go to your manual and check if your system can really play video files or not.
    Dec 2015
    #10388
    Just try the full tank method, fill up the car(nearest to your place), reset the trip meter , do the usual route, like office, fetch kids, etc etc, then fill her up again at the same gasoline station, chk the receipt how many liters you consumed, if it says 100kms on the trip meter and you consumed 10L thats 10L/100km or 1/10
    ok i'll try this. thanks.
    #10389
    yeah di talaga mawawala yan bro unless ma fix na error, maski reset mo pa thru obd scanner. usually daw sabi sakin mechanic MAF daw ang cause, kaya madalas yung iba na wala scanner eh linis muna MAF, naayos naman.
    Apr 2008
    #10390
    Checked the manual again and indeed, the files should be supported. However, what I noticed is that there are certain formats (even if they are in the MP4 format) that the HU cannot seem to play. If ever it plays, the video just shows static while the audio plays in the background. I suppose you cannot expect a lot from the OEM HU.
    #10391
    May nakapag palit na ba sa inyo ng thermostat?
    Ang tagal nakabukas ng "Cold Engine" netong mga nakaraang araw.
    Nasa magkano kaya yun saka labor?
    Nov 2012
    #10392
    Mga sir san kaya ako makabili ng surplus parts? Nabangga ako sa likod kelangan ko ng driver side tail light. Thanks
    Sent from my Redmi Note 3 using Tsikot Forums mobile app
    Jun 2016
    #10393
    ano po ang tawag sa panel na ito? nid ko po palitan yun sakin. yun kulay black po sa likod ng silver.
    #10394
    Quote Originally Posted by gadtechs View Post
    try the cathay centers in banawe, QC, and evangelista, makati.
    or online like olx.
    Aug 2005
    #10395
    Sa Evangelista bro kung malapit ka doon. Kung di mo madadala sasakyan mo, dala ka ng sample housing kahit broken piece para masiguro mo parehong colour shade ang mabili mo. Mga ibang housing na benta nila faded na.
    Nov 2012
    #10396
    Quote Originally Posted by leinahtan View Post
    May idea ka sir kung magkano?
    Jul 2016
    #10397
    Hi,
    Any recommended vios model? (newbie lang po)
    Misis ko po ang gagamit..
    TIA
    Aug 2005
    #10398
    Quote Originally Posted by aweng View Post
    Hi,
    TIA
    A 1.3 E A/T will be fine for the wifey.
    Sent from Zenfone2
    Jul 2016
    #10399
    Sent from Zenfone2
    Salamat Sir..
    bat kaya walang pumapansin sakit na Toyota agent? pansin kolang..
    from bulacan <<<<
    Aug 2005
    #10400
    Salamat Sir..
    from bulacan <<<<
    Look for another dealer. Don't waste your time on one. If you're not getting their attention, leave. They can have their lousy time, for all you care.
    Sent from Zenfone2
Toyota Vios Owners &amp; Discussions Thread
