View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 465 of 580 FirstFirst ... 365415455461462463464465466467468469475515565 ... LastLast
Results 9,281 to 9,300 of 11582
    Aug 2004
    #9281
    how to enable yung sound ng alarm pag ni-lock/unlock.. naka silent kasi, wala naman ako manual
    2011 vios e a/t
    Aug 2008
    #9282
    There's no way to enable the vios's TVSS lock/unlock sound indicator unlike sa IMV trio (innova, fortuner and hilux). If you really want a sound indicator and shock sensor, may nabibili naman na alarm module.
    Aug 2004
    #9283
    Quote Originally Posted by crave View Post
    naka silent ba talaga ang default mode nun? gusto ko sana na may tunog kapag inilock, need ko pa kasi icheck yung door handle to make sure na naka lock nga..
    thanks for the info..
    #9284
    Quote Originally Posted by Elroi View Post
    wala talaga tunog yun sir...
    Aug 2004
    #9285
    Quote Originally Posted by payaso_loco View Post
    now i know..hehe
    thanks
    #9286
    with our gen1 vios i can enable/disable the sound by pressing both buttons at the same time. is that what you're referring to?
    what it actually does is disable the audible alarm pero active pa rin yong security. bale flashing turn lights na lang gagana pag activate nung alarm.
    Dec 2013
    #9287
    Good Evening po
    pa help naman mga sir.
    i owned a Toyota Vios 1.5G 2010 model, Just a few days i noticed that when i start my engine the radiator fan is not turning ON, but when i turned the A/C on the fan will also turn ON but i a Medium Speed, i not sure i my observations are wrong, but a few days ago the normal is when i start the engine, the fan will also goes ON then when i turn the A/C on the radiator Fan will start to go to High Speed to Medium Speed Interval, Hindi ako sure kung tama ako sir dun, pero kasi ngayon when i start the engine no response lang sya or baka matagal lang tlga sya mag on "im not sure"....pero pag binuksan ko naman yung A/C...umaandar naman yung radiator fan but on a medium speed lang, Guys p help naman, baka naencounter nyu na tong issue na toh, ano ba pwedeng fix nito? plano ko kasi i pacheck bukas so since wala akong ka idea bka lokohin ako or tagain sa presyo, kea ask ko lang ano suggestions nyu.......salamat in advance
    Dec 2013
    #9288
    Good Evening po
    Good Evening po
    #9289
    Quote Originally Posted by viostechtips001 View Post
    Good Evening po
    that seems about normal.
    radiator fan turns on when the engine is hot enough.
    radiator fan turns off or stays off when engine is cool enough (as in during cold starts in the morning).
    radiator fan turns on when the aircon is turned on.
    is there anything else that seems to be wrong with your car?
    Good Evening po
    Dec 2013
    #9290
    dr d.... sir i also noticed na yung coolant ko sa reserve bigla naubos...normal din po ba na bigla nauubos yun....mula kasi sir nung nabili ko yun never ko pa nalagyan or na refill....di naman po kasi ng babawas or bumababa yung coolant sa reverv nya. pero just a few days ago bigla nlng wala na laman...pero i opened the radiator cap... meron nmn po laman...yung sa reserve lang yung wala
    #9291
    ^^^too it up with premix toyota super long life coolant. Pagnaubos, alam mo na na may problema ka sa cooling system
    Jan 2014
    #9292
    Mga sir kamusta! its been awhile hehe ,
    may inquiry lang ulit ako napansin ko lang to lately ,
    yung keyless entry alam ko kasi dati pag nilolock ko may tunog kahit unlock tumutunog din
    ngayon hindi na siya tumutunog kahit i lock/unlock ko wala ng tunog umiilaw nalang tapos naglolock/unlock
    ano kaya problem nun mga sir? saka yung security light diba dapat may 15 to 30 secs interval non para mag blink ulit? yung sakin parang continues at mabilis yung pag blink niya ,
    my ride ; TOYOTA VIOS 1.5G AUTOMATIC 2004 MODEL
    need some help thank you guys!
    #9293
    Quote Originally Posted by KrisVios04AT View Post
    sa pagkakaalam ko may procedure sa manual kung pano iactivate ulit ung sound ng alarm. somewhere in this topic may nag ask na niyan and may nagpost ng procedure. hehehehe, sorry 1.3g lang kasi akin pang 1.5g kasi ung feature na iyun eh.
    Nov 2012
    #9294
    Mga bossing tanong ko lang kung saang shop sa banawe maganda bumili ng Vios Gen 2 accessories like side mirror chrome, visor at side moulding? Kakakuha ko lang ng 2nd hand Gen2 last week balak ko sana pagandahin since stock lahat. Thanks
    Aug 2013
    #9295
    Sino na po nagpa 6ok km pms dito sa casa or labas?
    #9296
    Quote Originally Posted by gadtechs View Post
    newly found auto supply - kay import elementz sa Otyis Branch and meron din sila sa banawe. hihihi.
    back up camera with rearview (LCD) is 2.5k lang sa kanila kasama install.
    backup sensor 1.8k lang sa kanila.
    meron pang mura bandang tandang sora, threebrothers autohub ata pangalan. mura mga promo nila eh.
    Aug 2014
    #9297
    good day mga sir ask lang po nag woworry kasi yung kapatid ko eh 1.3 e 2012 na vios po samin. nakadinig daw po sya ng sound na parang nag lock nung nag brake daw po sya pero isang beses lang daw nya po nadinig. ano po kaya yun sound na parang nag lock daw po? maraming salamat po ingat sa lahat
    #9298
    Quote Originally Posted by abduljhacull View Post
    observe if it recurs.
    from what i know, a brake that locks makes no sound..
    #9299
    Hmm, sakit ata talaga ng gen2 ito, if in case under warranty toyota will repair it free of charge, lalagyan ng shim (un tawag nila eh) ung brake caliper.
    If not, 150petot ata each ang cost of repair. Had mine done at toyota bicutan.
    Had mine last 25k PMS and so far nawala naman.
    Aug 2014
    #9300
    Quote Originally Posted by RomeoAlpha View Post
    ahhh d pla sya normal may kelangan palang gawin cge sir salamat po sa ngayun isang beses palang naman nyang nadinig eh pero papacheck ko na din.. salamat sa pag sagot sir
Toyota Vios Owners & Discussions Thread
