View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 464 of 580 FirstFirst ... 364414454460461462463464465466467468474514564 ... LastLast
Results 9,261 to 9,280 of 11582
    #9261
    Very minimal ang difference ng 185/60 sa 175/65. No real impact on FC and comfort, but you might notice a slight improvement in highway stability.
    For those who've tried riding a Vios G and a Vios E, halos wala namang difference sa ride diba? But the G rides on 185/60 R15 tires while the E as 175/65 R14 tires.
    Jun 2010
    #9262
    i'm curious about the ecopia.. nakaka-save daw ng fuel because of low rolling resistance?
    makapal pa ang center? sounds more like chronic under-inflation than mis-alignment..
    from what i understand, thicker tires might cause you to burn more fuel...
    When I bought the Vios, I was told by the sales guy to use 32 (psi?) sa front and 30 sa rear. Also, on the door sticker, it says 230 kpa front (33Psi according to google) and 210 rear (30Psi). Nagpapahangin ako every Sunday. Is it because kulang ng 1Psi yung front ko? If so, bakit pati rear tires same lang yung issue eh tama naman pressure. Am I doing it wrong?
    #9263
    Quote Originally Posted by Chrisbn View Post
    Nope, you followed the correct tire pressure. Just normal wear and tear for the tires, you cant keep them forever even if you dont use them.
    Jun 2010
    #9264
    Good to know, thanks!
    Binili ko na ang dunlop. Yung bridgestone kasi ng suki kong shop, 2713 yung manufacturing date tapos si Dunlop, 3414. Sabi ng shop, halos magkapareho lang yung 2 brand. And they said I shouldn't consider yung si Goodyear kasi lately daw, maraming panget na batch.
    They checked the alignment, ok naman daw. Baka daw wear and tear lang talaga plus yung sinabi nilang di na rin maganda mga local made ni Goodyear, which was my stock.
    Btw, they said I should just use 30Psi on all tires, would that be ok instead of the 32 front 30 rear?
    Thanks everyone... learned a lot today :D
    Aug 2004
    #9265
    Follow the door sticker so it should be at least 33 front 30 rear.
    Jun 2010
    #9266
    Got it. Thanks a lot.
    #9267
    Got my best FC yet. December 25 to January 6.
    15.35km/L. Mixed. Sarap kapag wala gaanong tao sa NCR.
    #9268
    napuna kurin..
    fuel-miser pala car ko...
    and thanks to the fuel price rollbacks, for the first time in decades... umapaw ang filler tube ko! 950 bucks lang ang nailagay... (1000 kesos ang regular buy ko..) . wigo.
    Dec 2014
    #9269
    Quote Originally Posted by sirkosero View Post
    labor lang. yung oil, oil filters, gasket at miscellaneous, charge pa din sayo.
    kung regular motor oil lang, without the optionals, prepare 1300 petot. sa toyota makati ako nagpaservice nuon
    Ako din medyo malapit na. Buti nga ok naman din ang presyo.
    Anyway would you recommend upgrading yung oil to synthetic or yung isang nire recommend nila na type? Would you have any idea kung magkano?
    Thanks bro!
    #9270
    Quote Originally Posted by senyorjalapeno View Post
    Thanks bro!
    Sorry medyo late response, i suggest mag fully synthetic ka sa 5k kms mo, then maintain mo na until end of life ng sasakyan mo. Para mahati ang gastos. Ako every 5k 2.8k plus minus 20% kung may dagdag na parts na papalitan. at least hindi mabigat na magsabaysabay ung pms. Normally every 10k change oil, in between naman ung ibang pms item.
    #9271
    transferred the ultragauge to the vios.
    Oct 2014
    #9272
    Hello sir, ano po yan ultraguage?
    #9273
    ^sir para ma-access ang ibat ibang sensors ng sasakyan natin. Makikita ang real time data ng ecu ng sasakyan natin.
    Sent from my Nexus 7 using Tapatalk 2
    Oct 2014
    #9274
    Ayos yan sir ah. Mahirap ba magkabit nyan? Hindi naman po ma void warranty ko?
    Sep 2013
    #9275
    Sir, San nyo nakuha yan? How much?
    Feb 2015
    #9276
    gud eve, mi have querries lang po is it still safe to drive pag bumababa ang rpm ng kotse>and mhina hatak sa gas anu po kya prob dun ? many thanks sa mgrreply
    Quote Originally Posted by Myrin Myrin View Post
    Some taxi drivers who went over 200k sa odometer with their vios. Had their fuel pump replaced. Anyways have it checked. Better safe than sorry.
    #9278
    no, it's not safe.
    e, kung tumirik 'yan sa gitna ng busy road? sa NLEX?
    bring it to the talyer po..
    #9279
    Kung nagpalit ka ng baterya, at minsan napapadaan ka sa matubig na kalsada like medyo baha. Tapos one click pa din ang start pero pagkatapos bagsak ang rpm up to 400 or even less, then sasamahan mo pa ng aircon lalong babagsak.
    most likely and most probably oxygen sensor yan. Medyo madugong gastusan yan, replaced my fathers vios last november 1 piece is 7k, set is 14k. Nakadiscount na lang ako sa labor.
    Oct 2009
    #9280
    Maganda pa check mona agad yan baka saan kapa abutin mas mahirap at mahal magpa tow.
Toyota Vios Owners & Discussions Thread
