Page 69 of 73 FirstFirst ... 1959656667686970717273 LastLast
Results 1,361 to 1,380 of 1447
    Dec 2017
    #1361
    many owners' manuals have recommended tire sizes and pressures for the car.
    different car.. different tire size.. different pressure.
    And aside from the Owner's Manual, you usually find the recommendation on the driver's side door jamb.
    #1362
    let me guess...
    nawala ang owner's manual, at na-pintahan ang sticker.
    at iba-ibang size na gulong ang nakakabit!
    apologies to TS.
    Oct 2019
    #1363
    Good day po.. May owners manual po ba kayo ng Toyota Revo diesel po.. Salamat po.. Pwede po ba makahingi? wala po kasing manual nabili ko na 2nd hand. Kung hindi po pwede.. Baka po pwede malaman ang required Engine oil, transmission oil, power steering fluid, at coolant po.. Salamat po..
    Nov 2017
    #1364
    Quote Originally Posted by Ceann Niño View Post
    Mga sir, i wanna ask kung may standard pressure for our tires? Or best practice na tire pressure?
    The owner's manual recommendations changes on which engine and tire/wheel you have
    for 2002 and below:
    Tire Size Front Rear
    185/80R14 Gasoline 26 psi 34 psi
    Diesel 30 psi 34 psi
    195/70R14 Gasoline 26 psi 36 psi
    Diesel 30 psi 36 psi
    195/65R15 30 psi 36 psi
    You may have to adjust tire pressures if you are upsizing or moving to a different load range(e.g. From P to LT tires) even if they are the same load index and speed rating(91S ata for revos ?).
    https://static1.1.sqspcdn.com/static...+inflation.pdf
    Apr 2008
    #1365
    When we still had the Revo, I used to inflate up to 38psi front and rear. Higher inflation means lesser effort to move the car, and the Revo is a very lethargic vehicle. It needed all the help it could get! [emoji23]
    Sent from my SM-G965N using Tapatalk
    Nov 2017
    #1366
    Quote Originally Posted by GTi View Post
    You'll also eek out a bit more km/l that way too although medyo tatagtag ung likod.
    Jun 2017
    #1367
    pwede po mag request/ hinge po pdf. service manual and or owners manual po ng revo gsx 2.0 1rz gas engine po.. my email address po is odraregnivla*gmail.com ..maraming maraming salamat po
    Sep 2019
    #1368
    Mga sir, planning to replace my radiator for 1999 revo GL very soon. Ano po ba need ko e note Pag fill ng coolant/ distilled water? My recommended ratio ba or practice namas maiging sundin?
    #1369
    I usually use the Prestone Pre-mix coolant. No need to add distilled/water.
    Dec 2017
    #1370
    It will be better if you will use a premixed coolant so that you don't have to worry about ratio.
    Drain it and fill it with running water until it is clear. Close the "valve" then fill it up with the premixed coolant for one or two liters then partly open the drain and wait until you have a clear coolant flowing out.
    Close the drain and fill it up fully with the premixed coolant. Don't close the radiator cap and start the car. Wait for about​ five to ten minutes to make sure that any trapped air will escape.
    I hope someone will correct me on this if there's anything wrong.
    Dec 2019
    #1371
    Quote Originally Posted by jasonrey View Post
    mine is from a 1999 year model. not sure if it covers everything for your year model. but, sent it to you just the same.
    Hi sir, nahuli na ako sa biyahe ng revo owners. pwede rin ba ako makahingi ng 2.0 1rz-e sr revo service/repair manual. it will be my second educational car.
    thanks.
    Dec 2019
    #1372
    Quote Originally Posted by gtdni_revo View Post
    sir, owners manual po ng 2004 vx200 pahingi po copy sir, email it to davidgracetim*gmail.com, thank you
    Sent from my F5321 using Tsikot Forums mobile app
    Hi guys, i am just new here. bought a revo and would like to ask a copy of service manual to start with.
    Nov 2017
    #1373
    Quote Originally Posted by johdani View Post
    Owner's Manual(originally uploaded by red_one):
    Toyota Revo Owner's Manual.pdf - Google Drive
    Here's an Electrical wiring diagram of the Vietnamese market Zace which may be similar to 1.8 revos
    Zace (Revo maybe)EWD DR77W (VN).pdf - Google Drive
    Engine Repair Manuals:
    Buku Manual Toyota Kijang 7K-E ( Kijang Kapsul EFI) - Iman Suherman (7K-E)
    https://cardiagn.com/toyota-engine-1...repair-manual/ (1RZ)
    https://cardiagn.com/toyota-engine-2...repair-manual/(2L-II)
    https://www.academia.edu/7407534/Toy..._Repair_Manual (7K)
    https://cardiagn.com/toyota-1c-2c-2c...ir-manual-pdf/ (2C)
    As far as full workshop manuals they are rare (if not non-existent for our specific variant) and the closest thing i found is a mention of one for sale for the toyota condor(SA market na high roof "equivalent" ng revo at for their 2wd(top of the line Condors/taiwan market Zace are available with Full time 4wd) variant that at the very least share the front suspension with the revo according to online part catalogs.
    Dec 2019
    #1374
    Quote Originally Posted by red_one View Post
    Manual sent to your email.
    sir, pwedeng makahingi dunng manual. walang manual na naturnover sa akin. 1rz ang makina. salamat. nagalaw ko kasi tps nya.
    salamat.
    Last edited by johdani; December 16th, 2019 at 08:40 AM. Reason: question was answered. thanks
    Jan 2017
    #1375
    Mga sir pede ba ipa computer diagnosis ang REVO SR 2000 model?
    Thanks.
    Nov 2017
    #1376
    Quote Originally Posted by Chi-SR View Post
    Thanks.
    May diagnostic port ung mga gasoline variants sabi sa mga nabasa ko OBD-1 Daw.
    Eto un pagadjust ng fuel mixture sa mga 1.8 according kay google translate.
    Balasan dari Toyota Kijang Kaskus Community - Part 2 | KASKUS
    may makukuha ka din daw na codes sa OBD1 pag i key-ON mo sya ng naka short un dalawang pins sa diagnostic port kagaya ng ginawa sa pagadjust ng fuel.
    How to Get Toyota Codes OBD1 in Under 1 Minutes
    Jan 2020
    #1377
    Quote Originally Posted by LOLZ View Post
    sir sa pagdiagnos po ba kailangan talagang OBD ang magamit. i have seen sa you tube kasi na nagjujumper sila ng wire. is it applicable? thanks
    Nov 2017
    #1378
    Quote Originally Posted by Habib Colangcag View Post
    Yes sir applicable ung jumper method basta 22 pin ung check connector as below(obd1) and not 16 pin(obd2).Ayun sa 7ke service manual pede din i test un fuel pump operation/spark by jumping other pins
    Nov 2017
    #1379
    edit:double post
    Jan 2017
    #1380
    Mga sir, baka may alam kayo na magandang ATF fluid na compatible for REVO SR - 7K engine.
    Thanks
Toyota Revo Owner's Club Details
