Page 72 of 73 FirstFirst ... 2262686970717273 LastLast
Results 1,421 to 1,440 of 1447
    Nov 2017
    #1421
    Quote Originally Posted by Chi-SR View Post
    Mga sir, planning to replace yung front and rear shocks for RevoSR, KYB yung plano ko ipalit. Question, may mga variants sya and honestly wala ako idea sa difference nung mga variants aside sa price of one variant is higher than the other variant. para sa RevoSR anong type/variant ng shocks ba and dapat or recommended na ilagay. and if meron din kayo marecommend na other brand aside sa KYB na within price range at quality.
    Thanks
    Reading around the gas type(Excel-G/Gas-adjust) mas okay daw pag palaging kargado ung sasakyan pero masmatagtag pag walang laman at mahal kesa ung oil type (kyb premium).
    Jan 2017
    #1422
    Quote Originally Posted by LOLZ View Post
    Salamat sir
    Apr 2021
    #1423
    mga sir baka may marecommend kayo na pwedeng pag pa check up ng transmission for REVO-SR(automatic) south area sana.
    salamat
    Ganito din inquiry ko sir, san sa south area may maayos na talyer.
    Owner of 2000 revo sr m/t gasoline. Ang nangyari kasi sa akin, ayaw na magregister yung speedometer. Kapapalit lang ng cable, pag ginagalaw yung cable, pumipitik naman yung gauge kaso pag kinabit na, stuck na po sa zero. Nung hindi pa pinapalitan yung cable, stuck yung gauge up until i reach speed of 60.
    May mga nahingan na ako ng opinions, sabi nila may papalitan daw sa transmission, kaso ayaw ko ipagalaw yung transmission po neto sa basta bastang talyer lang. May nakaexperience na po ba ng ganitong situation dito?
    Sana may mashare kayong talyer na integrity wise eh maayos. Salamat po in advance.
    Dec 2019
    #1424
    Quote Originally Posted by Dadogisdacat View Post
    Try sa cruiser autoparts sa may sucat near evacom. diyan ako nag pakabit ng speedometer cable ng glx gas m/t ko early last year.
    ganyan din issue ko rin dati lagi naman siyan stuck sa 0 yung speedometer needle, tapos pag nasa SLEX na biglang iilaw ang engine light pag natakbo ng mga 80-100kph. nawala naman yung engine light nung pinalitan. pero medyo bouncy na yung speedometer needle pag umaandar na...
    Apr 2021
    #1425
    Salamat will try sir. Sabi din ng isang pinagtanungan ko, sa rapide, yung gear daw sa may transmission ang pudpod na kaya pag high speed lang daw kumakagat. Plastic lang daw. Sadly wala sila ng part na yun.
    Apr 2021
    #1426
    Di naman nailaw yung engine light ko, yung speedometer lang talaga ang di nagalaw even yung numbers sa mileage din na rin nagalaw. Pinagtataka ko lang is after mapalitan ng cable maski high speed di na rin nagalaw.
    Sana may parts sila. Puntahan ko yung sinabi niyo. Was thinking sa kasa na kasi baka wala din sila parts na na kailangan kaso mahal dun for sure
    Nov 2017
    #1427
    Walang stock atm pero may listing sa lazada nun speedogear baka magkaron ulit ng stocks
    Toyota Revo 1.8 7KE,FX 7K Speedometer Gear 33482-2945 | Lazada PH
    Jan 2017
    #1428
    Mga sirs, ok lang ba gumamit ng Toyota ATF T-IV para sa REVO SR? Dexron III (Toyata ATF T-III) kasi ang nakalagay sa manual. Baka may recommended din na magandang replacement brand ng ATF.
    salamat
    Jun 2005
    #1429
    Pwede naman. Afaik T-IV is dex3 equivalent.
    Or bili ka na lang dex3 talaga. Mas mura pa sa autosupply.
    salamat
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    Jan 2008
    #1430
    stick to what is the original requirement.. mahirap pag palit palitin lalo na yan ATF ng transmission..
    Nov 2017
    #1431
    salamat
    Reading around.... maybe
    People seem to have no problem using T-IV in vehicles calling for Dexron II/III but not viceversa (shuddering problems) however there were TSBs from toyota that state T-IV as incompatible with vehicles specced to use toyota D-II or Dexron II/III
    https://toyota-club.net/files/2005/tsb_atf-2004.pdf
    Mar 2021
    #1432
    salamat
    Daming ATF dexron III available.
    Castrol transmax multivehicle atf gamit ko through the years kasi madali hanapin.
    Jan 2017
    #1433
    Mga sirs, worth it ba to use a Iridium Spark plug? in terms of gains specially for an old vehicle for its price? What about the platinum type (NGK)?
    thank you.
    May 2018
    #1434
    thank you.
    Wala akong napapansing significant gain sa stock engine pag gumamit ng new technology spark plugs. At hindi naman ako nagmo-modify ng makina, kaya sinusunod ko lang factory specs.
    #1435
    thank you.
    i believe the gains, is in the long life of the sparking plugs.
    but only if one picks the right model plug.
    Apr 2012
    #1436
    Kumusta na mga Revo niyo? I miss ours. We sold ours back in 2012.
    Nakikita ko pa din siya, pero parang napabayaan yung paint na. Medyo kupas na kulay.
    Not sure if it's ideal to buy it from the current owner if ever ibenta nila.
    It's our first vehicle
    Sent from my SM-A507FN using Tapatalk
    #1437
    ganyan din ako when i sold our sentra to a friend.
    i also wanted to buy it back.
    but we should learn to let things go...
    get newer car.
    Aug 2017
    #1438
    Good day guys,
    Hingi po ako tulong, ang aking auto tranny parang naghhunting between 2-3 gear, parang nangangabayo. Hnd ito ramdam sa una or pgkamalamig pa, pero kpg matagal na byahe say mga 30 mins na mararamdaman na siya. Any troubleshooting tips or any ideas kung ano problem will be very appreciated.
    Maraming salamat mga ka-TROC.
    Sent from my SM-G985F using Tsikot Forums mobile app
    #1439
    Quote Originally Posted by gtdni_revo View Post
    Good day guys,
    Sir, have you tried the basics like changing the ATF and cleaning the strainer/filter?
    Aug 2017
    #1440
    Quote Originally Posted by jvnj View Post
    Good day sir jvnj,
    Thanks for the reply
    YES, ATF and filter (OEM part) already changed. But still the same.
    Any more suggestions sir?
Toyota Revo Owner's Club Details
