Page 68 of 73 FirstFirst ... 1858646566676869707172 ... LastLast
Results 1,341 to 1,360 of 1447
    Sep 2019
    #1341
    Quote Originally Posted by GTi View Post
    Wala bang decal sa likod? Like DLX, GL, GLX, SR and so on.
    Sent from my SM-G965N using Tapatalk
    Cenxa talaga sir, wala kc decals. Ito pic niya
    Ano kaya variant nito? ang ano engine? and power/displacement? sorry sa term
    Apr 2008
    #1342
    Quote Originally Posted by Ceann Niņo View Post
    Mukhang GLX. Eto ba yung may wiper sa likod at power windows?
    Apr 2014
    #1343
    Hello po mga sir. New owner of 1999 revo here, and new to cars actually. How do i know po anong name ng model/variant ng revo ko? Newbie talaga and wanna learn anything here. Big thanks.
    What does the orcr say?
    Sep 2019
    #1344
    Wala wiper sa likod sir. Pawis windows pa
    Sep 2019
    #1345
    Quote Originally Posted by chronicle View Post
    The OR says 2L engine, 1900 displacement pala. Thanks.
    Question sir, normal lang ba na parang sobrang init ng hood kahit mga 15 mins drive lang?
    Apr 2008
    #1346
    Ah, GL.
    Kung 2L engine, diesel yun na 2446cc displacement same as ours. Perhaps the 1900 you are pertaining to is the weight?
    Di naman gaanong nagiging basehan yung pagkainit ng hood, lalo na kung mainit din naman ang panahon. Ang tanong, tumataas ba ang temp gauge from the typical 40% mark?
    Sep 2019
    #1347
    [QUOTE=GTi;3111087]Ah, GL. Kung 2L engine, diesel yun na 2446cc displacement same as ours. Perhaps the 1900 you are pertaining to is the weight?
    Thanks sir! Yung 1900 is piston displacement as per OR.
    Monitor ko na muna sir if lumagpas ng 40%. If normally sir more than 40% na, my problem na ba?
    Apr 2014
    #1348
    #1349
    I didn't see this. I always thought our diesel revo was a 2.0 diesel. Haha.
    Reason for this misinformation, when we checked the or/cr later in life of the car, we found the LTO incorrectly put in the fuel type as gas... We have to go to lto east to have it corrected... What i didnt know was even the displacement was wrong in the lto records.
    Edit : no longer own the car. Ü
    Sep 2019
    #1350
    Baka mali nkalagay sa OR ko sir sa displacement. Big thanks sa info. Marami pa ako questions soon mga sir ha.
    Apr 2008
    #1351
    [QUOTE=Ceann Niņo;3111089]
    Diesel yung sayo no? If so, there is only one engine option and that is the 2.4L 2L. It is not uncommon for the OR to have erroneous vehicle data. I remember that we used to have a 2004 Accord 3.0V6 with an OR indicating 2.0L displacement and 4 cylinders. [emoji23]
    Typically, ayaw kong makitang umabot ng kalahati, since that usually means there is a problem. Depende na kung gaano sya kabilis umangat from there para malaman kung gaano ka lala ang problem.
    Sep 2019
    #1352
    Sent from my BLL-L22 using Tapatalk[/QUOTE]
    [QUOTE=GTi;3111095]
    I think so too sir error is with the OR. Observe ko muna sir behavior ng temp gauge. Thanks a lot.
    Apr 2008
    #1353
    Since you just got the car, and it is a 20 year old vehicle, I would suggest you have the radiator overhauled (pull down and thoroughly cleaned), especially if you suspect there to be an overheating problem. Check for any water or oil leaks from the hoses and seals. Make sure all consumables like fluids, filters and belts are still viable. If uncertain, replace them. And then start a service record to take note of all maintenance services done on the car. This will save you the ultimate hassle of having to call the towing service should the car break down in the middle of nowhere.
    In my experience since this car has no computer box, walang limp mode, power cutoff at di nawawalan ng aircon kapag nagooverheat. So yung temp gauge lang ang indication hanggang sa makakakita ka na ng usok galing sa makina.
    #1354
    personally, i find that temp gauge, more informative.
    Sep 2019
    #1355
    Will note your suggestions sir. Salamat sa advise.
    Jan 2017
    #1356
    Mga sir asked ko lang, any idea kung magkano ang average cost ng cleaning ng aircon?
    Thanks
    Nov 2017
    #1357
    You can also use the model codes listed in the chart and the model plate to verify what model trim your revo is/was
    e.g LF80L-GRMNSM 1998-2002 GLX MT
    LF82L-GRMNSM 2003-2005 GLX MT
    Sep 2019
    #1358
    Quote Originally Posted by LOLZ View Post
    Thank u sir. I just compared the info on the plate with the chart. Mine is LF80L-GRMDSM. Sir GTi was right, GL xa as per the chart
    Sep 2019
    #1359
    Mga sir, i wanna ask kung may standard pressure for our tires? Or best practice na tire pressure?
    #1360
    many owners' manuals have recommended tire sizes and pressures for the car.
    different car.. different tire size.. different pressure.
Toyota Revo Owner's Club Details
