Results 1,041 to 1,050 of 1447
- Apr 2008
- 6,235
October 14th, 2016 09:41 PM #1041
- Sep 2010
- 36
October 26th, 2016 08:28 AM #1042I have a revo DLX 2002 model. It's my first car bought brand new. Ok pa ang kaha, pero mausok tambutso. Sabi ng mechanic iPa compression test ko. Suspects a Nya need top over haul. Saan Pwede mag pa compression test dito Sa cavite/ las pinas area. Saan in Pwede mag pa top overhaul na reliable shop. How much ang magagastos? Thanks po Sa mga sasagot
October 26th, 2016 01:57 PM #1043
Good pm tsikoteers. Anyone here have owners manual ng toyota revo diesel?
Sent from my SM-J200GU using Tsikot Forums mobile app
October 26th, 2016 02:44 PM #1044
- Apr 2011
- 198
October 31st, 2016 09:06 PM #1045during my journey napansin ko mataas ang level ng preno ko pero kumakagat naman.hydrovac na po kaya ito.may remedy pa po kaya? bago ako magpalit ng hyrovac.ano pong magandang brand at nasa magkano.
sa clutch ko naman.nag iba ang setting sa normal mataas na naman.e ka aadjust ko lang sa may ilalim ng driver side.kung adjust ko ulit baka mahugot na ung rod.pa comment po
Maraming pong salamat
- Nov 2008
- 641
November 2nd, 2016 05:22 PM #1046When you say mataas and level, matigas ba syang apakan? If not, baka naman kelangan lang ng adjustments. Kung tumitigas na apakan, yun malamang ang Hydrovac. Check nyo din yung connecting hoses baka may leak na.
Yung sa clutch, pwede nyo naman masilip kung malapit na sya mahugot, kung may clearance pa (exposed thread pa), then pwede mo pa i adjust. Kung paiba-iba na yung level nya, maaring may malapit nang bumigay, either yung master or secondary ang kelangan nyo nang palitan. Just in case, don't go for those repair kits, experience ko di din gaano tumatagal, mas maganda yung assembly na, kahit yung japan made OK na.
- Apr 2011
- 198
November 3rd, 2016 06:30 PM #1047
- Nov 2016
- 3
November 4th, 2016 03:15 PM #1048hello, mga sir ask ko lang anong ngyari sa aircon ko bihira ko lang kasi gamitin sasakyan ko revo minsan sa 1 weeks isang beses lang or dalawang beses 2001 GAS so ngayon nawala ung aircon niya hindi na siya malamig dinala ko sa aircon repair sabe compressor daw pwede pa kaya maayos un?
ANY TIPS: salamat...
- 54,247
November 4th, 2016 11:12 PM #1049yes and no.
a while back, a popular compressor brand was advertising that they can fix their leaking compressors. but they added that the fix may not last "long". sabi ko sa sarili, "just long enough to sell the car. heh heh."
aside from the compressor, other sources of leak include the tubings and everything else. these can be fixed thru replacement. others say they can be welded, but it needs special welding materiel and skill.
when replacing, the replacement parts can be either oem (expensive!) or replacement cheapies. "it's up to you."
good luck, po.
November 5th, 2016 12:39 PM #1050
Guys. Sino po meron owners manual ng revo diesel. Tia.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
