Page 107 of 145 FirstFirst ... 75797103104105106107108109110111117 ... LastLast
Results 1,061 to 1,070 of 1441
    Aug 2011
    #1061
    the cigarette lighter plug-in? i used to have one. ok siya to monitor charging system integrity.
    Check out this product I found:
    VST VST-76 3-in-1 Car Thermometer / Voltmeter / USB Charger | Lazada PH
    Eto po.
    Sent from my SM-J200GU using Tsikot Forums mobile app
    #1062
    Quote Originally Posted by jncp9886 View Post
    VST VST-7�6 3-in-1 Car Thermometer / Voltmeter / USB Charger | Lazada PH
    Eto po.
    that's not what i once had.
    but someone here did mention that one. it's somewhere here.. "what's the last thing you bought" thread, yata...
    Aug 2011
    #1063
    Btw planning to change my stock 195/65r15 tires. Ano po ba pwede max size ng gulong for a r15 rim
    Aug 2011
    #1064
    Ok will look into it. Tnx
    May 2009
    #1065
    Good am guys. Anyone here installed car voltmeter on revo? And also a dashcam? May nakita ako sa lazada but interested in getting inputs muna sa mga naka bili na. Tnx
    ang ginawa kong setup :
    1. bumili ako ng voltmeter (as in voltmeter lang talaga. wala nang extra usb port). nabili ko sa deeco about P150 lang ata. tapos tinap ko sa ignition switch ACC circuit. tapos nilagyan ko ng double sided tape at idinikit sa lower part ng dashboard. kung straight ahead kita ko yung voltmeter sa space sa pagitan ng spokes ng steering wheel. no need na igalaw pa ang ulo para makita ang reading while driving.
    2. bumili din ako ng type s brand na charging circuit splitter worth P500 sa handyman. mayron itong 2 usb port at 2 cig plug style port. tapos nakasaksak sa oem cigarette lighter outlet syempre dahil ayoko munang magtap sa fusebox. mayron din itong 3M na double sided tape kaya dinikit ko na lang sa plastic cover ng kambyo
    dito na sa splitter nakasaksak all the time yung dash cam ko atsaka yung mga gadgets. dito ko rin ilalagay yung binabalak kong bilhin na diy tpms sa lazada.
    Aug 2011
    May 2009
    #1067
    puntahan nyo na lang po yung thread ng dashcams.....
    Sep 2005
    #1068
    Hello mga kapatid,
    I am looking for a service manual ng Revo GLX 1.8 Gasoline Manual Tranny baka meron kayo dyan naitatabi. Thanks.
    Aug 2012
    #1069
    Plug-in type na voltmeter lang gamit ko. But you can also use yung dash type that you can tap sa ACC.
    3-in-1 Voltmeter Thermometer USB Charger
    4-in-1 Voltmeter Clock Calendar Thermometer
    Sent from my D5833 using Tapatalk
    Aug 2011
    #1070
    Ok kaya ito?
Toyota Revo Owner's Club Details
