Results 611 to 620 of 1447
- Apr 2008
- 6,235
May 13th, 2014 01:10 AM #611Hi there! We have a 2001 Revo GLX diesel. I use 205/70/R14 (195/70/R14 stock size) GT Radial Classiro tires inflated to 38psi on all corners. I find this tire pressure great for heavy payload, and that it decreases the sluggishness of the car. With this tire size, I notice that the speedometer reading is almost the same as indicated by GPS. Also, the odometer moves in conjunction with the speedometer, so I believe my mileage is accurate. Perhaps you can try testing your speedometer reading alongside a GPS unit to gauge its accuracy.
I don't mind having upsized tires, as long as it is within reasonable limits. They give the benefit of improved ride quality, handling and a slightly higher ride height.
Sent from my GT-I9100 using Tapatalk 2
- Aug 2012
- 2,767
May 14th, 2014 09:24 PM #612*johnrichard07: recommended upsizing is maximum +/- 2% difference in circumference. for 14" rims, stock tire is 195/70R14..
changing to 27/8.5R14 results in +8.8% difference in circumference (already too large)..
- when speedometer reads 100 kph, you are actually travelling at 108.8 kph
- when trip meter reads 1000 km, you actually traveled 1088.0 km
in comparison, changing to 205/70R14 results in +2.2% difference in circumference (so still acceptable)..
- when speedometer reads 100 kph, you are actually travelling at 102.2 kph
- when trip meter reads 1000 km, you actually traveled 1022.0 km
by the way, are you using your Revo off-road hence the A/T (All Terrain) tires??
with regards to tire pressure, there is max PSI rating marked on the tire sidewall. you can fill air between the recommended value in owner's manual and the max value marked on the tire, depending on your load.
- Apr 2008
- 6,235
May 16th, 2014 08:35 PM #613Hi bro! Do you use stock tires? What's the actual speed when the speedometer reading is at 100km/h? When I was driving a 2012 Isuzu IPV with my GPS, I noticed it's speedometer was reading around 5km/h more than the actual speed when registering at 100km/h.
- Aug 2012
- 2,767
May 16th, 2014 10:45 PM #614i recently changed tires from stock 195/65R15 to 205/65R15. now i have to account to +2.0% difference in circumference.
anyways, the speedometer, odometer and trip meters are factory calibrated to the stock rims/tires. if you are using stock, then whatever is displayed should be accurate data.
with regards to GPS, you also have to consider GPS error and inaccuracy unless you have a military-grade GPS device.
- 54,254
May 17th, 2014 09:30 AM #615
- Aug 2012
- 2,767
June 19th, 2014 08:47 PM #616to fellow Revo owners with 1RZ-E engine, confirm ko lang yung connection point ng NEGATIVE terminal for JUMP STARTING. based on the Owner's Manual, tama ba yung part na nilagyan ko ng arrow?
- 54,254
June 21st, 2014 01:42 AM #617i don't have a revo. but i always connect the clips to the battery terminals. i find it less messy.
- Aug 2012
- 2,767
June 21st, 2014 08:41 AM #618
- Apr 2008
- 6,235
June 23rd, 2014 12:08 AM #619Had the Revo serviced... Again. It's been having overheating problems lately. Have changed the radiator cap and hoses, thermoswitch and thermostat valve and performed radiator overhaul to no avail. At the end I had to replace the head gasket, valve cover gasket and an oil seal. Apparently oil and water have been mixing already. All this at a young age of 110tkms!
After fixing though, I've noticed a slight improvement in performance, and a significant improvement in gas mileage from ~7.5km/L city to 8.8km/L in my latest full tank.
- 54,254
June 23rd, 2014 08:58 AM #620
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
