Page 62 of 73 FirstFirst ... 125258596061626364656672 ... LastLast
Results 1,221 to 1,240 of 1447
    Aug 2016
    #1221
    Quote Originally Posted by mmv12 View Post
    just sharing. i inquired with toyota bicutan re atf for our toyota revo glx 2000. they recommend the type 4. but as per owners manual, we should be using the dexron III. but according to them, they don't have that one anymore. so they're using the type 4. the attached photo was sent to us a day ago.
    there are still dexron III available in the market. I got mine at Petron.
    Jul 2012
    #1222
    Quote Originally Posted by gorz_j View Post
    Yeap, thats what i think also. So do i nees to use that or the type 4?
    Sent from my SM-N910U using Tsikot Forums mobile app
    Aug 2012
    #1223
    Type T-IV ginamit namin in 2012. So mag 6 years na ang Type T-IV sa Revo. It is compatible with Dexron III.
    Toyota ATF WS ang hindi compatible sa Type T-IV and Dexron III.
    Sent from my ASUS_X00DDA using Tapatalk
    Jul 2011
    #1224
    guys,
    hingi ako ng advice regarding sa revo diesel engine.
    recently nasira na yun diesel engine nabutas yun engine block.
    now nag hahanap ako ng pampalit sa blumentritt. kaso puro may efi turbo yun available.
    is it ok to install 2L engine with efi turbo sa revo?
    Feb 2018
    #1225
    Quote Originally Posted by red_one View Post
    What is your email address? I have scan copy of owners manual.
    You can use any Dexron III ATF from local stores or gas stations. If sa casa naman, you can buy Toyota ATF Type T-IV. P450 per 1 liter. You need 2.4 liters.
    Other things na pwede palitan if overdue na: air filter, fuel filter, spark plugs, engine oil, oil filter, differential gear oil. Check PMS in owners manual.
    Sent from my D5833 using Tapatalk
    Good nagbabasa lang po ng mga trends.
    Gusto ko lang itanong kung nasaan ba yung fuel filter ng Revo SR 1RZE engine? Second hand lang yung sa akin at 7 years ko nang gamit. Hindi ko rin alam kung okay pa ang fuel filter, athough regular ang palit ko ng spark plugs & other oils. Yung air filter nya ay washable at wala naman akong nakikitang sira sa kanya.
    Dec 2009
    #1226
    just sharing. i inquired with toyota bicutan re atf for our toyota revo glx 2000. they recommend the typeIV. but as per owners manual, we should be using the dexron III. but according to them, they don't have that one anymore. so they're using the typeIV. the attached photo was sent to us a day ago.
    DexronIII is the minimum requirement..typeIV is the better replacement because dexronIII is an old formulation
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jul 2011
    #1227
    Quote Originally Posted by alx View Post
    guys,
    need help. pa share naman sa mga nakapag palit na ng engine.
    thanks
    Apr 2008
    #1228
    guys,
    Haven't done this personally though I don't see why not. I remember seeing Revo's for sale through the years at the former Sulit.com with 2L-TE's. There was even one with a 4D56 TDIC, and another with a 1KZ even. Engine swaps are kinda hit and miss though. Some may not be in good condition.
    Sent from my SM-G900I using Tapatalk
    Jul 2011
    #1229
    sir GTI
    thanks for the reply.
    ang hirap mag decide kasi medyo mahal din makina.
    non turbo cost around 75k
    w/ turbo is 85k
    sabi kasi wag daw with efi turbo kasi this is controlled by a computer box. some say ok lang kasi na convert naman na ang fuel injector to mechanical type.
    reason why i ask if ok ang turbo. kasi puro may turbo binebenta sa blumentritt. mas malakas daw at tipid sa consumo..
    how will i be able to check the engine to determine if ok pa or not?
    Apr 2008
    #1230
    sir GTI
    w/ turbo is 85k
    Ang kupad ng 2L. If I were you, I'd definitely get the turbo para upgrade na rin. I forgot whether it was the 2L-T (better option kung ayaw ng EFI) or 2L-TE that has turbo (overboost ata?) problems, though there are many forums where you can read about it. I'm not a mechanic but AFAIK you can start up the engine and then check for blowby (my friend's Surf had that) and turbo problems (that too).
    Jul 2011
    #1231
    how will i know if 2L-T?
    i saw one that is not efi turbo.
    ang nakasulat is d turbo ceramics.
    tho, 2L sya. pero parang iba ang porma ng engine compare to my revo orig. how do i post picture ba?
    Apr 2008
    #1232
    AFAIK yan na nga ang 2L-T, and then pag 2L-TE "EFI diesel turbo". Pero makita mo rin naman na wala syang kasamang computer box kapag 2L-T lang. Same cam cover as the 2L, may turbo lang na dagdag.
    Halata ko lang although pareho yung basic na tunog ng 2L sa 2L-T, ang laki ng hinina ng volume ng 2L-T pagkumpara sa 2L ng Revo na parang laging may matinding engine knock kahit maayos naman talaga ang makina.
    Best if you bring a trusted mechanic who has experience with engine swaps to check out the engine before making any purchases para hindi sayang ang pera.
    Aug 2012
    #1233
    Quote Originally Posted by gary2367. View Post
    What is your e-mail address? I can send you the photo.
    Feb 2018
    #1234
    same question din po, vx200 nman sa akin. sabi sa manual every 2 years ang palit. s.diony*yahoo. com my email add, if you can send it to me the photo it will be a big thanks.
    Aug 2012
    #1235
    Quote Originally Posted by Archangelx View Post
    Photo sent in email.
    Feb 2018
    #1236
    thank you sir sa photo location ng fuel filter. nacheck ko narin kahapon, mahirap plang i DIY masikip yung pwesto nya kailangang ilift tlga ung sasakyan. Salamat ulit
    Nov 2014
    #1237
    Mga sir alam niyo po ba saan yun location ng flasher relay ng Revo SR. Thanks
    Mar 2018
    #1238
    did you have to bring down the evaporator?
    Good day
    May nakaexperience na sa inyo na mahina ang a/c pag idling lang (below 1000rpm) pero malamig pag umandar na or pag above 1200rpm na?
    Ano possible cause? Unit is VX200
    Thank you
    Apr 2018
    #1239
    Good day mga ka TROC
    I own a 99 Revo GL diesel binigay sa’kin ng father ko when they move to a different country. Napansin ko kasi medyo matigas yung gas pedal nya kaya hirap humatak, so I’ve search on google and youtube for some possible cause and DIY repair. Most ng nakita ko is about dirty throttle body and also suggestion to lube the throttle cable.
    Naalala ko nung magpalit ako ng compressor nabanggit ko yun sa mekaniko and he did the same thing he lubed the throttle cable pero after almost a year eto bumalik ulit pero hindi kasing lala gaya ng dati. So ngayon nung bumalik ni-lube ko ulit yung cable and also check the air intake nakita ko may dalawang malaking punit yung intake hose(tinakpan ko muna ng duct tape for temp solution) I’m planning to buy a rtv sealant today to fix it kung wala akonh mahanap na replacement part.
    Then tinignan ko din yung kabilang dulo(sorry hindi ako ganun karunong sa engine parts and terms hahaha) ang kapal nung dumi (boxed on 2nd pic) it’s all grimed up.
    So long story short po, any suggestion about my concern, how to clean that part, what to use when cleaning it(materials and solvent cleaners), and do i have to take that metal part out when i clean it? Thank you po in advance.
    Sep 2010
    #1240
    hi red_one,
    can you please send me a copy of the revo owner's manual? we just recently acquired a 2002 SR A/T and no manual came w/ it. thanks!
    ponp717*yahoo.com
Toyota Revo Owner's Club Details
