Page 719 of 775 FirstFirst ... 619669709715716717718719720721722723729769 ... LastLast
Results 14,361 to 14,380 of 15487
    #14361
    Quote Originally Posted by Sleepcare View Post
    Brand new car doc.
    Actually dapat nga ganyan sana. First time ko lang naka-acquire ng brand new tapos may kabig paglabas palang ng showroom
    send it back to them.
    talk to the higher boss, complain to toyota ph., etc. etc, etc.
    hindi dapat pinapakawalan yang kotse kapag ganyan.
    Aug 2009
    #14362
    Actually i've already sent a formal letter to them but ang mali ko is hindi ko napa-receive yung document sa Customer Relations. Ayaw ko na din ibalik sakanila for that problem yung car. I'll bring my business somewhere nalang in high hopes na maayos.
    #14363
    well,
    good luck, po.
    i hope you don't have to replace anything big-bucks.
    marami naman diyang magalinig mag-align.
    Jun 2013
    #14364
    Brand new car doc.
    sakin ganon sir straight from casa, pag release binalik ko agad kinabukasan ng umaga tapos hapon na release ulit
    Aug 2009
    #14365
    Quote Originally Posted by Erick Chavez View Post
    Naayos lang ba yung problem boss? If you would mind, sino yung selling dealer mo? Baka pareho pala tayo
    Feb 2005
    #14366
    In my case, everytime a new car was released form the showroom, i always brought it to my suking shop for alignmemt, camber correction, wheel balance, tire pressure check the next day.
    Most likely, sablay talaga pag galing sa casa
    Jun 2013
    #14367
    Toyota Bicutan Sir, naayos naman sa Casa kaso bumalik din pero matagal naman after a year yata... sa JiGa ko nalang dinala so far oks naman na....
    saka pala sobrang tigas ng gulong nung pagkalabas sa casa nasa 47 yata yon :D
    #14368
    in fairness to toyota,
    never have i experienced such unsavory experience from them.
    just lucky, i guess?
    #14369
    well, if the mis-alignment recurred after a year
    it's probably not toyota's fault anymore.
    more likely, "wear and tear" or aggressive driving practices.
    some writers recommend regular alignment check... every year... every 2-3 years...
    hyperinflated tire?
    my personal suspicion is, it was intentional. they probably reasoned, that the car would be staying in the company bodega for some time, and by hyperinflating it, some of the air would have leaked out by the time the car is sold...
    Jun 2005
    #14370
    Yup mataas ang psi ng gulong kotse pagdeliver from toyota. Sometimes nasa 50psi. Para maganda ang tayo pag deliver sayo. Then adjust mo na lang after.
    Lahat ng binili ko na brand new sobra tigas ng gulong. Binababa ko agad to 32 psi as soon as i-turnover sakin ang susi. :D
    Sent from my MI MAX 2 using Tapatalk
    Feb 2005
    #14371
    Driver side rear and passenger side front shocks are busted.
    This will be my second claim for the shocks [emoji854]
    #14372
    maybe the dealers are under instructions to keep installing 'em defective shocks, to replace the same initially-installed defective shocks, until they are used up.
    only then will they start using the "better model shocks"...
    hindi ba,
    the replacement items' warranties are only up to the original parts' warranties?
    Feb 2005
    #14373
    I think so. 3 years pa din
    Nov 2019
    #14374
    Im also wondering if masyado bang lubak-lubak ang dadaanan mo everyday with your Innova.
    Feb 2005
    #14375
    Typical MM roads amd expressways, so I don't know if that can be considered extreme "lubak".
    #14376
    sometimes,
    it's not the lubaks.
    it's the way one drives over the lubaks.
    Dec 2019
    #14377
    Or if you live specially on the places where roads are totally lubak na lubak.
    Sent from my SM-N970F using Tsikot Forums mobile app
    Feb 2019
    #14378
    I finally got my innova after 3 months of fixing at shop for the damage rear door. I noticed the power steering fluid level is below level and when I drive it again for the 1st time after 3 months the steering wheel felt a bit stiff. What should I do? It was okay 3 months ago when I have it repaired. Thank you.
    Jan 2009
    #14379
    How stiff is "stiff"?
    I was driving a sedan before switching to an Innova and the first time I drove it, the steering wheel felt comparatively stiffer than the sedan... with obviously good reason. But after a while of driving it, I've grown accustomed to it.
    Just saying that maybe you've been driving a different vehicle while your Innova was in the shop and you've just grown accustomed to it.
    But to be thorough, refill the PSF and check for leaks. Also check the tire pressure.... low tire pressure makes for a harder steering.
    Feb 2019
    #14380
    Yes I was indeed driving a sedan and I check also the tire pressure it was okay for 3 months of not using it all 4 tires 30psi and I just add 3psi making it 33psi. I will try to add PSF to make it to the desired level. But normally if the vehicle is not use for that long will it not make steering wheel stiff and does it need to drain the PSF and refill a new one? I will check again probably also I was driving a sedan and now shift back to Innova and steering wheel felt a stiffer compared to sedan.
Toyota Innova Owners & Discussions [continued 3]
