Anyone here tried to install cruise control on 2017 up innova?
Sent from my ELE-L29 using Tsikot Forums mobile app
While i was driving earlier I noticed when my hands aren't in the steering wheel, the steering wheel would wiggle a bit left and right in quick sequence is this normal?
Has anyone tried using this air filter brand or JGC replacement brand? Is quality good? Saw the item on shopee and they are relatively cheap compared to oem or fleetmax.
I gas up last night and my fc is at 6.6km/li city driving 40-60km/hr on average. I need to replaced the air filter and see if my fc improves. Aside from JS Asakashi any recommended replacement brand?
Wix is pretty good. OEM quality at a lower price. Fleetmax I've tried before and it is a little more restrictive vs OEM.
If you are using 40 wt oil you could also try switching to 30 wt if the manual allows it. Might bump your fuel mileage a bit more.
How much is the oem air filter around Php1200? I have seen both wix and fleetmax in Shopee selling for Php700-800 and other replacement brand JS Asakashi Filterpro, JGC selling much lower for around Php400-500. What do u mean by more restrictive? I have been using 15W-40 ever since and this is D4-D I also plan to switch to 30 before but I still stick with 40 probably if my engine is gasoline I can switch to 30.
the engine cover used to be standard issue in the previous gen innova.
as was the nice ashtray, in the first offerings...
the times.. the times..
