Results 14,371 to 14,380 of 15330
July 17th, 2020 12:08 PM #14371
Driver side rear and passenger side front shocks are busted.
This will be my second claim for the shocks [emoji854]
- 52,732
July 17th, 2020 12:11 PM #14372maybe the dealers are under instructions to keep installing 'em defective shocks, to replace the same initially-installed defective shocks, until they are used up.
only then will they start using the "better model shocks"...
hindi ba,
the replacement items' warranties are only up to the original parts' warranties?
- Nov 2019
- 973
July 17th, 2020 02:19 PM #14374
July 17th, 2020 02:27 PM #14375
Typical MM roads amd expressways, so I don't know if that can be considered extreme "lubak".
- 52,732
July 17th, 2020 03:13 PM #14376sometimes,
it's not the lubaks.
it's the way one drives over the lubaks.
- Dec 2019
- 2,072
July 24th, 2020 03:56 PM #14377Or if you live specially on the places where roads are totally lubak na lubak.
Sent from my SM-N970F using Tsikot Forums mobile app
July 25th, 2020 12:27 PM #14378
I finally got my innova after 3 months of fixing at shop for the damage rear door. I noticed the power steering fluid level is below level and when I drive it again for the 1st time after 3 months the steering wheel felt a bit stiff. What should I do? It was okay 3 months ago when I have it repaired. Thank you.
July 25th, 2020 12:49 PM #14379
How stiff is "stiff"?
I was driving a sedan before switching to an Innova and the first time I drove it, the steering wheel felt comparatively stiffer than the sedan... with obviously good reason. But after a while of driving it, I've grown accustomed to it.
Just saying that maybe you've been driving a different vehicle while your Innova was in the shop and you've just grown accustomed to it.
But to be thorough, refill the PSF and check for leaks. Also check the tire pressure.... low tire pressure makes for a harder steering.
July 25th, 2020 12:56 PM #14380
Yes I was indeed driving a sedan and I check also the tire pressure it was okay for 3 months of not using it all 4 tires 30psi and I just add 3psi making it 33psi. I will try to add PSF to make it to the desired level. But normally if the vehicle is not use for that long will it not make steering wheel stiff and does it need to drain the PSF and refill a new one? I will check again probably also I was driving a sedan and now shift back to Innova and steering wheel felt a stiffer compared to sedan.
I also use the same brand for my android auto medyo mahal compared sa non branded typc to c.
Suzuki JIMNY [merged threads]
