Page 716 of 775 FirstFirst ... 616666706712713714715716717718719720726766 ... LastLast
Results 14,301 to 14,320 of 15487
    Dec 2019
    #14301
    Hello. Ask ko lang po kung anong ginagawa sa first 1000 kms PMS? Nasa 700 kms pa lang po yung Innova namin kaso gusto na namin ipa 1000 kms kasi baka biglang ibalik na sa ECQ yung Metro Manila. May problema rin kasi yung transmission. Minsan ang hirap niya mag-shift.
    Ask ko rin po kung okay bang 100 pesos lang yung ibigay sa mekaniko ng Toyota?
    #14302
    Quote Originally Posted by Amirqwe View Post
    puede naman. check loose bolts yata. wala yatang pinalitan. am not even sure if they changed oil. basta dinala ko. give them a call regarding your concerns, po.
    i do not give tip at the casa. since 2005. have purchased several cars from them, all serviced during warranty period, there.
    they haven't given me the evil-eye yet. heh heh.
    ang inabutan ko, ay yung batang naglinis ng loob ng kotse. siya lang kasi ang nakita ko. mukhang trainee at hindi regular employee. considering no amount is expected nor required, any amount is welcome.
    Jun 2005
    #14303
    1st 1k PMS ng innova ko costs 2400. That was around august last year. The 5k PMS cost about the same (february this year). Regular oil + oil filter, usual inspection and top up.
    No need to tip mechanics at casa.
    Sent from my MI MAX 2 using Tapatalk
    Dec 2019
    #14304
    Ito po yung 1000 kms PMS ko sa Toyota.
    1. Oil + Oil Filter + gasket = 2600 pesos
    2. Miscellaneous = 510 pesos
    Bawal ipatanggal. Ito raw kasi yung mga glove, pamunas. Basta yung mga ginamit daw ng mekaniko.
    Grabe rin pala sa Toyota. Unang singil sa akin ay 10,000 pesos dahil fully synthetic oil at kasama yung mga add-on nila tulad ng engine cleaner. Pinatanggal ko yung add-on tapos mga nasa 7k na. Pinagawa kong ordinary oil (mineral oil siguro) na lang.
    6 months interval lang kasi kapag fully synthetic tapos 3 months kapag ordinary oil.
    Regarding naman sa transmission ko, pinipilit ng mekaniko na hindi raw niya mareplicate pero nung pinoint out ko sa kanya yung tunog(kasi nagagawa naman niya), sinabi niya lang na normal lang daw yun. Pumunta siya roon sa isa pang Innova tapos nangyayari rin paminsan minsan yung hard shifting (+tunog). Normal lang kaya na paminsan minsan lang nangyayari sa akin yung hard shifting. Liable kaya sila kapag may mangyari sa transmission ng Innova namin?
    #14305
    aha
    now, you're learning!
    regarding the sound and hard shifting,
    is it the sound of hard metal grinding against each other?
    if so, that's probably normal. press the clutch pedal fully and the sound and the difficulty should go away.
    Feb 2019
    #14306
    For those who owns an innova what is your current odo reading? Mine is around 110K still running good just have the problem with check engine light which turns on occassionally especially when at full stop.
    #14307
    IIRC ours is already 180K?
    Airbag indicator naman naka ilaw [emoji23]
    Feb 2019
    #14308
    Haha I just reset mine whenever it lights up. When your car is aging strange things happens on your dashboard hehe
    Jan 2009
    #14309
    But on the other hand, if it's the airbag... something that may one day have something to do with a passenger surviving or dying, wouldn't it be prudent to have it looked at? At least find out what the code is?
    Feb 2019
    #14310
    I tried it bringing it before to the shop to have it scanned but at the time it doesn't light up so they cannot check it right? For a week probably it light up once or twice especially when it is long idle in stoplight.
    Hindi sila liable. Stop dreaming. If youre doing maintenance with them and if there should be any failure during the warranty period they will cover anything that failed. Clutch and brakes are consumables though.
    Jan 2009
    #14312
    CEL or SRS?
    I thought you just said that you reset it whenever it lights up.... and there's a question of how you're doing this.
    Anyway, some DTCs are stored in memory and can be extracted during a scan.
    Feb 2019
    #14313
    CEL or SRS?
    Yes when it happens I reset it meaning I turn off the engine and then start the engine again. I will bring it to the shop for my next pms and let them see if it can be retrieved in the memory. Mine is CEL.
    Jan 2009
    #14314
    Yes. But, make them admit that you both heard something to which they couldn't (or wouldn't) identify the root cause. That's going to be on record and a receipt which you can cash-in on a rainy day. If they don't want to put it in writing, then compel them to look into it. Ganun lang yun. Wala silang pupuntahan.
    #14315
    2005 model.
    140K km.
    early on, the fuel water contamination light lit up.
    i did everything in the manual. no dice.
    in disgust, i replaced the entire fuel filter assembly. it was still cheap, back then.
    that solved the problem.
    Jun 2005
    #14316
    Matik ba yan? Pansin ko may gear hunting innova lalo sa eco mode. Not complaining. Normal naman yun
    #14317
    2005 model.
    140K km.
    Ours is 2008 model, gasoline AT... Approx 62kkm... Changed 4 tyres, front brake pads and 4 shocks....No issue so far...😎😍😉
    #14318
    Ours is 2008 model, gasoline AT... Approx 62kkm... Changed 4 tyres, front brake pads and 4 shocks....No issue so far...������
    innova is a well-built car.
    it is a shame that the new model is larger than the previous.
    medyo mahirap sakin, dahil makitid neighborhood namin...
    mas type ko tuloy na bumili ng slightly used, kaysa kumuha ng bago. sigurado pa sa EP.
    Jun 2005
    #14319
    Di naman ganun kalaki difference doc..
    Dec 2019
    #14320
    i've just remembered last year i drove a 2nd gen innova 2.8 and went to my aunt's house in bulacan. napakakitid din ng pathway papuntang garage nila and then nahirapan akong ipasok duon. they also had an innova g 2.5 d4d 1st gen kasya siya. kaya pinark ko na lang beside of their house instead.
    then narealized ko na puedeng magkasya ang 2nd gen innova dun because my uncle told me that he parked a hiace gl grandia (yung flat nose version) and it fits in the narrow pathway to the garage.
Toyota Innova Owners & Discussions [continued 3]
