Page 712 of 775 FirstFirst ... 612662702708709710711712713714715716722762 ... LastLast
Results 14,221 to 14,240 of 15487
    Jan 2009
    #14221
    Quote Originally Posted by jovz View Post
    tanung ko lang po kung ano po possible cause ng tulo sa may passenger side po gawa nababasa po un flooring
    Most likely, condensate from the A/C. Check the drain hose if it's loose, blocked, or broken.
    May 2010
    #14222
    Share ko lang. Kahapon nag palit ako ng clutch set at kahit ng aux fan (sa harap ng consender)
    * Clutch Set - P5,500
    ** Clutch Cover - Aisin
    ** Clutch Disk - Aisin
    ** Pilot Bearing - Koyo (same as orig)
    ** Release Bearing - Koyo (same as orig)
    * Labor - P2,500
    * Aux Fan - P680
    ** Fan - Sanden 80w 12 volts. 12 inches size (10 inches blade)
    ** Relay
    ** Fuse
    * Labor - P950 (napamahal. kay mang Danny 400 lang sabi niya dati)
    Dec 2019
    #14223
    Parang common issue ba to sa new innova sir?
    Dec 2019
    #14224
    Tama. Was an issue in my 80 series before. Same thing parang na misalign ata
    #14225
    Hello guys!
    do any of you know approx. how much a throttle pedal position sensor costs now? 2006 Innova D4d manual. saka saan kaya aa south mura makabili or sa banawe?
    thanks
    Jun 2005
    #14226
    Quote Originally Posted by Louga View Post
    * Labor - P2,500
    * Aux Fan - P680
    ** Relay
    ** Fuse
    Ano model inno mo? Saang shop ka nagpagawa ng clutch? Bukas kahit sunday?
    San ka din bumilinng parts?
    Sent from my MI MAX 2 using Tapatalk
    #14227
    * Labor - P2,500
    * Aux Fan - P680
    ** Relay
    ** Fuse
    aux fan?
    whypo?
    my innova does not have one.
    May 2010
    #14228
    aux fan?
    whypo?
    Pang tulong lang po pag summer at babad sa araw. Ok naman a/c ko so far. Murang upgrade lang din kaya ok na din.
    Sumasabay lang sya sa compressor. Pag pitik ng compressor pitik din yun fan.
    May 2010
    #14229
    Quote Originally Posted by sirkosero View Post
    2009 gas m/t 140k kms.
    Auto shop: Will power auto supply. Along East service road (katabi pizza hut) in between FTI and Bicutan. Dealer sya ng Aisin. Mas mura kesa sa Pasay.
    May katabi na autoshop din ito Vegar pangalan mura din don.
    Note; ang orig na release bearing ng innova ko ay koyo brand. yun binigay sakin ay NSK na mahal mali pla so be aware lang. See attachment non pinapalit na bearing na same sa orig pati yun number.
    Yun orig ko na clutch cover at plate parehas Aisin uu tatak non binaklas.
    Shop: Petron gas station. West service road in between sun valley and merville. Pag galing ka south 1km away from Toyota bicutan. Look for Teody. 09303260561. Sarado sunday unless pa appointment ka. Tawag muna bago magpagawa kc dami nag papaayos sa kanya mag 1 lng sya. Doon din ako nagpagawa pang ilalim ko 3weeks ago. Maayos gawa hindi madaya.
    List of Aisin Dealers
    Parañaque - Grand Sucat Auto Supply/Cruiser Parts Center/Willpower Auto Supply
    Banawe - Toyorama/Toyocars
    Masangkay - Riken Motor Sales
    Will power info. Bukas linggo 1/2 day. Willpower Auto Supply - Auto Parts in Paranaque
    Attached Thumbnails Attached Thumbnails 20200301_112537.jpg   20200301_115608.jpg   20200301_103533.jpg   20200301_103553.jpg
    Feb 2006
    #14230
    thanks po sir check ko din nga po pala ito
    Feb 2020
    #14231
    tanong lang po may nagbebenta kasi sa akin ng innova e manual diesel 2005 model acquired ng 2006, odo is 150k and kakapalit lang ng timing belt yung owner is maalaga naman sinusunod daw nya PMS, asking price is 400k ok lang po ba presyo nya? salamat sa sasagot
    #14232
    Quote Originally Posted by corner View Post
    if it is in as good a condition as you would like it to be,
    "yes".
    tawaran nyo po, baka sakaling bumigay pa nang kahit kakaunti.
    Feb 2020
    #14233
    "yes".
    sya na mismo nag baba ng presyo sir now its 385k need cash lang daw. nde kasi ako marunong tumingin ng oto sir, nde naman available yung mga mekaniko dito
    Dec 2019
    #14234
    tanong mo na rin kung may other issues pa yung innova niya.
    Aug 2013
    #14235
    Nauna na change oil. Next up, change PSF, ATF, and rear diff gear oil.
    Sir pwede malaman year model ng unit nyo & ODO? 2014 sa akin 140K kms na. Palit oils na din ako?
    #14236
    Check ka muna bro sa online sellers,- would not hurt to compare if you're keen on buying a unit...
    Talaga bang kilala mo ang nagbebenta sa iyo?
    #14237
    "hindi marunong tumingin..."
    you have a big problem, there.
    my only possible advice i can say is,
    look at whatever is visible. nothing should look "wrong".
    take it for a test drive. nothing should feel fishy. drive it over road surface imperfections and humps. dapat wala lagutok.
    have it lifted up at a gas station. nothing wet should be seen underneath, including the suspension parts, engine bottom, and transmission housing.
    and examine the CR (certificate of registration) and OR (official receipt). all originals dapat, up-to-date, and seller's name must be on the papeles.
    good luck, po.
    Feb 2020
    #14238
    good luck, po.
    nag sama po ako mekaniko na sanay na sa toyota, kaso limit lang ang oras na pwede sya, kaya sya ang pinag test drive ko, dalawa lang sabi nyang problema, mejo hilaw na AC at my singaw na radiator parang sabi nya smallest pin hole at nakita rin ng owner. well yung owner binawasan pa nya ng 10k for radiator and ac service. dahil nga limitado lang si mekaniko sa oras sabi nya skin maganda pa yung hatak solid pa yung pang ilalim, ok na ok pa. yung age nung car is totally not abused unlike sa mga unang nakita namin. small dents and scratches is normal for second hand car sabi nya. kaya noong umalis si mekaniko, tumawad pa ako gang 370k para may pang diesel ako, tumawa si owner pero binigay parin nya yung car nya for 370k dahil need nila ng cash talaga pang down sa isang pwesto raw kesa maunahan sila ng iba. ... nag text si mekaniko nung kalagitnaan na ng bayaran, sabi nya kunin ko na kasi minor issues lang meron. sa edad daw nung innova mukhang maalaga si owner. puro casa yung innova nya with resibo talaga and records. the saddest part is napaluha si owner at niyakap nya yung car nya at nag paalam na. nare repair po ba ang rad ng innova or purchase nang bago ano po magandang brand at presyo at saan makakabili or pwede ba ako bumili mismo sa toyota?
    edited. si mekaniko laht tumingin pina lift nya sa shell
    walang naging problem sa papeles sir
    Feb 2020
    #14239
    minor issues lang daw talaga sir and nabili ko na po yung innova nya
    #14240
    although the radiator is plastic, matibay naman.
    mine is still original, since 2005.
    i do not think a leak fix for a plastic radiator, will last long.
    buy a new one, sir.
    i think the innova is one car that the manufacturer got right, the first time.
    it's the most problem-free car i have ever experienced.
Toyota Innova Owners & Discussions [continued 3]
