Results 7,011 to 7,020 of 15485
BANNED BANNED BANNED
- Feb 2013
- 487
July 21st, 2013 10:27 PM #7011Yup kita mga ganyan na problema, wala ako windows 8, pero kung 32 bit yan, tatakbo yan.
July 22nd, 2013 08:41 AM #7012
VVTi ba? If yes,
It can be.
1. visually check the rocker arms by opening the valve cover - nangyari na sa akin yan nahulog ang isang rocker arm, medyo complicated and pagbalik ng rocker arm but doable by your suking mekaniko. Yung VVTi hindi na po nakatuhog na parang barbecue ang mga rocker arms, kundi nakaipit lang sa overhead cams kaya may tendency na madisplaced gaya ng nangyari sa akin.
2. Sliding clutch.
July 22nd, 2013 08:53 AM #7013
Sa tire pressure , do not under inflate it will wear out your outer tire corners, pag under inflate ang sumasayad sa lupa ay yung mga kanto at yung gitna less pressure na halos naka angat sa lupa.
Reminder lang po sa mga rezing rezing dyan
Stock Yokohama is 94S rating meaning Load Index is=670Kilos and Maximum Speed=180KPH
If you want a better performance and higher speed rating find tires the have H and V ratings.
July 22nd, 2013 11:53 AM #7016
Yes, all tires has this ratings marked on the sidewalls aside from Manufacturing date, min/max PSI pressure.
Meron akong nakita na Indonesian Tire brand (Delium) 94H rating meaning 210KPH max speed at may Mags lip protector pa *P3,000/piece
Meron din Indonesian brand (Gajah Tunggal) GTX65 na 94V rating meaning 240KPH max speed, di ko pa alam price probably around less than 4K/piece - price guess lang
Meron ba dito na naka Gajah Tunggal GTX65 tires? pa share naman ng price at review.Last edited by Mile2; July 22nd, 2013 at 11:56 AM.
- Jan 2010
- 304
July 22nd, 2013 12:33 PM #7017after 4 yrs, all stock pa din innova ko. sa lahat ng mod na pwede gawin, yung retractable or fixed headlight washer ang pinaka gusto kong ipa mod sa innova ko.saan may nagkakabit nito?
July 22nd, 2013 02:14 PM #7018
Hi guys, any recommendation sa spark plug? gusto ko kasi mag palit ngayon. May spark plug ba na nagpapaganda ng FC? VVTI
- Feb 2013
- 487
July 22nd, 2013 06:49 PM #7019
- Apr 2009
- 71
July 23rd, 2013 01:19 AM #7020Hello mga sir. Tanong ko lang regarding pms. Malapit na kasi mag 15k yung odo ko peron yung last pms ko is last feb pa (10k). Usually ano po ba sinusunod nyo sa pms? Every 5km na takbo or every 3 months? Or which ever comes first? Sa case ko kasi 5 months na since my last pms. Sinunod ko kasi yung ever 5km. D4D a/t po pala unit ko at mineral oil yung gamit ko. Thanks!
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
