For those who are interested in seeing their AN140 Innova's parts diagram and those looking for its part's corresponding part number, you can check this site.
Modifications TOYOTA INNOVA [GUN14#,TGN14#] (ASIA and MIDDLE EAST)
Hi Mr. Goodshot, you can buy online sa Aliexpress na gagamitin mong connectors if you are also interested to replace yuong stock to projector type (see below link). Still waiting pa rin ako who can provide the wiring configuration para sa projector. I can do the splicing and plan to top the new 8-pin connectors para sa projector and retain ko pa rin yuong old connector (hang lang yuong sa stock connectors, para in case need to ibalik sa stock, just plug in the old 8-pin connector). Pero need to add the 4 pins connectors na required ng projector. Hoping someone could help us on this.
Alta calidad 4pin auto impermeable 4 p enchufe de la carcasa macho y hembra conector gris 9 98 1 942-in Conectores from Luces e iluminacion on Aliexpress.com | Alibaba Group
Shhworldsea 8pin carcasa electrica automotriz cable arnes hembra macho conector enchufe 9 98 1 897 9 98 1 896 para Toyota-in Cables, adaptadores y enchufes from Automoviles y motocicletas on Aliexpress.com | Alibaba Group
Mga bossing ask ko lang magkano inaabot sa 25k pms last 20k pms ko kc sa toyota innova 2013 model inabot ng 13k plus, di pa kasama ac service don, ngayon kaya 25k pms magkano kaya aabutin if papa sama ko yung express air care ni toyota para sa ac kaso harap lang ata yon di pa kasama back side..need na rin ba talaga cleaning maintenance ng ac..marami po bang service advisor ang list ng list ng job number na di naman kailangan and naglilist ng job pero di naman ginagawa!! Salamat sa mga may nakaexperience at may nakaalam na makapagbibigay liwanag sa aking agam agam!!![]()
Salamat sa info bossing, although ala ako idea sa pagsilip ng air condition filter..lagi kasi may kasamang break Cleaner, break paste, break stop squeal,Silicon moUld, clean all breaks, tigthen body yung pms nila then pina add ko itong toyota aircare express Umabot na sa 15k ung cost ko!! Takot rin kasi bossing magkaproblema in long run kaso parang pamahal ng pamahal ang cost.![]()
yung air care express ata kasama dun yun binibutas nila yun gilid ng evaporator at lalagyan ng cleaning chemicals as opposed to removing the whole assembly possibly including taking apart the dasboard. I am also of the practice na as long as it runs fine don't mess with it. palit aircon filter lang regularly.
Hi mga sir, ask lng ako about sa oil leak sa innova 2015, 35k km. Nagtry po kc ako mag change oil diy, and yung pag tighten ko sa oil filter is hand tightened lng. Akala ko ok na po, pero after ilang days napansin ko, bgla nlng may oil spots sa garage, so pag check ko ng oil filter mejo loose sya di nmn sobrang loose, pero nahand tighten ko sya ulit pabalik. So nagpunta na ako sa car servicing near samin pinainspect ko and sinabi kong maluwag ang oil filter, so ginamitan nya ng filter wrench and naikot pa nya sigro ng 2x so sabi ng mekaniko, nalimutan siguro higpitan. Ang tanong ko po possible ba na may na damage dun, and Im not sure if ok na ang leak kc prng may oil leak prn ako nakita kanina pero not sure if dahil un sa ibang leaks bukod sa filter or yung sa oil filter na kumalat sa bandang frame ng kotse na naipon at tumulo lng ulit. Upon checking sa dipstick minimal and still safe level ang oil ko. Thanks sa sasgot and in need of advice.
i wouldn't let them touch my aircon, if it was still cooling fine.
if it still blows the same cool air at the same strength, there's no need to clean it, because there's nothing to clean.
when the stream of air gets weak, the filter may be dirty already. time to service it, DIY.
the aircon air filter is accessible by removing the bottom glovebox.
if you don't know how, google it, po. ang daming youtubes diyan on how to do it.
doing it the first time, it may seem like something will break. but it won't. pramis.
kailangan lang nang kaunting lakas ng bisig.
Ano kayang problem ng innova namin. Sana may makatulong
Kasi kahapon parang nagkakaproblem sa shifting from neutral to 1st gear Innova 2015 E Dsl MT namin. May time na naka 1st gear na siya bumababa siya to Neutral. I google'd for a solution na possible ay ang bushings sa shift lever. Di ko pa nachecheck kasi gusto ko sana if mabaklas ko siya may parts na ako na pang replace. Tingin nyo may iba pa bang issue?
Minsan nag ga grind siya kapag saktong first gear ko then releasing of clutch tapos biglang bababa to Neutral. No issues sa ibang gears. Neutral to First gear lang talaga.
Salamat sa makakatulong![]()
Sent from my Redmi Note 5 using Tapatalk
Kapag nag shi shift ka ba parang hindi masyadong pumapasok? Maganit?
Yung sakin, first gear at reverse ang may problem.
Kung oo, shifter bushing siya. Nakapag palit na din ako niyan. 750 bili ko dati sa set. Yung ball at bushing. DIY lang namin, dami videos sa youtube.
I noticed that my left headlight is busted in low beam but it works when in high beam and the right headlight works both in low and high beam. Is my left headlight bulb busted or is it a blown fuse? Thank you.
