What product/s did you use to maintain that shiny original paint? I remember my 2012 Innova before I sell it the white Pearl paint already has those manilaw nilaw.(is your headlamps still oem?)
maluwag yung passenger side 17 in wiper blade nung kabayo ko. pinalitan ko ng bago at mahigpit uli. kung di ako nagkakamali, plastic yung retainers (or holder) na nagcoconnect sa steel arm ng wiper. malamang talo si plastik kay bakal. hook type arm.
btw, bosch (graphite) wiper blade 17 in for P220 tapos P260 sa 20 inch yung nabili ko. tried also the refills years ago. in my case hindi masyado tumagal. or baka near its expiry date na siguro yun (rubber) kaya nagkaganun.
Need help with my 2008 Innova E Gas AT...
I noticed that my RPM is fluctuating (parang nawawalan ng power). It usually happens when I'm cruising at a steady pace in low RPM.
I also experienced it several times upon starting the engine. Normally, when we start a cold engine mas mataas talaga yung RPM until the temp normalizes. But it stays right above 1000rpm until it eventually goes down to its normal rate. But sometimes, I experience heavy fluctuations ranging somewhere between 500rpm to 2500rpm.
What could be the problem? Is it my battery or my spark plug?
Thanks Dr. D!
I don't remember having my fuel filter replaced ever. I kinda assumed it was being done every time I have the vehicle serviced in the case (that was long time ago, i don't get service from the case anymore).
I'll just have the fuel filter and spark plugs checked.
Guys pahelp naman. My family is considering to get an innova by the end of feb. Since lalabas ang 2016 model. May chance ba bababa ang presyo ng 2015 models.
Hi Guys,
Meron ba sa inyo na nakapag-remove nung parang blue film dun sa body cladding ng toyota niyo (see attached)? Para saan ba yun? Is it there to serve for a specific purpose i.e. reflector, protection etc? May mga nakikita kasi ako na wala na yun exposing the chrome finish (looks good lalo na kung Black yun ride). I tried to pry on the film medyo mahirap siya tanggalin so left it as it is. Any thoughts? Thanks!
It's just a protective sticker para di magasgas during manufacturing and assembly. Parang protective film sa mga LCD displays na bagong bili. I removed mine a few days after receiving my car. Nung una nag-dalawang isip din ako kung tatanggalin. Tinanggal ko na rin kasi marami akong nakikita sa daan na wala nang sticker... maayos naman.
Besides, mas maganda kung naked chrome lang dahil terno sa ibang chrome parts.
mga sir sa 60k na mileage innova d4d po ano po ang need ilagay na engine oil mineral pa rin po ba or ok na din semi synthetic and sa ganito po ba na mileage need na rin palitan un fuel filter thanks in advance po.
mga ka innova, umilaw un fuel filter ko kahit puno naman un gas ko, nagpalit na po ako ng fuel filter pero ganun pa rin po. matagal na po ako sa labas nag papachange oil.
anu po poblema kaya po?
Innova 2015 J diesel po un akin.
Thank you mga master
