Mas mura sa aguila at ok naman quality mahal sobra sa casa at bopols pa magkabit.
In a some of the toyotas i had, aguila nakasulat.
Now on my existing, AGC na lang. Dont know if the "A" means Aguila or Asahi on the existing models though.
Sent from my MI MAX 2 using Tapatalk
speaking of the defogger.
the defogger switch and the radio buttons in the innova i am using, are situated in such that i can easily brush onto the defogger switch, switching it on, when i manipulate the radio's controls.
and as i do not remember when i last used one, i am tempted to pull out the defogger's electircal connector clip, or its fuse.
Never once have this happened to me.... and I have a touchscreen 2-DIN. When I operate the screen, I rest my thumb on the silver bezel on the areas around the defogger and hazard switch, for stability. Having steering wheel controls does significantly reduce my interaction with the HU.
Yes, just implying that a touchscreen is more involved and increases the chance of inadvertently hitting the wrong buttons. Even so, it doesn't happen to me. But like me, you can however, anchor one of your free fingers on a solid surface while you work the controls (ie. knobs) with your thumb and index fingers.
Anyone here who knows where the flasher relay for the 2016-2018 Innova is located? I've been eyeing for an LED upgrade for my signal lights and I would like to avoid installing resistors since splicing of any kind is disturbing for me. Therefore, changing the flasher relay to something that would support LED signal bulbs to avoid hyperflashing would be my route to this upgrade. I would also like to ask how many pin it is since I've been seeing 3-pins and 8-pins and I don't know which is which. Thanks!![]()
Swerte pala ako since the defogger switch is at the foot/bottom portion of the consol adjacent to the switch of the OEM backing sensor, where the cigarette lighter interfaces are, so I practically do not touch the area....
However, one time, I noticed that the defogger switch was on.... Looked like it was hit by the cellphone which I usually secure in that area....
Planning to sell my 2013 Innova and get the 2.8 Innova G.
Tanong lang po mga bossing. Hindi ba nabibitin yung bagong 2.8 Innova sa akyatan at overtaking? Yung sakin kse ngayon vvti gapang sa bitukang manok papuntang bicol at kelangan galitin makina 5 adults + luggage lang on board.
Thanks.
It's a good upgrade for you. Gas are meant to revved high to get it going. And of course may factor din ang weight ng innova. 2.8 is more than enough. We have a 2.5 Innova. Walang ka hassle hassle ang akyatan with 9 passengers. Calamba to Camarines Sur pa yun![]()
Sent from my Redmi Note 5 using Tapatalk
Parehas lang malakas Naka detuned pa yan 2.8 innova na yan pero kung same ng TOTL ng Fort yan mas lalo kakainin yung Fortuner .
Maganda humatak basta diesel yung previous innova 2Kd 102Hp 200Nm torque ang lakas nga hatak ngayon pa kaya na naka Vnt + Intercooler pa [emoji846][emoji846][emoji846]
Sent from my SM-G950U using Tapatalk
