I ask my SA kung naoopen ba ng keyless yun liftgate. Di daw. Sayang naman. Nice additional feature sana yun at sulit ang pa keyless. Hehehe
i have an E variant, with casa-installed keyless.
the remote's unlock button, unlocks all four doors and the liftgate, all at the same time.
but there is no liftgate-only unlock button.
the J variant has a liftgate keyhole; the E variant does not. it was the reason i had a keyless installed in my E .. as it comes out from the factory, the only way to open the liftgate was by pressing the unlock button beside the driver! hassle kung umu-ulan o may maraming bagahe.
Speaking of the Innova's lift gate, if you have it open in the rain, will water ever get in the door through the door handle and/or plate lights?
It seems that when the door is up, the area where the plate number is attached forms a catch basin. From the looks of it, if you have it open long enough (like when loading/unloading stuff in the rain, water could collect and get in through the door handle mechanism or through some other way.
I have a G, if that makes any difference.
if you open the liftgate under heavy rain... in a few seconds, water will spill into the posterior aspect of the compartment, wetting your baggage.
hindi maganda ang design ng weatherstrip.
i guess this is the reason why i never encountered water collecting in the plate area.. sinasarhan ko agad ang liftgate dahil tinutuluan at nababasa ang bagahe..
mga sir, nag pa-change oil ako kanina and sabi ng mekaniko need daw palitan yung spark plug o-rings saka yung gasket (di ko sure saan banda) kasi nagle-leak yung langis sa palibot ng mga spark plug. Easy fix lang po ba sa mga mekaniko to? o-ring and gasket lang kaya kailangan or may iba pang pyesa na required? Thanks!
Mga sir, magkano kaya mag pa adjust ng hand break ng innova, na sobrahan gamit ng bayaw ni misis, parang na strecth na cable, kaya na hilahin ng isang daliri na walang kahirap hirap.
^ noted doc. Actually i want to learn everything about cars, from the engine to brake system so i can be a handyman. Doing it by myself. Thank for all the reply mga sir.
Good day ma'ams/sirs!
Tanong ko lang, anyone here got problems with alternator assembly? Yung sakin kasi (innova j 2010), may squeaking sound kahapon lang. though, minsan npapansin ko pag start ko, my ganung sound pero nawawala din in 5 sec. pero khapon di na nawala yung sound pg nka andar. pina check ko, ang sabi alternator assembly daw problem. anyone here got the same experience po?
Thanks!
when the belts squeek, my first suspect is loose belt, which can easily be remedied by tightening adjustments.
my second suspect is idler pulley bearing, in which case replacement is in order. (wd 40 squirt is a temporary fix. it comes back in 2 weeks.).
back in 2005-2006, my innova's charging system failed without warning. i was told then, that the alternator's bearing failed and couldn't be fixed. i had to buy a replacement alternator. (the model was new then, and there was no such thing as ex-casa parts.). today, i could argue that alternators/bearings don't fail within 2 years of use... but back then, i was younger...
as you might suspect by now... casas don't fix.they replace.
bring your car to an outside mechanic, for second opinion.
For those interested.
Tire rotation is important. Daming innova ako nakikita. Pudpod ang rear tires especially the outer side which means under inflated. Rotate every 5k.
I got original yokos *3500 ea
Wheel alignement toe and camber 600/set
Bendix pads 1000 set
