Results 13,501 to 13,510 of 15330
- Nov 2017
- 1,748
November 18th, 2018 08:06 AM #13501Mas mura sa aguila at ok naman quality mahal sobra sa casa at bopols pa magkabit.
- Jun 2005
- 3,774
November 18th, 2018 08:06 AM #13502In a some of the toyotas i had, aguila nakasulat.
Now on my existing, AGC na lang. Dont know if the "A" means Aguila or Asahi on the existing models though.
Sent from my MI MAX 2 using Tapatalk
November 18th, 2018 12:11 PM #13503
- 52,731
November 18th, 2018 06:12 PM #13504speaking of the defogger.
the defogger switch and the radio buttons in the innova i am using, are situated in such that i can easily brush onto the defogger switch, switching it on, when i manipulate the radio's controls.
and as i do not remember when i last used one, i am tempted to pull out the defogger's electircal connector clip, or its fuse.
November 18th, 2018 08:44 PM #13505
Never once have this happened to me.... and I have a touchscreen 2-DIN. When I operate the screen, I rest my thumb on the silver bezel on the areas around the defogger and hazard switch, for stability. Having steering wheel controls does significantly reduce my interaction with the HU.
- 52,731
November 18th, 2018 08:52 PM #13506
November 18th, 2018 08:59 PM #13507
Yes, just implying that a touchscreen is more involved and increases the chance of inadvertently hitting the wrong buttons. Even so, it doesn't happen to me. But like me, you can however, anchor one of your free fingers on a solid surface while you work the controls (ie. knobs) with your thumb and index fingers.
- 52,731
November 18th, 2018 09:01 PM #13508
- Oct 2018
- 46
November 18th, 2018 09:10 PM #13509Anyone here who knows where the flasher relay for the 2016-2018 Innova is located? I've been eyeing for an LED upgrade for my signal lights and I would like to avoid installing resistors since splicing of any kind is disturbing for me. Therefore, changing the flasher relay to something that would support LED signal bulbs to avoid hyperflashing would be my route to this upgrade. I would also like to ask how many pin it is since I've been seeing 3-pins and 8-pins and I don't know which is which. Thanks!
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
