Page 609 of 775 FirstFirst ... 509559599605606607608609610611612613619659709 ... LastLast
Results 12,161 to 12,180 of 15487
    Apr 2009
    #12161
    Quote Originally Posted by evincar View Post
    actually kaka pundi lang din saken ngayon weekend, same spot left brake light. 2012 model saken naka 2x na kong palit. pang 3rd na ngayon, hindi ko pa nga napapalitan
    ganon kaya talaga, sabi lang saken check ko raw voltage,
    hmmm bigla ko tuloy tinignan at check kung may pundi dito sa innova. ok pa nman all lights are working.
    Sent from my GT-I9300 using Tsikot Forums mobile app
    #12162
    Quote Originally Posted by mk View Post
    mga kapwa ka innova owners, na notice ko lang, itong particular model ng innova ( 2nd gen yata ) panay pundi either side ng brake lights. just dont know why. parang sa sampung innova na nakita ko, basta pag itong series na ito, sure talaga na may pundi. may poblema ba talaga sa pag gawa ng wiring ngeto ? ... yung unang release na innova wala naman ganun na problema
    sa mga innova owners na similar series, please check your brake lights for sure may pundi yan
    you can look at mine. it hasn't pundied yet since new, way back in 2012.
    the usual suspects in repeated pundi, include:1. vibration. loose housing, etc.; 2. excessive heat. look for loose connections; and 3. it's not really pundi, but is suffering from poor or dirty electrical connections. twirl the bulb to make it light up. but don't sandpaper the bulb socket, lest it rust.
    #12163
    So far, all original bulbs pa rin sa aming 2008 na unit...
    Oh wait. I changed the backing lights to double contacts, 5w for park light and 21w for reverse light.....
    Jan 2009
    #12164
    You have WHITE lights in the rear when the parklights are on? What for? That's technically illegal.
    BTT. Changed to red 1157 LEDs for the rear parklights/stoplights, red T15 LED for the high-mount brake light, and amber 1156PY LEDs on all turn signal lights.
    I still have the original bulbs somewhere.
    #12165
    Checked ours last night reverse lamp on the left and the 3rd brake lamp is busted.
    #12166
    Changed the bulbs to deep yellow bro.,- and only 5W (regular power rating) for park lights.
    Reverse,- 21W+5W......
    29.8K _/_/_/_/_/_/_/_/_/_/
    Jan 2009
    #12167
    [COLOR="#008080"]
    No offense. I'm just passionate about road signs, regulations, and signalling.
    It is certainly better than white. But still, only red and white (when in reverse) are allowed in the rear when solidly lit. Amber is allowed in the rear as signal and hazard lights (blinking) only. Though, solid amber is allowed on the side of the vehicle (particularly near the front).
    #12168
    No issue bro.
    I appreciate your input.
    Makes me a better citizen of our (shared) roads...
    #12169
    OT.
    the source i read (RA 4136) is strangely quiet re. back-up lights. it is not even mentioned.
    but it does mention plate lights as requirement!
    perhaps it has been updated...?
    Jan 2009
    #12170
    OT.
    In exterior car lights and indicators, white light is generally a universal signal to other drivers that your car is going towards the direction of the white lamp. In other words, if you see white light (from headlights or reverse lights), it indicates that the car is going towards you.
    For the same reason, red tail lights indicates the the vehicle is driving away from you.
    It is then not a good idea and sometime downright dangerous to use the wrong light color. As an example, it is dangerous and reckless to use red-colored lamps in front of any vehicle (unless you're the police/EMS and ONLY when they're flashing), as other vehicles might mistake you as going the opposite direction, instead of driving towards them.
    Using white tail lights is also both confusing and glaring.... annoying at the least.
    May 2012
    #12171
    madali ba magReplace Rear Tail Light Innova?
    balak ko mag DIY, ako nalang mag palit ng bulb sana
    kaso wala ko makita sa youtube or guide pag baklas
    salamat
    #12172
    salamat
    kung babasahin yung instructions sa owner's manual, mukhang napaka-dali! gaano ba naman kahirap mag-tanggal ng kitang-kitang regular-size bolts using a box wrench?
    but sa totoo lang, kapag babatakin na, ay feeling ko'y parang mababali ang housing. (nguni at hindi naman nabali.... heh heh.)
    May 2010
    #12173
    napalitan na rin water pump last saturday. wala ng tulo.
    #12174
    Quote Originally Posted by piscesboy View Post
    magkano po ang inabot?
    mukhang puede bang DIY?
    May 2010
    #12175
    mahirap po pag diy sir, marami po kakalasin, pati timing belt tatanggalin sir.
    6750 yung pump, meron mas mura pero hindi daw genuine. + 2k labor kasi nagpalinis narin ako ng brake at nagpalit ng pads tapos dagdag PSF.
    #12176
    Korek ka riyan bro..
    Lakasan lang ng loob at diskarte.
    You pull it out a bit sideways, while holding the whole structure.
    After a couple of successful ones, it comes naturally.... [actually a bigger challenge was the tail lights of the GS - in this case you have to rock it to let loose off the ear/positioner] Gamunggo ang pawis at kalakas ng kabog.... ��
    May 2012
    #12177
    Ty sir, subukan ko sa weeknd hehehe
    Feb 2015
    #12178
    Guys pahelp naman po... Nabutas ung condenser ng innova ko .. Ninto lang... Payong ang nakatusok... Sumingaw.. Kala ko kung ano ang umusok sa hood.. Kaya nataranta ako pinatay ko kagad ang makina. Then nakita ko ung condenser nabutas ang lakas ng sipol at singaw.. Magkano ba ang price nun ?meron bang surplus nun?at magkano kaya?or kaya pa kaya irepair to?pls help me naman. Malaki kasi ang butas ung sa payong na stick. Tnx
    #12179
    Quote Originally Posted by maze View Post
    kapag kusang nabubutas dahil sa edad, payo ko ay palitan na, at umpisa na ng pa-ulit-ulit na butas yan.
    ngunit ang sa iyo ay hindi kusang nabutas. puede pa sigurong ayusin yan. hindi ako sigurado, ngunit wari ko'y aluminum yan. hanap ka ng aluminum welder at doon ka magpa-ayos.
    Feb 2015
    #12180
    Sa may gitna banda tinamaan, 2010 model innova.. Sir baka may idea ka kung san makakabili ng brandnew o surplus.. Or shop na alam?and ideal price nya po.ung sana mura lang. Wala kasi ako idea dito nalang ako nagpost.
    Tnx po ng marami.
Toyota Innova Owners & Discussions [continued 3]
