Page 633 of 775 FirstFirst ... 533583623629630631632633634635636637643683733 ... LastLast
Results 12,641 to 12,660 of 15487
    #12641
    ^under inflated yata madalas front tires kaya nakalbo na sir hehe and bihira kasi mag tire rotation
    #12642
    Kahit na yata tama ang tyre pressure bro, madaling mapudpod ang unahang gulong ng Innova.... Naka 4 na siguro akong rotate ng gulong...
    Apr 2010
    #12643
    Baka may alam kayong shops that sell the front grille for the 2015 model, may project lang akong gagawin. mga 10 shop na ata natawagan ko sa Evangelista
    Jan 2009
    #12644
    Quote Originally Posted by ParticleX View Post
    There are a couple of listings on olx. Have you checked those?
    Apr 2010
    #12645
    yes na check ko na, those were for the 2012-2014 models. malaki yung grille nung 2015 halos 3/4th size ng radiator
    May 2010
    #12646
    ok lang to eto gamitin na coolant? kulay green siya, wala kasi yung pink e
    #12647
    bili nalang kayo sa casa ng premixed coolant. its 300pesos for 2L na if I'm not mistaken
    #12648
    I actually have a concentrate which i mix with distilled H2O..
    Jun 2016
    #12649
    Good day! I own a toyota innova gas AT its a E variant but ol model. Paano ba tamang pagcompute ng fuel consumption? Nagfull tank ako sa odo 70824 then nag drive ako at umabot sa 70987 ung odo sa last full tank ko ulet.. Click to click. Unleaded sa petron.. I run 163km base sa odo ko.. 70987-70824 =163. Ang 1st full tank til click(70824 odo) is 17.41 liters... Tas ung huling full tank ko is (70987 odo) is 18.91liters. Ang basehan is ung lass full tank? Naguguluhan ako kung ano tama..
    Sample 1 computation:
    Odo 163km . lass full tank 18.91liters. Kung ang basehan is Liters/100km.
    >>>>> 163km divide to 100km is equal to 1.63liters.. Bat nging 1.63 ang 163 kasi bumabase ako sa 100km per liter ,ryt?
    >>>>>next is 18.91 liters(last full tank) divide to 1.63 km is equal to 11.60 liters per 100 km?..
    >>>> fuel consumption is 11.60liters/100kms.
    Sample 2 computation... Simpl lang 163km(odo) divide 18.91liters(last full tank) is equal to 8.62liters sa 163km na tinakbo ko...
    >>>>>fuel consumption .. 8.60litres sa 163km run.O 11.62liters??? Thanks ng marami...
    Pls correct me if im wrong at kung ano tlaga tamang computation... Kasi naguguluhan talaga ako kung anu ang fuel consumption ko.. Kung 11.62 ba o 8.
    Jun 2016
    #12650
    Pls correct me if im wrong at kung ano tlaga tamang computation... Kasi naguguluhan talaga ako kung anu ang fuel consumption ko.. Kung 11.62 ba o 8.60liters?
    Sep 2012
    #12651
    (17.41 liters multiply by 100) divide by (70987 minus 70824) equals 10.680 liters per 100 km
    In Spreadsheet formula
    =(17.41*100)/(70987 - 70824)
    Sent from my Asus ZenFone 2 using Tapatalk
    Sep 2012
    #12652
    Kung kukunin mo naman is kilometer per liter
    (70987 minus 70824) divide by 17.41 liters equals 9.362 kilometer per liter
    =(70987-70824)/17.41
    Apr 2010
    #12653
    easier way to get KM/L:
    full tank, reset trip meter to 0
    drive, refuel as needed. more accurate if near empty
    note current trip meter reading
    refuel, note liters required to fill up
    divide trip meter reading to liters consumed
    example:
    you ran 500KMs on one full tank, then you required 45 liters to fill it up again to full
    500KMs / 45L = 11.1 KM/L
    #12654
    Quote Originally Posted by Deliq View Post
    Your second computation - 163 km divided by 18.91L on your second full tank - is the correct one.
    8.62 km/L, which is the same as 11.61 L/100km.
    #12655
    This is how important a cabin filter is. Replaced the 1 year old original Toyota (not fake OEMs) cabin filter with Vic carbon activated filter. Kadiri na yung old filter
    #12656
    Thanks for sharing bro
    I just dust off ours....😉
    #12657
    I just dust off ours....[emoji6]
    Hirap baklasin nung glove box. May technic ba? Hehe
    Dec 2007
    #12658
    Do one side then the other. Make a conscious effort not to pull down on the glove box as you try to dislodge it.
    #12659
    Use a screw driver wrapped with cloth and assist with your hand... Follow bro.timo07 style... Have done this with the rest of our rides.... Okay naman...
    Jan 2009
    #12660
    It gets THAT dirty because the Innova 2015 and older uses a recirculation flap that leaks too much outside air.
Toyota Innova Owners & Discussions [continued 3]
