Page 630 of 775 FirstFirst ... 530580620626627628629630631632633634640680730 ... LastLast
Results 12,581 to 12,600 of 15487
    #12581
    Quote Originally Posted by kisbai View Post
    helo po sa lahat. newbie question from a newbie innova owner. :-) . I am using Shell V Power Nitro Diesel for our new Innova E A/T. Pwede rn po ba yung Fuel Save Diesel ang gamitin ko kasi Power Nitro Diesel is more expensive. Thanks for the answers.
    There should be no issue using the regular diesel, bro.
    _/_/_/
    31.3K _/_/_/_/_/_/_/_/_/_/
    May 2012
    #12582
    inspect very well the housing.
    look for loose connection or poor contact (can generate excessive heat).
    look for loose mounts. vibrations can pundir bulbs faster.
    Thanks sir! sana maluwag lang
    mahal nun led bulb 1200 pala hahah
    #12583
    Quote Originally Posted by evincar View Post
    I still use the old incandescent bulbs as they light up the whole tail light assembly... More character, IMO.
    _/_/_/
    Jan 2011
    #12584
    Meron na bang nag try mag install ng carpet retention clip/hooks sa passenger side and middle seat of our innova?
    #12585
    Quote Originally Posted by 2rm View Post
    my 2005 has none. my 2012 has, factory-installed.
    i tried, years ago, in my other vehicle. i used velcro and two-sided tape. it didn't last long. for some reason, the velcro kept detaching. madumi sigoro...
    Jan 2009
    #12586
    [COLOR="#008080"]
    Depends really on the LED bulb design. It also lights up the whole tail light while the instant on/off characteristic of the LED somewhat makes it look a little modern. Same thing I did with the turn signal lights.
    #12587
    if the bulb is difficult to access, i would consider LED.
    but if not, i'd still use incandescent. the cost is a major issue...
    Jan 2009
    #12588
    If it adds 5HP per bulb, I'm all for it. LOL
    Kidding aside, I had those ordered from Amazon and eBay. All my interior lights are LEDs already.
    Excessive? Maybe. Any regrets? Absolutely not. I still have two pairs of Philips Xtreme Vision T10 LEDs on shipment for the front park lights and rear plate lights.
    #12589
    when newer, my right side headlight blinked out. twice. as it was not easy to replace, i considered LED after the third time. fortunately, it never happened again. it's still incandescent, years na...
    why it blinked out twice, i still don't know. i checked the housing, the contacts, etc.
    Jan 2009
    #12590
    What blinked? The actual headlight H4 bulb or the parklight T10 bulb?
    Anyway, I used these items:
    Amber 1156PY LED turn signals:
    Speed-adjustable flasher relay:
    Pure red 1157 20W COB LED brake lights:
    Pure red T15/T10 15W LED 3rd/High-mount brake light:
    #12591
    Speaking of blinking.
    Yung optitron gauge ko pasumpong sumpong blinking again.
    Nakiki christmas lights season.
    #12592
    i am sorry.
    i should have said, "blinked dead".
    the main bulb died, po.
    ok yung parklight, at mas madaling abutin siya.
    Jan 2009
    #12593
    i am sorry.
    That makes more sense. Some LEDs starts to blink/flash randomly when they die.
    FWIW, I'm still on my stock H4 bulb. When they go out, I'll probably get replacement conventional bulbs from Philips or Osram.
    Jan 2009
    #12594
    question lang, approximately how many kms bago magpalit ng break shoe at break rotor? 2x na ko nag papalit ng break pads at nasa 65k na odo.
    #12595
    Quote Originally Posted by frequenzy View Post
    that would depend on how much the driver uses his brakes, po.
    it can be as often as 10K km. i had my front disk pads replaced after more than 60K km.
    Jan 2009
    #12596
    Aside from sustaining any damage or defects, brake pads and rotors/drums are replaced based on remaining thickness. The minimum serviceable thickness figures (in millimeters) should be stated in the manual.
    Jan 2009
    #12597
    thanks sir, papacheck ko kapag nagpa break cleaning ako.
    Feb 2015
    #12598
    My innova E at Gas 10' 70k odo na.,gusto ko gumala magroadtrip kaso nakakawalang gana kasi mahal ng gas saka mababa fuel efficiency...7-8 km/L..from april 2016 (odo 56k) til present (odo 70k)na. hard to decide pag bumili bnew... montero 2016 2.4 dsl price sakin is 1,345,000 or the toyota innova G AT dsl 1,349,000. SUV or the MPV...
    Apr 2010
    #12599
    Kung bibili ka ng diesel vehicle just to offset the higher fuel cost, it would take you several years bago mag even out ang sticker price at maintenance ng gas vs diesel
    Dec 2008
    #12600
    If you keep the car more than 5 years and you add at least 10k km to the odo yearly. You would still come out ahead. imo.
    Sent from my SM-G930F using Tapatalk
Toyota Innova Owners & Discussions [continued 3]
