Page 636 of 775 FirstFirst ... 536586626632633634635636637638639640646686736 ... LastLast
Results 12,701 to 12,720 of 15487
    Jan 2009
    #12701
    Quote Originally Posted by archcos555 View Post
    Mga sir nakapag reface na ko ng rotor disc and palit brake pads nung Thursday. Ang mejo issue ko naman sa ngayona y parang ang lamya ng brakes or spongy pag pinangbbrake, ano po kaya cause neto. Pinableed nmn daw ng mechanic ung system. Anyone na may same experience dto? Thanks
    If everything was done right and there really is still enough rotor thickness, you just need to re-bed the brakes. Search the net for the procedure.
    May 2009
    #12702
    ganyan din yung kabayo ko nun. pinareface ko tapos palit bagong brake pads. mejo spongy kahit na fully bled na lahat ng brake lines.
    ginamit ko lang ng ginamit....tapos hard braking parati. ayun bumalik naman sa dating pakiramdam yung brake pedal.
    Sep 2014
    #12703
    Quote Originally Posted by miked View Post
    Ganun va sir akala ko kc may problema tlga. kc naninibago tlga ako dinala ko ult sa mekaniko ganun daw tlga un hayaan muna mag seat in ba yun, gamitin lng daw ng gamitin at babalik dn daw sa dati un. Ganun lng pla tlga pag bagong salpak. Nangingimay ako ang weird pag mag bbrake eh. By the way salamat sir sa input nio God bless[emoji4] [emoji4] [emoji4]
    Feb 2015
    #12704
    GOOD DAY... plano ko bumili sa online store na turbocharge kit... ilalagay ko sa innova gas at ko. ok lang kung gumastos ako malaki.. but the question is pede ba lagyan? kasi sa online kasi nakikita ko meron for gas engine.. saka ung obd tools ba yun na pde ireset ung odo bali naka apps sa android phone... either ipabili ko sa thailand ung ganung item sa brother ko na nasa thailand. kasi plan ko paastigin ung innova ko na model 2010, tas may nakita ko na foglamp napang 2010 na malapad na mayron na syang DRL.
    speedlab on fb. they're the only option imo.
    #12706
    Yes, at least, kung gumastos ka ng malaki, pag may problema, may tatakbuhan ka dito. Ü
    Speedlab ka na lang.
    Jun 2012
    #12707
    Quote Originally Posted by maze View Post
    Palit ka na lang ng kotse. Alphard v6. Yan astig.. innova kahit lagyan mo turbo, ganun pa rin yan. Di aastig yan
    Sent from my SM-A9000 using Tapatalk
    Sep 2004
    #12708
    Anyone here have problem with their odometer and speedometer readings? meaning not accurate? Is the speed sensor the solution to this? or is there other options.
    My problem is my Automatic Tranny, and the mechanic said need to fiz first the speedometer problem for the tranny problem to go away. Thanks.
    Feb 2015
    #12709
    Quote Originally Posted by dct View Post
    mahal ang alphard wew... i have another car yung montero newlook . . . experiment sa innova ko, lalo na yung engine na palagyan ng turbo... nway thanks sa advice . . saka ung odometer irereset ko sya gamit ung obd tools na ipapabili ko sa brother ko sa thailand.
    Apr 2010
    #12710
    ^ kung gagawa ka nang kalokohan, wag mo nang i-announce unless 999% sure ka na hindi mo ibebenta sa market yan
    #12711
    now, why would you want to re-set the odometer?
    Jan 2009
    #12712
    I can understand the reason behind you wanting to add a turbo, but what's the reason behind the odometer change?
    Changing the odometer (usually to lower the mileage reading), is illegal in many countries. At the least, the action is frowned upon as it connotes deception.
    Mar 2017
    #12713
    Any reputable paint shop na pwede nyo mairecommend na kayang gayahin ang original color, para lang sa back door ng innova, nasagi kasi ng tricycle, thank you?
    May 2010
    #12714
    can anyone recommend a trustworthy mechanic for innova? malapit sana sa Marikina
    #12715
    Quote Originally Posted by Avaris008 View Post
    if it's the engine, i don't know any.
    if it's for the change oil, i bring mine to the gas station. i use whatever specc'ed mineral oil and oil filter they have on the shelves. 'been doin' this for over ten years now, with no negative effects.
    if it's for the rest of the car, like brakes, shocks, and other regular wear and tear items, most jobs are pretty straightforward. i have mine done by the tambay mechanics beside the auto parts store.
    Jan 2011
    #12716
    Quote Originally Posted by shotgun_banjo View Post
    Just in case i want to know how much those little things are so that I can compare to other cars available online and assume those things needs to be done. I can't see the car personally as I am not in the Philippines so same thing with other cars that I see online which I need to take with a grain of salt when I look at the pictures and assume the worst.
    I know what you mean. Hindi ko papagamit yung sasakyan at siguradong mag-rarambo ako pag nasira sa kamay ng ibang tao yun. May nakaready na nga akong apat na jack stands para paguwi ko lift up yung sasakyan para hindi magkaroon ng flat portion yung tires. Mayroon din akong GPS tracker na kakabit sa sasakyan para pag may nag-start ng auto every 10 seconds magsesend sakin ng location at kung gugustuhin ko man pakinggan yung conversation sa loob ng sasakyan (walang takas saka walang carnap ba LOL!)
    Nagrent na ako ng sasakyan dati....sa 4 weeks kong rent I spent $56,000 pesos (2k a day) whats worst I can't even drive the damn car and I hate seating in the passenger seat. Sometimes my wife goes home as well for 2 to 3 weeks and also rents so we are looking at 7 weeks at the most in the Philippines every year so that is a $98,000 for a car rent. You are crazy not just buy a used car and offload the big chunk now then keep it for 6-8 years and you have your own car. I drive all over Luzon when I go home so yes it is expensive to rent hence the reason why I want to buy.
    I already found the right Innova and I think I got a steal for it. 2011 Innova G that only has 24k on the motor and this is the best part....seller agreed to sell it for 500k. My cousin who is a service adviser at a Toyota delaeship looked at the car and brought one of his Toyota mechanic who work at the same casa and they could not believe "the find" and was told I will be crazy for not buying it and if I will not buy it, they will, and sell it for 600k and make 100k easily. I was told the car is in pristine condition except for the following:
    - Minor scratch on the windshield caused by still original wipers (I chuckled when I found this out - 6 year old car with original wiper on it). They assured me it will be removed as they remove those scratches everyday at the casa.
    - Very minor scratches in the front and rear bumper caused by normal Manila driving. I told them I want it removed and was told cost will be around 3000 pesos per bumper.
    So ngayon ito tanong ko sa inyo:
    1. Where to get nice leather seats (leder land?) how much will it cost to get the door inserts wrapped with the same leather material?
    2. Where to get the bumper repaired instead sa casa where my cousin works? Is 3000 pesos per bumper okay sa casa?
    3. Mayroon bang floor liners for innova (semi-flexible rigid rubber tub like weathertech) if yes saan makakabili and how much po to?
    4. If I change the headunit of the Innova G for a 2 din touch screen for back-up camera will the steering wheel controls still function? Saan magandang magpakabit ng headunit saka backup and what brand?
    5. Saan murang bumili ng step board, roof rail, roof rack saka Thule carrier?
    Jan 2011
    #12717
    if you are much of the time of the year, abroad, and you are not going to be the user, and neither your immediate, loving family, i suggest you not buy it or any other car at this point, sir.
    baka magkanda-samaan lang kayo ng loob ng gagamit.
    serious advice.
    Aug 2011
    #12718
    Any idea po magkano buong backdoor ng innova 2016?
    Jun 2016
    #12719
    Good day! ask ko lang about sa AT transmision,naging habit ko na rin. pag nagdrdriv na ako nilalagay ko lang sa 3 pag sa mga kalsada na mejo matricycle pag nasa 40kph na saka ko shini shift sa D while running 40kph at naka apak sa gas. tas ganun rin pag ka paakyat na nasa 3 then pag hirap shinishift ko sa 2 while running at nakaapak sa gas. di nman siguro masira ung trans ng innova ko kung ganung ginagawa ko, base sa experience nyo? thanks sa makakasagot at makhingi ng payo para iwas sakit rin sa ulo.. hehe, gas engine po pala.. thanks
    #12720
    Quote Originally Posted by Deliq View Post
    i put my AT to D, and let the AT do the decision-making. works fine with me.
    the only time when i am tempted to put it in 3 or 2 or 1, is on flooded streets.
    if you find the speed too much, just let go of the gas pedal.
Toyota Innova Owners & Discussions [continued 3]
