Page 507 of 775 FirstFirst ... 407457497503504505506507508509510511517557607 ... LastLast
Results 10,121 to 10,140 of 15487
    Oct 2013
    #10121
    Kung automatic yan, mas malakas sa gas. Parang mahal sa 390k kung 05 model.
    Mar 2015
    #10122
    manual trans po, mataas nga po price pero 1st owned all stock 59k km reading. Enough na po ba yung txt sa lto to verify kung malinis ang documents ng vehicle or need ko punta ng ltO.
    Any sugestion po regarding what type of innova is fit for my 400k budget. Tnx
    Oct 2013
    #10123
    Makakuha ka na nyan d4d na j
    Feb 2015
    #10124
    Jan 2012
    #10125
    Quote Originally Posted by dccct View Post
    I own a 05 model G gas manual(got it 3 years ago at PhP510k with 75k+ km reading) and here are what I've changed so far: tires, fuel filter, air filter, battery, fuel pump, aircon evaporators (front and rear),brake pads(front and rear),shock absorbers(front and rear),engine tuning(material and labor), then every 5kms - oil semi-synth/oil filter and spark plug.
    I suggest using your budget for the d/p of a brand new E model d4d (manual), because it has all the features of the former G(05), even more. 350K d/p 14-15k per month for 5 years (it may cost more but is almost the same as buying replacement parts for a 05 model)
    Hope this helps. tia.
    Oct 2013
    #10126
    Bakit ka nagpalit fuel pump?
    Jan 2012
    #10127
    Quote Originally Posted by vvti2.0 View Post
    CEL na po sir at 100K+kms. mahina na voltage upon checking. submerged po kasi. pag nabuksan, halos manipis na wires sa loob.
    Mar 2015
    #10128
    Salamat sir sa info,
    Not practical for me get new car gagamitin lang po kc every vcation nmin dyan once a year then wla na po ggamit nga car. Plan ko rin po dispose after two years. Salamat po.
    Aug 2014
    #10129
    Quote Originally Posted by 1natzt View Post
    di pa ba kumakain ng langis?
    medyo common yata sa vvti corolla ewan ko lang ssa innova pag di religiously ng pms.
    Oct 2013
    #10130
    Iba ang 1trfe, wala ata issue ng sludging compared sa vios at altis. Mas bago kasi na engine. Yung filter sir, dumumi na rin ba?
    Oct 2013
    #10131
    Kung bihira mo gamitin, get the vvti, you can advantage of the lower price. Para yung sa amin, nakuha namin for 270k + 30k, model 2008 E manual vvti. Plan ko na sana ibenta at same price then dagdag ako around 150k to get a d4d, pero ang fuel consumption ko every month is around PhP 2.5k lang nung PhP 55 per liter ang unleaded. So di practical to spend the 150k difference para sa matitipid ko sa fuel consumption. Baka obsolete na innova di ko pa nabawi 150k.
    Jan 2012
    #10132
    yung fuel pump filter, malinis pa sir. problema lang talaga yung submerged electronic components, nabubura yung pcb board after several years. same sa fuel gauge din.
    Oct 2013
    #10133
    Fuel gauge dun sa dashboard paps?
    Oct 2013
    #10134
    How about yung fuel filter sa engine bay paps?
    Feb 2015
    #10135
    first pms today ng innova e d4d ko. 7.5k+ nagastos ko po.
    nah change oil na po. at synthetic yung pinagamit ko. tas nag palit na din ng oil filter at ng casket or gasket ba yun. nag add daw sila ng pang linis sa dinadaanan ng kurudo papunta makina. nag lagay din daw sila ng oil na maglulubricate sa loob ng engine. so kahit daw na si pa fully nag cicirculate yung engine oil sa loob kahit kakastart lang ng makina ay safe na ipatakbo. wala ng risk na magasgasan daw kung ano pa.man gumagalaw sa loob.
    next pms po ay schedule for change ng oil filter and adding 1l synthetic engine oil. sa 10k na daw let po ang change oil.
    after 5k pms. advisable pa ba mag papms sa casa or sa labas na lang? hmm san ba talaga mas safe? sa casa or sa labas. given na mas makakatipid "daw" sa labas. hmm.
    thanks po sa mag aaddvise.
    Feb 2015
    #10136
    sa next pms pala ay airfilter.. correction dun sa oil filter na nalagay ko ehehe.
    Jan 2013
    #10137
    Yung iridium spark plug ba ng innova kelangan pa linisin pag nag pa pms? Planning to have my next pms outside casa kse patapos na rin bayad ko..
    Oct 2013
    #10138
    Di naman nililinis yung, baka maputol pa yung tip.
    Aug 2014
    #10139
    Quote Originally Posted by NarsMlvn View Post
    dapat sir mineral muna, mas mainam sana every 5k, para kahit di nafilter sa oil worn metals, maflush out naman sa oil change.
    pero naka synthetic ka na, palit ka na lang oil filter after 5k.
    enjoy the ride and be safe.
    Feb 2015
    #10140
    so mas maganda ang mineral kesa sa synthetic?
Toyota Innova Owners & Discussions [continued 3]
