Me article sa topgearph na new plates lang daw ang bawal ang cover. Paglumang plates pde pa daw me cover as long as clear.
that article is a hearsay until such time na magrelease ang LTO na memo that the old plates can use transparent plate covers.
ako tinangal ko na rin paps... tutal naka standby lang naman yung covers natin kung sakali totoo nga na may exemption... huwahahaha!
sa 1.2k na mods, ipenalty tayo ng 5k nyehehehe.... hay naku, pero tama lang naman na wala mga covers, pero dapat implement nila ng maayos sa lahat...
Ako paps d ako agree dun.. dapat i allow ang plate cover as long as clear at visible ang plate number.. kse proteksyon din yun kahit papano sa mga magnanakaw ng plaka tapos gagamitin sa krimen.. dapat na ipagbawal ay yung mga naka tilt ang plaka at malabo yung cover kse hindi makikita ang plate number sa mga cctv sa kalsada..
matutuwa na naman mga magnanakaw ng plaka nyan kse pyesta na naman sila.. hehe..
wala tayo choice, that is the law... ako mismo gusto ko rin sana meron.. pero yun nga, yan ang batas..
regarding sprint booster, theres a documentation over the net that the claim of sprint booster reducing the DELAY in TIME the throttle input is not true, it just reduces the pedal travel ex. that at half of pedal travel become full throttle, thats why the response is almost instantaneous, it manipulates only the VOLTAGE VALUE of throttle signal,
maninibago ka talaga pag meron saka wala.
What the throttle controller does is to alter the linearity of the voltage vs. Time of the pedal. Mathematically speaking it modifies the slope of the line.
Posted via Tsikot Mobile App
it is pure gimmickry, in some way your correct in saying it reduces the time, because halfway of pedal travel of throttle your already in full throttle.
linearity from no input to anywhere between 1/3 - 2/3 of pedal travel, usually halfway your already 12v or full throttle iirc.
anyway good investment in rezing rezing or quick acceleration.
nakagamit ako nyan nalito ako nung una, so sensitive, mga 40km yata bago nagamayan.
In other words, if accelerator speed is from 1 to 10, sprint booster simply makes 1=3 or 5 depending on your setting. So you end up with just 3 to 10 or 5 to 10 instead of the normal 1 to 10 increments.
it only makes your pedal travel shorter, making the last half a dead area and unusable,
kumabaga sa gun, short take-up / short trigger.
you can mimic the response of sb by being quick in the foot, kakapagod yan hehehe.
pero halos wala pa yata akong nakausap na di gusto ng effects ng sprint booster, hapi sila lahat, si manong lang hinde kasi andun sa crame mataas na bp.
Ano yung gimmick? Tama naman na mas pinabilis yung pag open ng throttle?
Kasi yung throttle is a voltage controlled device which is directly proportional sa voltage output ng apak mo sa pedal, ngayun ang ginawa ng add on controller is to amplify that signal to make it appear na mas diin yung apak mo, therefore mas mag open ng malaki earlier yung throtte mo, so it means na reduce nga yung lag.
Based from the Toyota Service Manual, ito ang specs ng accelerator pedal:
Standard Voltage:0.6 to 1.0 V, so yun ang output range ng pedal.
I get it. You get the same effect pushing the pedal further and faster. I am thinking this can be done mechnically to shorten the pedal travel.
Kind of expensive stuff IMO for the thing it does.
Sent from my GT-N5100 using Tapatalk 2
Ganyan ang presyo nyan kasi limited production lang naman yan and of course the safety standard processes it went thru just to be certified as safe to use in vehicles.
So it is not expensive for the thing it does.
