Page 314 of 775 FirstFirst ... 214264304310311312313314315316317318324364414 ... LastLast
Results 6,261 to 6,280 of 15487
    Jan 2012
    #6261
    Quote Originally Posted by siopaonatoasted View Post
    Di lang yung cylinder head gasket ang dapat mo palitan, pati yung gasket ng sparkplug. 1k ang set nyan sa toyora, PhP 600 yung sa cylinder head at PhP 400 yung sa sparkplug, meron sila stock dun.
    Kung nag leak na, dapat na nga yan palitan.
    salamat ng marami sir. i'll do as suggested.
    Oct 2011
    #6262
    Madaling maglaba... Mag-aral ka muna kung papaano tatanggalin, bro.
    19.2K:book:
    may nakita akong illustration dati dito sa thread on how to remove the cabin filter, medyo nakakatakot lang na i-push ung dalawang hinge/side ng lower glove compartment baka mabali.
    Jan 2012
    #6263
    Quote Originally Posted by Mile2 View Post
    I have done this twice already, bought the inner and outer gasket and did not put gasket maker (sealant) and it leaked.
    Solution: put gasket sealant.
    Take note: the original setup has sealant, if you look at the cylinder lip it has a slotted/uneven surface near the power steering fluid reservoir.
    salamat sir. i'll take note of these solutions.
    Jan 2013
    #6264
    Quote Originally Posted by Capsaul View Post
    last sunday from car park incline kasi ang pa exit, i approached the incline on 2nd gear, di pa sya nangangalahati sa inclined ramp kinapos ang innova ko, kapos to the point na tumigil sya halos midway...straight naman yung ramp pero kinapos talaga, at madami pa ako kasunod sa likod...i applied the hand break
    then shifted to 1st gear... then pressed the gas pedal almost to the metal then depressed the handbreak,,, after the climb may naamoy ako na parang sunog na goma or break lining ...inside the cabin medyo kinabahan ako what caused the smell, ano kaya sa tingin nyo, nawala naman after a while and wala naman kakaiba sa takbo after that incident... Ride is innova G gas....yung carpark is Remington Hotel sa may paranaque..
    sa MOA carpark i can use 2nd gear climbing its spiral ramp to carpark.
    survey nga tayo whats the best carpark in metro manila...
    for me yung new carpark ng Solaire no. 1 ... the best so far kasi libre pa hehehe
    sir.. clutch yung nangamoy nyan.. usually nangyayari yan dun sa mga tinatawag na "clutch driver".. meaning laging nakaapak sa clutch kahit hindi na kelangan..
    yung nangyari sayo naka engage na yung clutch at inapakan mo na yung gas pero hindi mo pa binibitawan yung clutch.. mangangamoy talaga yan..
    ang style pag kinapos ka sa matarik na ramp.. apakan mo break then handbrake mo muna then shift to 1st gear then dahan dahan mong apakan yung gas sabay dahan dahan release ng clutch habang naka handbrake.. wag mong i rev agad kelangan dahan dahan.. mapapansin mo na medyo aangat yung harap ng sasakyan.. ibig sabihin tinutulak na paakyat yung sasakyan mo pinipigilan lang ng handbrake.. then tsaka mo bitawan yung handbreak.. swabe yan at hindi mangangamoy clutch mo tsaka hindi over-rev yung makina mo..
    Jan 2010
    #6265
    Quote Originally Posted by homhomnova View Post
    thanks bro... wala naman kaya masama epekto nun sa clutch assembly and makina?
    May 2007
    #6266
    Meron paps, 2008 yung sa akin, meron ng cabin filter.
    Not sure sa 2007 models.
    Meron na rin sa 2007 models... 2005 - 2006 yung wala pa.
    #6267
    Quote Originally Posted by liv View Post
    mine is 2005... ako pa naglagay.
    May 2013
    #6268
    Patulong naman Innova owners/ experts, nagsawa na agad sa crosswind ang tatay ko, binenta at gusto bumili ulit ng innova. (innova j vvti ang gamit nya 3 months ago before nya binili yung crosswind) this time, may titignan daw po siya na Innova G D4D bukas. nagpapasama sa akin.
    very limited po ang alam ko sa innova d4d dahil vvti po yung sa akin at kakakuha ko lang din po 2 weeks ago.
    question:
    what are the things to check sa used innova g matic d4d model 2011?
    Feb 2013
    #6269
    Quote Originally Posted by bakaldos View Post
    question:
    Bakit inayawan nya rin yung VVTI?
    Tingnan nya typical sa d4d ay yung loss of powe habang tumatakbo, black smoke during start, oil leaks and the usual inspection sa pagbili ng sasakyan.
    May 2013
    #6270
    wala naman po siya inayawan sa vvti, madali lang talaga magsawa, palit ng palit. 1 year nya ginamit yung vvti, tapos yung crosswind, 3 months palang sawa na ulit... gusto daw niya D4D naman, either innova, hilux or fortuner.
    Oct 2011
    #6271
    Sir kindly check for the pms record of the 2011 d4-d innova to make sure na nasusunod.
    Feb 2013
    #6272
    Sino ba naman di magsasawa sa crosswind, matipid parang jeepney, pero ang ride mo naman parang jeepney rin kung umalog hehehe...
    Kung gusto busisiin nyo, ipa computer scan nyo.
    Pero if may casa records, and chances are meron pa, check the casa records.
    Sep 2011
    #6273
    imo, matagal ng solve ang issue na yan, sa mga 1st gen na innova ata yung mga may d4d loss power(2008 pababa) , at ang black smoke nasa maintenance lang yun, kung regular naman ang PMS , maiiwasan ang black smoke at ang magiging sakit sa makina ;)
    tsakA 2011 ang hanap ni sir BAKALDOS paniguradong wala ng d4d issue yun ,(peru iba pa rin yung i check yung sasakyan bago bilhin)
    Feb 2013
    #6274
    Di pa rin solved ang issue ng innova, may mga ilan ilan na nagkakaroon ng power loss, di lang innova, basta d4d.
    Oct 2011
    #6275
    Solved na sir. Isolated case na lang ung meron pang mga d4d issues
    Feb 2013
    #6276
    Kung ganun, oras na para bumili ng d4d hehehe... ano mga models ang ok na?
    Oct 2011
    #6277
    2009 up models afaik okay na sir!
    May 2013
    #6278
    salamat sa mga inputs sir, 2010 Innova G VVTi A/T ang kinuha ni tatay... dami namin tinignan na d4d, hindi nya type ang ingay ng D4D engine... ayun, vvti nalang binili.
    Aug 2005
    #6279
    medyo malakas sa gas pag a/t.
    Feb 2013
    #6280
    Hehehe.. kanya kanya talagang preference..
    Magkano sana paps yung d4d?
Toyota Innova Owners & Discussions [continued 3]
