Pag nag adjust ka naman ng handbrake kelangan mo buksan drumbrake, makikita mo na din Kung manipis brake linings.
ma'am its normal for an ageing vehicle. ganyan din po yung 2005 model na gamit ko.
possible pricy solutions would be (a) fuel supply cleaning (replace fuel pump / fuel injector cleaning) (b) remove carbon deposits on 4 cylinders(in short - overhaul)
sabi sa talyer nung pinacheckup ko, ibenta ko na lang daw.haha![]()
If you are experiencing sudden drops in RPM that goes up and down, it is a sign that you have either Fuel system problem or ignition system problem, you'll need to replace or clean any of these; spark plugs, MAF cleaning, Stick Coil contact cleaning, replace air filter, Don't worry per my experience VVTi is very tough engine it should not worn out easily given proper maintenance.
Sometimes, just driving at constant high revs eliminates this rough idling, good for me that my daily route is mixed city and highway that I can run at high speed, some say this called italian tuning![]()
after 25km pms last wednesday along the way pauwi may nadidinig ako na mahinang rattling noise sa may dashboard passenger side when accelerating... wala itong ganitong tunog before pms... yung tunog nya ay parang nag ka crumple ng candy wrapper... nakaka irita kasi yung tunog... i declined the offer nung advisor na for decarbonize na daw kasi 25k na... pati yung cleaning ng ac. ano sa tingin nyo mga bro?
hirap kasi mag paayos kung hindi sure exactly... baka pina overhaul mo na yun pala nanginginig pa rin.
Pero Sometimes.... wala akong naramdaman vibration... pero paminsan lang....
Minsan parang konting apak mo lang sa Gas magaan syang tumakbo... sometimes parang mabigat.... Di ko ma gets....
Mahal ko pa Innova... prang yoko pa ibenta. kasi wala akong maisip anong ipapalit.
sir.. I suspect yung mga clips ng air filter mo yan.. nagkaganyan din sakin dati.. akala ko coins o kung ano na nakalagay dun sa compartment sa dashboard.. nung una tinanggal ko lahat ng nakalagay sa compartment sa dashboard pati na dun sa compartment sa gitna ng upuan sa harap.. as in empty lahat.. pero meron pa rin.. tapos nung magpa 1k pms ako hindi ko muna sinabi sa SA ko kse ayaw ko muna ipagalaw kse duda ako sa tunog tsaka baka kung ano ano ang kalikutin ng mga yun..
tapos nung pauwi na ako nagulat ako nawala na yung tunog.. so ang assumption ko andun sa engine bay naggagaling yung tunog.. so out of curiosity tiningnan ko ngayon dun sa engine bay kung ano ang possible na cause ng tunog.. eh nung nagpa 1K pms ako wala naman iba ginawa kundi change oil, check air filter, check brakes.. kaya naisipan ko i unlock yung mga clips ng air filter.. ayun lumabas ulit yung tunog tapos nung binalik ko nawala ulit.. so my conclusion ay yun na yung cause nun at ngayon wala na ako naririnig na kahit anong tumutunog..
yun lang.. sana makatulong..
nag order po ako ng fuel pump, update ko po kayo kung may effect yung replacement sa vibration problem. wala kasing balancer yung 1tr-fe ng innova, di tulad ng sa fortuner na dalawa yung balancer kaya dindi maingay at walang vibration kahit yung first version pa.
di ko rin po ibebenta yung sa akin. compared to other gas-fed mpv, innova is the best sa experience ko.![]()
