Masyado mataas ang 170 mA para sa isang add on na naka standby mode.
Madali lang i-test yan yung kung add-on mo nga ang kumakain nyan, mag-series lang ng tester sa add-ons mo then kunin ang total current nila sa stand=by mode.
Toyota Makati ko pina-install yung alarm, central locking and back-up sensor. I did the parasitic drain test again because I came across an article regarding waiting for the ECU and alarm to got "sleep". Like clockwork after about 1 minute the drain dropped to 18 miliamperes. I did the test several times and ganun pa rin. Hintayin ko na lang kung mag drain yung battery by itself. Last night I'm getting 12.42V ngayong umaga 12.39V pero I had to start the car to reposition it. Try ko ulit tingnan voltage this PM. Anyway may appointment na ako sa casa for Tuesday. Thanks all and I will updaye you kung ano mangyayari.
Check mo paps yung hugot ng current sa battery mo kapag naka engine off ka. And you can also check nyan kung magcharge rin alternator mo.
Mga paps, ask lang kung naencounter nyo na ito sa innova fuel gauge, kapag pina-dle mo sasakyan ng mga 5 to 10 minutes, makita mo na biglang bumababa or gumalaw fuel gauge mo, pero kapag pinatakbo mo na ito, babalik sya sa normal reading. VVT-i 2008 E model sa akin mga paps. Ask lang kung na-observe or naencounter nyo na rin ito, say naipit kayo sa traffic or may inaantay kayo habang umaandar makina.
Parasitic drain is 180 milliamps which goes down to 18 millianps after ~ 1 minute. Load test (A/C, lights) is stable at 14V on idle. Revving still maintains ~14V at the battery terminal. Gusto ko sana load test using starter pero walang min/max function yung tester/multimeter ko.
guys, ask ko lang. For VVT-i na matic, ok lang ba while going uphill from 3 to shift down to L? Lets say when going uphill na nasa 3 ka, then mukhang bitin and just shift to L to pickup the pace, ok lang ba yun?
