Page 393 of 775 FirstFirst ... 293343383389390391392393394395396397403443493 ... LastLast
Results 7,841 to 7,860 of 15487
    Nov 2013
    #7841
    hello po; gamit ko shell helix diesel HX7, 2thou for 6-liters. It's not synthetic but Synthetic Technology motor oil specifically formulated for turbocharged, crdi, egr fitted engines. This oil actively cleans the engine and continues to flow quickly which helps the engine to operate more efficiently and more responsive. Hope this helps, thanks
    May 2009
    #7842
    Question lang po.
    After niyo po makuha ng plate number at LTO sitcker sa CASA, dapat ba palitan rin nila yung CR na naka-indicate na yun plate number?
    Nun nakuha ko kasi yung CR ng innova ko wala pa plate num, so blank yun nandun. Then nun nabigay na yun plate number at sticker, di na pinalitan o inupdate yung CR, so blank parin siya.
    Ganito rin po ba sa inyo?
    TIA.
    Jun 2006
    #7843
    Akala ko abnoy FC ng innova ko same lang pala sa inyo 6-7km/L kasi ako city driving.
    Is it just me, pero pag blaze gamit ko mas malayo layo tinatakbo ng FC.
    Parang mas malayo din inaabot ng blaze sa akin, usually blaze ako pag byahe.
    #7844
    Quote Originally Posted by Simple Rider View Post
    Hello po.
    tanong ko lang kung ano yung spare tire lock niyo? :
    TIA
    yung spare tire lock nabili ko sa concorde, kako ang brand from thailand ata ito nung una hinde ko ma figure out pag kabit kala ko hinde match. nagawan ko rin ng paraan inipit ko yung bracket sa ibabaw ng chasis then isang bolt lang yung nakabit ko. ayoko kasi mag butas sa chasis at baka pagmulan pa ng kalawang. ok na at least mas kapante na ako ngayon na hinde basta masisikwat yung spare tire ko. bago pa naman at hinde pa nagamit nung previous owner.
    #7845
    Quote Originally Posted by n5110 View Post
    i just bought a cheap bicycle chain lock, and installed it in such a way that the bad guy easily sees it as he eyes my spare..
    the more effective theft deterrent is a very visible warning..
    #7846
    Ako dalawa,- Chain at tsaka iyong standard tyre lock....
    21.8K:bike3:
    Jan 2013
    #7847
    ako sir spare tire lock at cover nilagay kong pang secure.. so far ok naman at mas malinis tingnan kse walang naka laylay na kadena..
    Aug 2013
    #7848
    has anyone here have the weathertech AVM cargo mat for their Innova? How's the fit?
    TIA
    Aug 2013
    #7849
    Hello po.
    TIA
    AORTO. Wag mung sundin yung instructions regarding what hole to use. Isukat mo na lang muna bago i-bolt. I found out the hard way.
    Nov 2013
    #7850
    curious lang po ako....anybody knows kung obd II (on-board diagnostic 2) compatible ang Toyota Innova model 2009? If not, what obd tool can we use. planning to buy one for my own use, just in case any trouble or check engine light will arise in the future. noting that the warranty have already expired..thanks
    Sep 2011
    #7851
    Good day mga sir.
    Question lang po sa mga innova owners na nagpa install ng power window. Maganda po ba yong SHARK na brand? Gusto kasing palagyan yong innova ko this month. Nag inquire ako ng OEM brand mas mahal siya at hindi free installation may additional na 3k labor. Sa Shark po free installation na siya.
    Your reply is very much appreciated.
    #7852
    Quote Originally Posted by newlucban1 View Post
    Diagnostic tool for toyota Innova.
    Meron ako nito... I ordered from Hong kong... Na try ko na sa Innova at gumana naman. Standby lang ngayon sa cabinet. hehehehe
    OBD2 is not compatible for our Innova.
    #7853
    ^ma'am, where in hk did you get it? And how much? Thanks
    #7854
    I ordered it online sir.... it's been a year now nakalmiutan ko na
    Nasira kasi ang HDD ng laptop ko... all my bookmarks and important files, nawala lahat.
    Nov 2013
    #7855
    Quote Originally Posted by kristine123 View Post
    eto po ba sa e-bay ? pwede po ba malaman ang complete description, at specification mam ? kasama kung ilan pins ang connector .... thanks
    Aug 2008
    #7856
    Hi Innova gurus, I just want to ask if it's advisable to switch ON the aircon in the 2nd row all the time kahit mag-isa lang ako? i mean to "lessen" the load of the 'primary' aircon?
    #7857
    Quote Originally Posted by crave View Post
    i dont have innova bro, pero IMHO and AFAIK mas okay iyan.
    mahirap yung malamig sa harap tapos mainit sa likod.
    similarly, mas maganda flow ng refrigerant kasi the compressor is designed in a way to handle that load (as far as refrigerant flow) is concern kaya dapat no issue. sa service ko dati ang settings ko mas mataas temp sa likd compared sa harap.
    Jun 2006
    #7858
    Sabi din sa akin ng service advisor na di advisable patayin ang rear ac. Nasisira daw compressor dahil designed ito for dual use. Paminsan minsan pde siguro, pero usually lowest setting na lang.
    #7859
    yes, i believe it is easier on the compressor, because there is less resistance. but the reason i always keep my rear aircon on, is that it cools my cabin faster.
    #7860
    Quote Originally Posted by shibby75 View Post
    i always take a grain of salt, what the SA says. many buyers actually know more about the automobile in general, than the SA...
Toyota Innova Owners & Discussions [continued 3]
