Page 383 of 775 FirstFirst ... 283333373379380381382383384385386387393433483 ... LastLast
Results 7,641 to 7,660 of 15487
    Mar 2012
    #7641
    thanks 1natzt. akala ko kailangan ko ng pumunta ng casa para patingin ito.
    Oct 2013
    #7642
    Hello po .. I have a innova 2012 j... Pwedipo ba papalitan ng pwer windows?
    Oct 2011
    #7643
    pwedeng pwede sir aftermarket power windows.
    Mar 2012
    #7644
    sir Retz, saan magandang mag kabit ng power window? and may idea ka magkano aabutin? may modification bang gagawin? tnx
    #7645
    Quote Originally Posted by C.nova View Post
    in my opinion, the least problematic, more aesthetic, and more long-lasting conversion is the one the casa does. it is more expensive than outhouse, but to me, it is worth it.
    Oct 2009
    #7646
    I have mine done sa CASA way back 2008. Price then was 26k. Didn't have a problem until on the 5th year ( this year) when it suddenly did not work. Since out od warranty na, had this checked sa rapide. Turns out busted fuse lang pala. The complication though is finding it since this won't be part of those in the fuse box. My suggestion to you is have the fuse portion easily accessible for possible replacement later on. Ako, it took 2 hours and almost baklas ng dashboard bago mahanap fuse.
    Jan 2013
    #7647
    hello tsikoters.. may tanong lang ako..
    san ba nakakabili ng sprint booster at reasonable price? meron na ba inyo nagkabit na nito? musta naman yung result after installing it?
    maraming salamat po..
    Jun 2006
    #7648
    Anong sprint booster?
    Mar 2004
    #7649
    Quote Originally Posted by shibby75 View Post
    It's a device you connect to your accelerator. Basically, it makes you think you are going faster by adjusting the setting of the accelerator. Let's assume your accelerator has 1-10 levels. With the Sprint Booster, you can set it to start at 3, so speed 1 becomes 3. The moment you step on accelerator it gives you speed 3 right away. In effect, you lose setting 1 and 2 if you want to go slower. Better to spend your money on a Racechip or similar device.
    Jan 2013
    #7650
    sir.. racechip is for diesel variant.. mine is gas.. what do you recommend for gas variant?
    maraming salamat..
    Jan 2013
    #7651
    basically, it is an electronic throttle controller, sa madaling salita, brand ito ng electronic throttle controller wherein there are settings that makes your car more responsive or better fuel consumption depending on the setting.. afaik it is similar to e-shadow brand..
    Jun 2006
    #7652
    Im using the e shadow that i bought at c34x4 araneta for 5.5k.
    Oct 2011
    #7653
    Quote Originally Posted by ebmosqueda View Post
    Sir hindi ba may fuse box naman talaga ang innova tapos doon na lang ilalagay spare fuse kung sakali may additional electricals na gagawin sa ride mo? bakit may iba pang location ang fuse?
    Oct 2009
    #7654
    Not sure bro but i suppose after market kase siya and not originally installed. That is why you should ask na before hand. Anyway 2013 na baka dunna nilalagay by this time.
    #7655
    what i notice, is that if the installation was done out of the factory, there seems to be variation in work quality. i think this is because a number of these works are done outside the casa, by non-casa workers.. what i do, is to ask some questions, so that i can do some trouble-shooting of my own, justin case... like where the fuses are, where the manual is, where the secret button is...
    May 2013
    #7656
    good morning po fellow Innova owners, meron po ako napansin na parang "grinding" or "rubbing" sound malapit sa front passenger side wheel ng Innova J ko starting yesterday. medyo malala na sya kanina on my way to the office. tumutunog lang po sya when the vehicle is turning left. kapag diretso ang takbo or turning right, walang naman sound na ganun.. highly noticeable kapag sa rotunda yung tunog na parang kumakayod na bakal.. hindi po continous yung tunog, parang something that's revolving is hitting something stationary. kaya ganun po tunog na "krrrrugggg... (less than 1 second walang tunog).. krrrugggg... (less than 1 second silence.. krruggg"... bale parang perfect cycle po sya, pareho yung duration ng may ingay at walang ingay.
    question: saan na shop ko po pwede ipa check ang sasakyan ko? any ideas po kung ano ang probable cause ng ingay?
    sa makati po ang office ko, sa southern side ng Taguig near C5 naman po ang bahay. please recommend your trusted shop para po maipa ayos ko yung sasakyan ko.
    thank you in advance mga kapatid.
    Jun 2006
    #7657
    That could be he wheel bearing. Wag mo na gamitin at me tendency mag lock up yan pag nag overheat. Pde rin matanggal sa gitna ng byahe.
    Pag lumaki pa sira nyan, pati spindle nyan sisirain.
    Aug 2006
    #7658
    Quote Originally Posted by bakaldos View Post
    Stock wheels and tires ba ito?
    Dec 2009
    #7659
    Quote Originally Posted by homhomnova View Post
    maraming salamat..
    Unichip from Speedlab
    Oct 2009
    #7660
    Pa check mo dyan sa rapide taguig near rosewood pointe and pa quote ka. Of course baka mahal price nila kaya tell them balik ka nalang. Ako, after that pumupunta ako sa banawe, sa toyorama, bebenta sila orig toyota parts, dun na din ako nagpapakabit. Eto number # 7120105. Nakapagpapalit nko ng bushing at shocks dyan. Ayoko sa casa kase bukod sa mahal, di naman ka talaga sure kung orig toyota parts ( minsan replacement parts lang).
Toyota Innova Owners & Discussions [continued 3]
