Page 287 of 775 FirstFirst ... 187237277283284285286287288289290291297337387 ... LastLast
Results 5,721 to 5,740 of 15487
    Aug 2010
    #5721
    is it safe to upgrade the headlight bulb to 100/90w?
    naka ceramic plug naba ang headlight ng innova?
    does innova have relay installed for its headlights and horn?
    #5722
    Quote Originally Posted by trucker111 View Post
    its safe once you use a aftermarket Relay wiring kit...the stock relays for the headlights is just rated to the stock wattage of the HL Bulbs.... same goes for the Horn OEM relay...Nope youll have to get ceramic plugs since the oems are just hard plastic... ;)
    Oct 2011
    #5723
    Sirs, anong gamit niyong size ng baterya sa inyong Innova both gas and diesel? 2sm or 3sm?
    Dec 2012
    #5724
    Good day Innova owners. I had my first brand new manual Innova E Diesel last February 2013. I have no problem with everything except that I am bothered if is it normal na mataas talaga ang rev niya? When I maintain yung rpm niya sa 2k, nasa 70kph lang ang speed niya. When I am running at 100kph, nasa almost 3k ang rpm. Running on 120kph, nasa 3,300 na banda ang rpm niya. I can't imagine if I want to try and push it to 140, baka masira na makina ko? Is that normal sa Innova? O meron pinapagawa dito para ma improve siya. I was told Montero sports runs less than 2k rpm maski nasa 150kph na ang speed nito. Though I usually have 13km per liter fuel consumption pag mag sctex ako.
    Feb 2013
    #5725
    1sm lang ata ang innova, mag ask lang ako mga paps, normal ba sa vvti yung parang amoy kaunti ng fuel ang usok nya during cold start?
    #5726
    Quote Originally Posted by siopaonatoasted View Post
    how many years na Innova mo boss?
    Sep 2010
    #5727
    Quote Originally Posted by junrellannt View Post
    Ironic isn't it?, the A/T D4D only has 4 speed and yet at 100kph rpm hovers only at 2000+, the manual has 5 speed yet do the same at 3000rpm hence the engine noise. Also when you reach 80kph for the A/T, you will feel the surge of speed going to 140kph.
    Feb 2013
    #5728
    5 years po, 51k mileage, hindi naman strong yung amoy nya, at saka di sa akin ito before, sanay ako kasi sa diesel. hehehe
    Sep 2010
    #5729
    For the D4D, "D" position is more than sufficient even for steep inclines, however steep downhill, i do use the lower gears for engine braking assist. Use only distilled water, i.e. wilkins for washer fluid. No residues, no clogging. Also use this if you must add water to your coolant, never use tap water to prevent rust formation and deposits or even 'lumot'.
    Dec 2007
    #5730
    Ok lang yung observations mo sa speed against rpm. Ganyan din sa akin. Montero's engine have higher power and torque kaya it can be fitted with higher gear ratios. Ive done 140 kph on my innova and yes maingay na ang makina. D ko na matandaan pero nasa 3.7K rpm na yata. 4300 rpm naman ang redline.
    Mar 2013
    #5731
    Hi newbie here. Just got my innova g d4d. I'm looking for trunk tray beige color? Where can i buy it besides from casa? How about spare tire lock is kaco brand just the same as the one being sold at the casa? Price is quite far. Thanks
    Feb 2013
    #5732
    Ask lang mga papas regarding sideskirts, di kaya mangalawang yung ilalim na part na covered ng sideskirt kapag tumagal kasi siksikan lang ng dumi?
    Jan 2013
    #5733
    Quote Originally Posted by flao_17 View Post
    sir.. palagyan mo na rin spare tire cover aside from the lock.. yung trunk tray marami ka mabibilhan nun sa banawe
    Mar 2013
    #5734
    Thanks. Any shop you can recommend? Is the spare tire lock really safe? Is it rust free? Thanks
    Jan 2012
    #5735
    Quote Originally Posted by fredgimed View Post
    Magkaiba po kasi ang gear ratios ng 5M/T at 4A/T ng innova D4D..also how the D4D A/T engine is tuned. notice the difference in terms of max torque(see technical specs).
    D4D A/T has 260*1600-2400rpm
    D4D M/T has 200*1,400-3,200rpm
    *Max Torque info of Innova D4D A/T and M/T are from toyota motors philippines
    Jan 2013
    #5736
    hello mga ka innova.. tanong lang po.. ano ba ginagawa pagnagpa 5K PMS? Tuwing kelan ba pinapalitan yung spark plugs at ano ba marerecommend nyong oil for every 5K OCI?
    maraming salamat po..
    Oct 2011
    #5737
    Sir, kindly check your manual for the replacement of sparkplugs... for OCI, mineral oil shall suffice the 5k interval.
    Jan 2012
    #5738
    Quote Originally Posted by homhomnova View Post
    AFAIK every 40K kms ang palit ng spark plugs as per users manual, pero CASA advise to replace it every 10K PMS. for 5K OCI, you can stick to TGMO
    Jan 2013
    #5739
    Quote Originally Posted by markduguran View Post
    maraming salamat sir.. tsaka ano ba difference ng regular mineral oil sa semi-synthethic in terms of performance?
    Jan 2012
    #5740
    On regular use, halos wala naman yan difference in terms of performance. but when subjected to extreme conditions (e.g. long drives, high revs, etc etc) dun may advantage ang semi-synthetic and fully synthetic oils. Not much on performance but more on engine protection.
Toyota Innova Owners & Discussions [continued 3]
