Page 353 of 775 FirstFirst ... 253303343349350351352353354355356357363403453 ... LastLast
Results 7,041 to 7,060 of 15487
    Oct 2011
    #7041
    Sir, maybe you are referring to race chip. I think it is price at 20k approx.
    Jan 2013
    #7042
    not sure pero iba pa yata ito dun sa tinutukoy ko sir..
    pero kung sakaling ito man yun.. di bale na lang.. masyado palang mahal..
    maraming salamat..
    Jun 2006
    #7043
    Elctronic throttle controller tawag don, 5k bili ko. Meron sa sulit
    Dec 2007
    #7044
    Pang diesel ang racechip.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    Jul 2013
    #7045
    Tanong lng mga ka-innova? Regarding wifer blower reservoir(tama ba term ko). Di ko kasi mkita ung laman ng reservoir kung konti na lng, ung tip lng ng reservoir ung visible eh. Ganu ba kadami dapat laman nun? Pede bang distilled water n lng i-refill ko. TIA
    Jul 2011
    #7046
    sir sa pagitan ng air filter at ng condenser/radiator yung coolant reservoir na transparent, kulay lagi ng coolant PINK pag toyota.
    back read ka sir may nag-post with pic nito.
    may marked "L" (low), "F"(full), at "B"(boil?bleed? ewan ko)
    Oct 2011
    #7047
    Quote Originally Posted by ero124 View Post
    ung sa wiper reservoir meron siyang cap sa loob, you pull it and there's a chain like plastic and may marking nandun low and normal.
    Aug 2006
    #7048
    Windshield washer fluid reservoir tawag dyan, wala siyang overfill, puede mong punuin and yes puede distilled water or mineral water, meron din nabibili na pre-mixed solution sa Toyota or any auto supply.
    Jul 2013
    #7049
    Tnx po sa mga reply. Un kasing sakin buhat takip hanggang sa parang leeg lng ang kita, nakatago ung pinaka body talaga na lalagyan. 2013 model po ung sakin, try ko po tangalin ung takip baka may mkita ako parang chain na sisasabi ni sir retz.
    Jun 2006
    #7050
    Unless nakaligtaan ilagay yung parang plastic chain na yon, bka di mo lang napansin, me naiiwan kasi sa gitna pagtanggal mo ng cover, pull it out, kasama chain don.
    Jul 2013
    #7051
    Wala po talaga chain eh, kahit ung pnagkakabitan ng chain sa takip wala din ako nkita even markings sa sinasabi ko na leeg ng reservoir wala din. Wala na kasi ako nakikita fluid pero may lumalabas namn pag press ko ng blower. Oc-oc lng. Punuin ko n lng siguro.
    #7052
    Quote Originally Posted by siopaonatoasted View Post
    Dalawa ng fuel filter ng innova, isa sa tank, isa dun sa engine bay. YUng sa engine bay ang pinapalitan. Yung sa tank, nililinisan lang.
    Mahal ang fuel filter ng innova sa may engine bay, around 2.5k, I think around 40k km bago magpalit.
    40k km bago palitan? mine is 80k na... di ko pa napapalitan dapat kaya papalitan ito?
    #7053
    Guys, Share ko lang ano ang na read ng MOBD tools ko sa techstream.
    No trouble codes naman ang lumabas...
    INNOVA/KIJANG INNOVA TGN 1TRFE
    2013-07-24 05:05:07 PM
    [Engine and ECT Stored] System
    [Parameter] [Value] [Unit]
    Vehicle Speed 0 km/h
    Engine Speed 687 rpm
    Calculate Load 19.6 %
    MAF 2.68 gm/sec
    Atmosphere Pressure 103 kPa(abs)
    Coolant Temp 89 C
    Intake Air 55 C
    Engine Run Time 40 s
    Initial Engine Coolant Temp 95.0 C
    Initial Intake Air Temp 59.3 C
    Battery Voltage 13.2 V
    Accel Sens. No.1 Volt % 15.6 %
    Accel Sens. No.2 Volt % 31.7 %
    Throttle Sensor Volt % 15.2 %
    Throttl Sensor #2 Volt % 47.0 %
    Throttle Idle Position ON
    Throttle Require Position 0.7 V
    Throttle Sensor Position 0.0 %
    Throttle Position No.1 0.7 V
    Throttle Position No.2 2.3 V
    Throttle Position Command 0.7 V
    Throttle Sens Open Pos #1 0.9 V
    Throttle Sens Open Pos #2 2.0 V
    Throttle Motor Current 0.7 A
    Throttle Motor DUTY 15.2 %
    Throttle Motor Duty (Open) 0 %
    Throttle Motor Duty (Close) 15 %
    Throttle Fully Close Learn 0.6 V
    Injector (Port) 2.30 ms
    Injection Volum (Cylinder1) 0.106 ml
    Fuel Pump/Speed Status ON
    Evap Purge Flow 0.0 %
    Purge Density Learn Value 0.000
    EVAP Purge VSV OFF
    Target Air-Fuel Ratio 1.000
    O2S B1S1 0.05 V
    Short FT #1 7.0 %
    Long FT #1 -7.9 %
    Fuel System Status #1 CL
    O2FT B1S1 7.031 %
    IGN Advance 6.5 deg
    Knock Feedback Value -3.0 deg
    (CA)
    Knock Correct Learn Value 16.0 deg
    (CA)
    Starter Signal OFF
    Power Steering Signal OFF
    Power Steer. Sig. Record ON
    Neutral Position SW Signal ON
    Stop Light Switch OFF
    A/C Signal OFF
    Closed Throttle Position SW ON
    Electrical Load Signal OFF
    # Codes(Include History) 0
    Time after DTC Cleared 2190 min
    Distance from DTC Cleared 370 km
    Warmup Cycle Cleared DTC 22
    TC and TE1 OFF
    ACT VSV ON
    Idle Fuel Cut OFF
    FC TAU OFF
    SPD (NC0) 650 rpm
    SPD (SP2) 0 km/h
    Shift SW Status (R Range) OFF
    Shift SW Status (2 Range) OFF
    Shift SW Status (L Range) OFF
    Shift SW Status (3 Range) OFF
    A/T Oil Temperature 3 81.8 C
    Lock Up Solenoid Status OFF
    Shift Status 1st
    SLT Solenoid Status ON
    May problema kaya ang MAF ko? bat wala akong makitang OS sensor at mga cylinder?
    Jan 2013
    #7054
    Quote Originally Posted by shibby75 View Post
    ayun.. tama ka sir.. galing mo..
    hindi ba ma void warranty pagnagpakabit nun at san reputable shop nagkakabit nun? di kaya ng skillset ko yun kung DIY..
    maraming salamat sir..
    Oct 2011
    #7055
    Meron dapat yan sir or not unless tinangal ung cap like chain. Dun mo makikita washer fluid level.
    Oct 2011
    #7056
    Mahal ng fuel filter for vvti compared to d4d na element lang. Pero mas dapat palitan ang fuel filter ng d4d sa dumi ng diesel natin.
    Jun 2006
    #7057
    Quote Originally Posted by homhomnova View Post
    Kinabit ko din sa akin nung under warranty pa, pag magpa service ako, tinatanggal ko. Bypass plug lang sya sa throttle. Madaling gawin.
    #7058
    mine is a diesel. and if i remember right, the 2.5K included the entire assembly of filter and housing. the filter element alone costs a lot less..
    i bought the entire assembly because na-inis nako when the warning light refused to go out even after i replaced the filter and pumped the etc etc etc..
    #7059
    yes, i like this contraption. it beats guess-timating the actual level. i even used to pentelpen the recommended level marks in older models..
    Oct 2011
    #7060
    Quote Originally Posted by kristine123 View Post
    Palitan mo na sir nasa pms yan pag palit ng vvti fuel filter mo.
Toyota Innova Owners & Discussions [continued 3]
