wala bang peke na techstream?
na-intriga tuloy ako para bumili.
kung may thermometer kayo, yung ambient temp ng saken mataas ng 1-2 deg C sa MID.
What brand of battery are you using? I used Gold Motolite but after 1 year, it gave up. Can anyone suggest a better replacement?
1 year? it might be a defective unit. it might still be under warranty. bring it back to the store. you might be in for a brand new replacement..
another possitility is, your charging system is defective. my innova's alternator developed a bearing failure; my battery died due to under-charging. curiously, the idiot warning light didn't light up... alas, the battery warranty does not hold up for alternator problems.. but if this is the case, then all your gold needs is a charge..
I'm surprise that the battery indicator didn't show-up given that the alternator is having problem. It will also produce an unusual noise if the bearing or the pulley is the culprit.
sa sobrang lobat pati yung battery indicator di ma-supply ng kuryente hehehe
I was driving this afternoon just along quirino ave just after turning right from Osmena BLVd (southexpressway ), and drove through a not so deep flooded area. A few meters away after, I noticed the Innova ( G) could not accelerate and can only drive forward at around 10 kph and barely tackled Nagtahan bridge. Could this be that the computer got wet or a clutch problem?
