Page 303 of 775 FirstFirst ... 203253293299300301302303304305306307313353403 ... LastLast
Results 6,041 to 6,060 of 15487
    Jul 2010
    #6041
    Quote Originally Posted by Capsaul View Post
    kahapon sinabay ko sa pms yung pag palagay ng 3m tint sa sa whole windshield 3M magic black.... for Php 2300... napamahal yata. harap lahg yun. Php 9700
    pag buong innova tint. Talaga bang visible yung 3M mark? sakto pa naman sya sa eye level ko, parang distracting sakin.
    pwede po sir matanggal. rub the 3M mark gently with a cotton na may konting rubbing alcohol.
    I had mine tinted last March 27 sa Team Car Center (732-3647), Banawe st. cor P. Florentino. 3M Magic Black Full
    Windshield/1pc for P1800. After 5 days, went back for 3M Medium Black 8in. Visor ( P380).
    #6042
    Quote Originally Posted by kristine123 View Post
    hirap kasi mag paayos kung hindi sure exactly... baka pina overhaul mo na yun pala nanginginig pa rin.
    Pero Sometimes.... wala akong naramdaman vibration... pero paminsan lang....
    Minsan parang konting apak mo lang sa Gas magaan syang tumakbo... sometimes parang mabigat.... Di ko ma gets....
    Mahal ko pa Innova... prang yoko pa ibenta. kasi wala akong maisip anong ipapalit.
    Mam A/T po ba? When you put it in D mode while brake is pressed nagkaka vibration po ba? Bumabagsak po ba bigla ang RPM? If yes, the servo needs to be cleaned.. normal po kase is when you put it in D, your RPM goes up a bit then goes back to normal, but if it drops instead of going up, servo is usually the culprit.. This is just based on the vehicles we have serviced, especially with VVT-i nga po, a friend of mine visited us complaining that when he puts it in D, it vibrates, you can see the plate number vibrating, when in Idle may konting vibration narin kagad then mawawala pag nag automatic ang aircon. We just cleaned the servo, usually takes an hour. After non nawala na po.
    Also you might want to have your engine supports checked. konting crack lang po magkaka vibration narin lalo na sa idle palang nararamdaman nyo na.
    #6043
    Quote Originally Posted by 1natzt View Post
    nag order po ako ng fuel pump, update ko po kayo kung may effect yung replacement sa vibration problem. wala kasing balancer yung 1tr-fe ng innova, di tulad ng sa fortuner na dalawa yung balancer kaya dindi maingay at walang vibration kahit yung first version pa.
    di ko rin po ibebenta yung sa akin. compared to other gas-fed mpv, innova is the best sa experience ko.
    bakit ka po nagpalit ng fuel pump sir? may problema po ba? magkano po damage dyan?
    Quote Originally Posted by imogen View Post
    yes sir medyo may tama ka na bumabagsak RPM konti pag D mode then makikita mo plate number na may vibration.
    mahal po ba magpalinis ng servo sir? dami po bang trabaho?
    Ano po pala ang servo sir? saan parte ito?
    Innova din ba inayos nyo sir?
    Thanks you sa tips sir...
    Apr 2013
    #6044
    Quote Originally Posted by timo07 View Post
    Dapat alam yan ng lahat ng dealer kasi naging common problem yan before. Nangyari sa innova ko at inayos nila under warranty. Bushing lang yung ilalagay.
    salamat po Sir, anong year model po ng Innova ninyo? Thanks again sa mga ngbigay ng feedback.
    Jan 2010
    #6045
    Quote Originally Posted by homhomnova View Post
    sir.. I suspect yung mga clips ng air filter mo yan.. nagkaganyan din sakin dati.. akala ko coins o kung ano na nakalagay dun sa compartment sa dashboard.. nung una tinanggal ko lahat ng nakalagay sa compartment sa dashboard pati na dun sa compartment sa gitna ng upuan sa harap.. as in empty lahat.. pero meron pa rin.. tapos nung magpa 1k pms ako hindi ko muna sinabi sa SA ko kse ayaw ko muna ipagalaw kse duda ako sa tunog tsaka baka kung ano ano ang kalikutin ng mga yun..
    tapos nung pauwi na ako nagulat ako nawala na yung tunog.. so ang assumption ko andun sa engine bay naggagaling yung tunog.. so out of curiosity tiningnan ko ngayon dun sa engine bay kung ano ang possible na cause ng tunog.. eh nung nagpa 1K pms ako wala naman iba ginawa kundi change oil, check air filter, check brakes.. kaya naisipan ko i unlock yung mga clips ng air filter.. ayun lumabas ulit yung tunog tapos nung binalik ko nawala ulit.. so my conclusion ay yun na yung cause nun at ngayon wala na ako naririnig na kahit anong tumutunog..
    yun lang.. sana makatulong..
    homhom thank you, nabasa ko reply mo i was skeptic na dun nanggaling pero kanina tiningnan ko yung clips ng air filter surprised ako at yung isa sa tatlong clip eh hindi naka fasten sabi ko sa sarili ko tama ka nga, i clipped it right away pero wala pang gala kaya di ko pa nailabas para ma test kung nawala na nga yung rattiling sound... Thanks bro.
    Jan 2010
    #6046
    after 3 years madami ng dents, scratches (from claws ng pusa), water marks ang innova ko, now im scouting for detailer... ask ko lang sa zeibart ba nag aayos ng dents? may ma recommend ba kayo na iba im from cavite area.... thanks
    Jul 2011
    #6047
    try nio sir sa Pinoydetailing.com madami silang alam na detailers.
    may ka-innova tayo dito nag-detail. si sir ginnova yata? not sure.
    Apr 2013
    #6048
    mga bossing, ano magandang gawin pag ginagawang boarding house ng mga daga ang engine ng sasakyan? dami na nilang nakatkat na wiring.thnx tnx in advance
    #6049
    Bakit bro.,- hindi mo ba ginagamit ang Innova mo?
    Pa-engine wash mo muna para mawala ang amoy ng mga daga at mawala ang mga tirang pagkain et al....Iyan kasi ang normal na pinagmumulan ng pagpunta nila riyan.... Dapat ay hindi na sila babalik diyan,- unless naaamoy pa nila ang kanilang amoy sa Innova mo.... Territorial din kasi ang mga iyan....
    18.9K:smooch:
    #6050
    Sir share ko lang with regards sa airfilter ng innova natin, last week may naririnig akong tunog sa innova ko lalo na pag naka idle ako, then pinatingnan ko sa kilala kong mechanic at nung buksan nyan may play iyung airfilter dahil yung rubber eh nag shrink na at di na lapat, bumili nalang ako ng new air filter (Purolator premium plus) ayon nawala na tunog. maganda kaya itong Purolator airfilter?
    Apr 2013
    #6051
    18.9K:smooch:
    ginagamit din araw araw din pero hindi nakaka 10km/day. lagi kong pinapa engine wash, pero wa epek, balik din sila. hindi kasi sementado ang labas ng gate namin dito. salamat sa reply sir
    Jul 2011
    #6052
    the electronic repellent is one solution, it is very effective and witnessed how mice run wildly just to get out of the range of the repellent (unfortunately we dont own one the incident happened in a carinderia in my collegw days). idk if this is still available locally.
    moth balls on the engine bay.
    #6053
    available pa ito sa Citi-hardware dito sa province... sure meron dyan. (electronic).
    delikado ang engine wire dyan... ang mahal pa naman ng mga ito pag papalitan.
    bili ka ng RACUMIN... lagay mo sa baba ng Engine.. for 1 week... at lagyan mo na rin moth balls malapit sa engine.
    for sure ubos yan sila lahat... wag lang sana aso at pusa ang makakain ng racumin.
    Apr 2013
    #6054
    thanks sa inyo, definitely do that. nakatkat na nila wiring ng left headlamp ko. hindi gumagana kung hindi ko pa ibagsak ang trunk. kahit yung plastic na ibinalot sa bundle ng wire hindi pinalampas. thanks thanks mga bossing
    Apr 2013
    #6055
    Quote Originally Posted by MrQ5 View Post
    Apr 2013
    #6056
    i mean the "hood", not the trunk.
    #6057
    Quote Originally Posted by nur_demha View Post
    mukha yatang kagagaling lang ng factory auto electrician sa canteen bago niya kinutingting yung headlight wiring mo..
    #6058
    natanong nato dati. ang mga natatandaan kong suggestions:
    1. keep the hood open.
    2. get an electronic rat repeller.
    3. dora rat killer.
    4. get a cat.
    Apr 2012
    #6059
    Good day po sa lahat at thanks in advance...
    pina engine wash ko pom ung innova namin last 2 weeks then sabi po nung pinsan ko na nagdrive nung innova ay para daw pong mejo navibrate or nanginginig now pag natakbo...
    ano po kaya pede ngyari? may mga dapat po bang ingatan once na nag papa engine wash?
    maraming salamat po...
    Dec 2007
    #6060
    Huwag ka papa engine wash. Ipadetail mo engine mo. May mga nabasa ako mga shops na nagdedetail ng makina without using pressure washers.
Toyota Innova Owners & Discussions [continued 3]
