Page 351 of 775 FirstFirst ... 251301341347348349350351352353354355361401451 ... LastLast
Results 7,001 to 7,020 of 15487
    Oct 2011
    #7001
    It already exceeded the +/-10% tolerance as i pointed out earlier.
    Dec 2007
    #7002
    but do not forget the tire manufacturer's inputs..
    "overinflating" may seem good to the user, but it actually predisposes to "oblong-ing". +/- 10% is usually a good safety range..
    What I'm saying is it can based on personal preference coupled with what jhnkvn pointed out as knowing the pros and con. This can be done by observing how your car behaves and handles, and over the long run the effect on your tires. My experience with underinflation is that it can really improve ride comfort but does affect steering, bumibigat ang manibela. For me, I stay very close to what toyota recommends. I can live with the ride quality, provides for better steering wheel handling and probably extends the life of the tires.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    May 2007
    #7003
    Ano ba ang maaaring problema kung parang ayaw humatak yung innova? Kaka tune up ko lang naman last march. Does this have something to do with the clutch assembly?
    #7004
    Quote Originally Posted by timo07 View Post
    Plus the fact na kapag malambot ang pressure ng gulong lalo na sa unahan,- and your drive is high speed curves,- mabilis mapudpod ang gulong sa unahan.... My experience, so I keep them on the high side of the recommended tyre pressure
    20.1K:sumo:
    Jul 2011
    #7005
    idagdag ko na din ang stress of its shape memory of rubber from under inflating for long rides, its ok for short distance travel.
    pero rides nila ito at ang gusto nila mas ok ang comfort over the life of tyres. routine check na lang lagi sa sidewall.
    Feb 2013
    #7006
    Quote Originally Posted by hops View Post
    Pwede spark plug, fuel you used (yan ang pangit sa gas engine ang damit klase na fuel), fuel filter, or baka clutch lining na.
    Jan 2013
    #7007
    hello mga ka innova.. share ko lang..
    natutuwa ako sa nilagay kong engine under cover.. these past several days ay laging maulan at maputik sa kalsada.. dahil sa engine under cover protected yung ilalim ng makina ng innova ko.. tiningnan ko kanina nung maghugas ako.. malinis pa rin at wala ni isang tilamsik ng putik.. ang hirap pa naman linisin ng ilalim ng makina lalo na yung mga singit singit..
    yun lang..
    Jan 2013
    #7008
    sir.. kung mataas na ang rpm at ayaw humatak.. sliding na clutch nyan..
    Feb 2013
    #7009
    Quote Originally Posted by homhomnova View Post
    yun lang..
    Pics naman sa engine cover.
    #7010
    Quote Originally Posted by siopaonatoasted View Post
    sa ganitong problema sir? nakikita ba yan sa mobd computer tools natin?
    tumatakbo pala sa windows 8 ang software ng techstream sir.
    Feb 2013
    #7011
    Yup kita mga ganyan na problema, wala ako windows 8, pero kung 32 bit yan, tatakbo yan.
    Aug 2006
    #7012
    VVTi ba? If yes,
    It can be.
    1. visually check the rocker arms by opening the valve cover - nangyari na sa akin yan nahulog ang isang rocker arm, medyo complicated and pagbalik ng rocker arm but doable by your suking mekaniko. Yung VVTi hindi na po nakatuhog na parang barbecue ang mga rocker arms, kundi nakaipit lang sa overhead cams kaya may tendency na madisplaced gaya ng nangyari sa akin.
    2. Sliding clutch.
    Aug 2006
    #7013
    Sa tire pressure , do not under inflate it will wear out your outer tire corners, pag under inflate ang sumasayad sa lupa ay yung mga kanto at yung gitna less pressure na halos naka angat sa lupa.
    Reminder lang po sa mga rezing rezing dyan
    Stock Yokohama is 94S rating meaning Load Index is=670Kilos and Maximum Speed=180KPH
    If you want a better performance and higher speed rating find tires the have H and V ratings.
    #7014
    Quote Originally Posted by Mile2 View Post
    Visible ba ito sa goma?
    Oct 2011
    #7015
    Speed rating has markings indicated the in the tyre.
    Aug 2006
    #7016
    Yes, all tires has this ratings marked on the sidewalls aside from Manufacturing date, min/max PSI pressure.
    Meron akong nakita na Indonesian Tire brand (Delium) 94H rating meaning 210KPH max speed at may Mags lip protector pa *P3,000/piece
    Meron din Indonesian brand (Gajah Tunggal) GTX65 na 94V rating meaning 240KPH max speed, di ko pa alam price probably around less than 4K/piece - price guess lang
    Meron ba dito na naka Gajah Tunggal GTX65 tires? pa share naman ng price at review.
    Jan 2010
    #7017
    after 4 yrs, all stock pa din innova ko. sa lahat ng mod na pwede gawin, yung retractable or fixed headlight washer ang pinaka gusto kong ipa mod sa innova ko.saan may nagkakabit nito?
    #7018
    Hi guys, any recommendation sa spark plug? gusto ko kasi mag palit ngayon. May spark plug ba na nagpapaganda ng FC? VVTI
    Feb 2013
    #7019
    Quote Originally Posted by kristine123 View Post
    Go for iridium spark plug, papagandahin ang hatak ng innova mo therefore helping to reduce your fuel consumption.
    Apr 2009
    #7020
    Hello mga sir. Tanong ko lang regarding pms. Malapit na kasi mag 15k yung odo ko peron yung last pms ko is last feb pa (10k). Usually ano po ba sinusunod nyo sa pms? Every 5km na takbo or every 3 months? Or which ever comes first? Sa case ko kasi 5 months na since my last pms. Sinunod ko kasi yung ever 5km. D4D a/t po pala unit ko at mineral oil yung gamit ko. Thanks!
Toyota Innova Owners & Discussions [continued 3]
