sa A/T, hangan 2K rpm lang.... at 80KPH mag shift gear un dun na umpisa ang arangkada sir.![]()
Anyway kahit ano pa sabihin nila, and kahit pa VVTI yung nabili naming, still mas gusto ko agn diesel engine, di lang dahil sa matipid ito, kundi dahil dun sa energy per drop ng fuel at dun na nga rin sa torque.
Yap, patay arangkada ng vvti, thats why i bought an electronic throttle controller, lumakas naman pickup lalo na kung sagad ang sports setting.
Di ba electronically controlled naman talaga ang throttle ng VVTI at kahit ng D4D? May delay pa nga huweehehe...
Budget ko guys is 1.1M. Naka captains chair na pala yung V. Ano pinagkaiba nya sa G? V ba ang top of the line then G sunod? Baka gasoline VVTI nalang siguro kunin namin. 2.0 ba makina? Same as altis?
2010 Innova Gas A/T Average consumption. Provincial road wich was not tipid mode,very light traffic, automatic fill and refill petron gas station. Total distance 108, consumed almost 10Liters of gas. 11Kilometers per Liter. Sa Makati Ortigas Traffic is around 6-7 Kilometer per Liter. Only problem was leaky shock which is a known problem sa innova but it was fixed under warranty. Sa mga DIY PMS kasi madali lang naman maintenance ng Innova Gas especially pag out of warranty na. 40K PMS 5.6Liters Motor Oil, 3Liters yong Rear differential Toyota GL5, 2.5Liters naman ang ATF Toyota Type IV and spark plugs iridium para good for 100k Kilomters, and air filter, cabin filter from Toyota Parts.
*siopao
The throttle controller removes the delay when put into sports mode, when in eco mode , it increases the delay. Mwehehe
Btw nasiraan na din ako nyan shock, costs 900p orig sa toyota.
Cons are higher gas consumption at sportsmode, heres what it look like
By the way. Just would like to ask.
Yun kasing coolant reservoir ko below na dun sa required level.
Meron pa naman natira,
does it mean yun loob ng radiator ko puno siya ng laman?
What can i do para maibalik sa normal level yun reservoir?
distilled water will do na ba?
or coolant pa din dapat?
Guys, mas ok ba yung diesel engine kaysa gasoline engine? For family lang naman gagamitin ito. Pang araw araw.
