Page 289 of 775 FirstFirst ... 189239279285286287288289290291292293299339389 ... LastLast
Results 5,761 to 5,780 of 15487
    Feb 2011
    #5761
    yung 3k RPM sa M/T diesel, around 120kph yun, sa matic 3k RPM 160kph. :D
    Feb 2013
    #5762
    Iba ata mga sir ang gear ratio sa differential ng gas at ng diesel Innova, pero very slight ang difference.
    Mga sir, ask lang ako, normal ba sa VVTi na kahit wag ka mag gas pedal, kapag nilagay mo sa 1st gear or reverse yung shifter eh gagalaw ang sasakyan and gaining speed also?
    #5763
    Quote Originally Posted by siopaonatoasted View Post
    maraming sasakyan, kapag cuidado kang mag-release ng clutch, ay gagalaw na sa 1st gear at hindi mag-i-istall.
    may mga diesel nga, kahit sa 2nd gear puede..
    engines have good low end torque.
    Oct 2011
    #5764
    just give it a slight gas/push at gagalaw na yan.
    Aug 2010
    #5765
    how do you drive your innova diesel d4d mt from full stop... 1st gear or 2nd gear?
    Mar 2013
    #5766
    Hi innova owners..been having trouble with my 06 innova's aircon.... The rubber seals always leak..seems the condenser does not cool the refrigerant well....any of you guys tried or successfully installed an auxiliary fan?
    Feb 2013
    #5767
    Gas yung sa akin, pero I would suggest always use the first gear from full stop. Kahit sa hanging na areas kapag naipit sa traffic, di na ako umaapak sa gas, yung clutch at yung idling lang enough na hehehe...
    May 2005
    #5768
    Quote Originally Posted by trucker111 View Post
    We have two drivers. One of them always start with 2nd gear. The other one always uses 1st gear. 2nd gear seems to accelerate better from stop. I don't know.
    Isn't that riding the clutch ?
    Oct 2011
    #5769
    when driving a manual tranny, much better full stop at first gear pag hindi full stop as in slight acceleration pa then 2nd gear.
    Aug 2010
    #5770
    pansin ko rin maraming driver 2nd gear agad coming from full stop. i'm referring to diesel fed engine.
    Aug 2010
    #5771
    i guess this is the ideal.
    #5772
    Baka nasanay sa elf truck? Ang reverse kasi nun nasa unahan. Masisira tranny niyan. Yung nagaapply din na driver ng dad ko dati nung pinatest drive siya lagi siyang nagse2nd gear. Ayun pinababa tapos ako pinagdrive. Hahaha
    Nov 2007
    #5773
    diesel sa akin and matic. pero same thing ang experience ko. paglagay sa drive, aabante na syang dahan dahan. or pag reverse, aatras na nang kusa. so pag trapik at mabagal talaga andar, preno na lang aalalayan sabay neutral pag stop. feeling ko parang may effect sa transmission pag naka "drive" tapos full stop nang matagal.
    #5774
    Quote Originally Posted by intellution View Post
    err.. what rubber seals are we talking about? baka hindi lang naka-shoot yung condensate drain hose?
    i have had no un-fixable problem whatsoever with my innovas' aircons..
    Nov 2007
    #5775
    Innova-tors, i noticed that the innova's paint is very easily scratched. i had my Inno paint protected at BigBert's but i'm not sure if it made a difference. i'm hoping its not the paint thats getting scratched but only the top coat or the protection applied at BBerts. anybody noticed this with your own rides/paint?
    #5776
    feeling ko parang may effect sa transmission pag naka "drive" tapos full stop nang matagal.[/QUOTE]
    meron nga.. increased wear and tear on the trans, engine, and the brakes... the experts recommend shifting to neutral when stopping for a "long" time.
    #5777
    Quote Originally Posted by axrockster View Post
    in my opinion, the innova paint is just as scratchable as the other cars'... but because the innova is bigger than the ordinary sedan, it does tend to get scratched more often than smaller cars... bigger target... more bulls-eyes..
    #5778
    What color is your Innova, bro? Is it black? If it is, then you should resign to your fate....
    Wala nang lalambot pa sa pintura ng Honda (mas lalo na nga sa black color),- mavtvt*n mo lang,- gasgas na...
    18.6K:grin2:
    #5779
    18.6K:grin2:
    Kaya dapat pearl white mica ang Innova :naughty2:
    Oct 2011
    #5780
    Sir, ganyan naman talaga ang matic nasa drive gear na kasi kaya aabante yan ng kusa without stepping the gas pedal.
Toyota Innova Owners & Discussions [continued 3]
