Have you encountered during driving and the optitron suddenly blinks or flashes instantaneuously?
Thanks for the reply dr. D. Kapag nawawala lamig sa aircon ko,at pinapagawa ko..usually,nag leak ang freon sa seals...i guess those are rubber seals sealing the hose(aluminum) and the evaporator...had it fixed with denso and same problem occurs, under warranty naman sya pero just want to see if others have the same problem..hinala ko its either my condenser is not cooling the freon well or the engine fan is not being efficient...you may have another opinion
well, a leak can occur practically anywhere in our aircon system.. the aluminum tubes, the rubber hoses, the evaporator and condenser coils both front and rear, even the compressor!
inefficiency of the engine fan or the condenser will not cause you to lose freon.. it has to be a leak, and from what i can gather from your narration, wherever that leak is, they still haven't discovered it...
btw, how old is your innova?
Parang delayed talaga if you compare it to manual.
As to starting with 2nd gear from full stop, sa sobrang lakas ng diesel engines, kaya mag start from full stop And 1st gear ginagamit lang pag sobrang steep ng incline ng road or super heavy ang karga. Thats the mentality of traditional truck or jeepney drivers which makes sense imho. I tried this on my bro's Strada, and indeed kayang kaya kahit 4pax resulting to faster accelleration compared to if starting from 1st gear.
wag kayu magaglit sakin sir , nagpapa liwanag lang po ako :sweat:
peru kahit na malakas siya, yan din ang dahilan sakin ng iba "malakas naman daw at kaya naman" tas tinatanung ko kung para san pa kako yung 1st gear at ang sabi naman " para sa ahunan lang daw yun " , kaya nga po tayu kasi may 1st gear para dun tayu mag simula , pwersado kasi ang clutch nun sa segunda kahit kaya naman ng sasakyan .nakaka awa yung makina . pwede naman sa 2nd gear kahit usad langgam wag lang talaga as in full stop tapos 2nd gear ang ipang aarangkada.
kahit sa mga jeep ko kapag ginamit ko minsan,1st gear ang pinang aarangkada ko![]()
mga bro baka may naghahanap dito ng brand new innova, madami kaming promo sa innova ngayon, big discounts din, ayun, PM nyo na lang ako if ever may magtatanong, thanks. :D
