^^^ Yup,- just drop it bro.,- that's the proper way...
17.5K:bruce_lee:
17.5K:bruce_lee:
Guys,
Normal ba na medyo mataas ang RPM at mas maingay ang idle after ng cold start?
^^^ Yes it is,- as the ECU is expediting to achieve the optimum operating temperature of the engine....
17.5K:bruce_lee:
Hi guys, meron bang nakakaalam sa inyo ng "Payload Capacity" ng Innova (E or G specifically)? TIA
^^^ Technical Specifications: Toyota Innova 2.5 G1 - CarWale
Around 700Kg bro., (gross weight-curb weight)
17.5K:bruce_lee:
question lang po regarding tire size question sa innova natin, may mga nakikita kasi ako nag lalagay ng 205/70r15 instead of the 205/65r15 na stock size, mas mataas sya tignan compare sa stock size, mas ok po kaya ganito size na gulong? may benefits po kaya?
Technical Specifications: Toyota Innova 2012 2.5 GX 8 STR BS-IV - CarWale
With reference to the aboves specs,- around 625Kg, bro... Gross weight less Curb weight.
17.5K:bruce_lee:
gross weight - curb weight = payload.
curb weight is the weight of the car when empty.
gross weight is the total weight of the car, including the maximum load it is designed to carry.
payload is the weight of the load into the car.
i'm sorry, but i left my manual at home. but the actual numbers should be easily available in the internet..
Thank you sir, pero di ko makita sa internet. I'll just do the formula that you gave nalang. Pinuntahan ko yung isang dealer dito sa amin and asked the same question, sabi 1000kg daw ang payload ng auv nila. we're considering kasi getting an Innova next year ang use it for family and business na din. just making sure na hindi ko ma-overload ang sasakyan. again, thank you!
Base sa website na ito....Technical Specifications: Toyota Innova 2.5 G1 - CarWale, ang gross weight ay 2290Kg at ang curb weight ay 1585Kg, and so ang payload ay 705Kg.....
(I was posting this yesterday, but was given a note that the Moderators have to review the post before it is posted here...)
17.5K:bruce_lee:
Bakit ako hindi makapag-post dito (kung may reference sa website)???
Kailangan pa raw i-review at i-approve ng moderator...
Innova Diesel:
Payload is about 705Kg.... gross weight=2290Kg; curb weight=1585Kg.Innova 2.5 G1 Technical Specs
Dimensions and Weights
Overall Length (mm) 4555
Overall Width (mm) 1770
Overall Height (mm) 1755
Wheel Base (mm) 2750
Ground Clearance (mm) 176
Front Track (mm) 1510
Rear Track (mm) 1510
Kerb Weight (kg) 1585
Gross Vehicle Weight (kg) 2290
No of Doors 5
Fuel Economy
Mileage Highway (km/liter) 14
Mileage City (km/liter) 10.6
Mileage Overall (km/liter) 11.28
Capacities
Seating Capacity (person) 8
Fuel Tank Capacity (liter) 55
Performance
Maximum Speed Km/Hour
0-100kmph 16.37seconds
1/4 Mile 20.5seconds
Engine
Engine Type/Model 2.5 Liter, 4-cylinder, 16 valve, DOHC, Turbo
Displacement cc 2494
Power (PS*rpm) 102PS *5600rpm
Torque (Nm*rpm) 200Nm *1400rpm
Valve Mechanism DOHC
Bore (mm)
Stroke (mm)
Compression Ratio :1
No of Cylinders (cylinder) 4
Cylinder Configuration In-line
Valves per Cylinder (value) 4
Fuel Type Diesel
Fuel System Common Rail
Transmission
Transmission Type Manual
Gears/Speeds 5Gears
Clutch Type
Final Reduction Gear Ratio
Suspensions
Front Suspension Independent, Coil Spring, Double Wishbone, with Stabilizer
Rear Suspension 4-link, Coil Springs
Steering
Steering Type
Power Assisted Standard
Minimum Turning Radius (meter) 5.4
Brakes
Front Brakes Ventilated Disc
Rear Brakes Leading-trailing Drum
Wheels and Tyres
Wheel Type Tubeless tyres
Wheel Size 15 inch
Tyres 205/65 R 15
17.5K:bruce_lee:
Question: How often do you check and inflate your tires? am noticing every other day, bumibigay steering wheel ko so every other day ako ng checheck ng tire pressure and surprisingly mas lower palage ng 2 PSI. Ramdam ko kasi na maingay ang makina after mag shift ng 1st gear. Di ba parang ang bilis ma deflate?
on stock tires (yokohama)
all tires on 33PSI with no load. (me and my wife lang everyday)
2.5DSL AT (2012) Oct12
mga sir.. ask ko lng po ano po magandang pang alis water marks sa slamin.. ng try ako ng glass cleaner di kaya. kumintab lng pero andun pa rin water marks.
thanks
