always on ang a/c kahit na walang tao sa likod. minimum fan setting.
di ba puwede na naka off ang a/c fan sa harap ay sabay off din sa likod?
Sa mga masters na ka-innova as ko your inputs regarding aircon lalu na sa mga same unit na 2011 E A/T GAS type 3 aircon control(no A/C on button)
1. Just my observation, yung front fans lang ba ang may cooling at circulating fan lang yung sa rear cooler fan switch sa 2nd row seat? When you feel it by hand yung malamig lang sa buga is yung sa harap then yung sa likod ambient lang ang buga. Is this normal or maybe needs checking next PMS. TIA
follow up if dual cooling sya where is the rear evaporator coil located?
There are 2 evaporator coils for the innova. 1 sa harap ( underneath the dashboard ) and 1 at the back ( passenger side ). only front has the option to get air outside / recirculate. yung likod ay recirculate lang. malamig dapat parehas. rear aircon also takes a longer time to cool especially during noon because the tubes run through the roof at gets hots kapag nakabilad sa araw yung sasakyan. kung hindi lumalamig yung likod mo, have it check immediately baka sira expansion valve.
Ka Innova, I am selling my stock rims and hub caps (1 set) for a give away price. Please PM me 09175635353. You can also view the pictures at ayosdito and sulit.
sir what if kung tinangal na yung check valve? pwede bang i turn off ang a.c. sa likod?
o.t. lang sir... i have a van 3 po ang evaporator... ang napancin ko po nung minsan eh pinatay yung isang blower eh nung binuksan ko na eh medyo nahilaw na po ang lamig nung pinatay na rear a.c. hindi na po kasing lamig ng dati... wala din po check valve...
Ok I will have it checked next PMS just to be sure. Also confirm my observation, the compressor only starts when front fan is on and temp selector is on, but when front fan is OFF and with temp selector is ON and rear fan is ON notice compressor does not start, so no cooling at rear fan.
Mga sir, need help in repairing cracked tail light ng innova. Binunggo kz ako sa likod, nag crack yung tail light (white part/bottom area). Ano po ba maganda ilagay doon para di pasukin tubig or moist? Or. How much po ba yung tail light ng innova and where is the a good place to buy?
Right tail light din ang may crack sa akin. Siguro try ko muna sa banawe baka mas mura. Medyo malaki kasi yung crack. Check ko kung kaya pa din ng xpel film. Thank you mga sirs.
