Results 14,561 to 14,570 of 15485
December 19th, 2020 08:34 AM #14561
I think I found the culprit. Logic tells me it's the LED brakelights I installed before this Check Engine thing happened. Check engine is gone after replacing it with a pair of P30 standard brakelights (sana wag na magpakita ever). I don't have the technical explanation, but I could only speculate (maybe sort of imbalance in the electrical system and the dashboard display). So I suggest you guys remove all new electrical devices you installed and observe if it will go away. Good luck..
January 7th, 2021 03:16 PM #14562
- Jan 2008
- 4,726
January 7th, 2021 03:48 PM #14563
January 14th, 2021 02:47 PM #14564
What is the wattage of the LED brake lights you installed?
January 15th, 2021 06:49 AM #14565
- 54,230
January 15th, 2021 09:01 AM #14566get the bolts that you just removed, and screw them back in.
that should cover the holes, and also ensure that you do not misplace them bolts, when you decide later to re-install the seats.
it is easy to lose or misplace those bolts, if you do not re-screw them back in.
January 15th, 2021 11:48 AM #14567
Ah ok worst case scenario probably the fuse or the socket will get busted if you use higher wattage and in my opinion it will not be enough the get the CEL lit.
- 54,230
January 15th, 2021 11:58 AM #14568
January 15th, 2021 12:02 PM #14569
That's the big question that only scanner can verify. My vehicle also sometimes CEL do lit up during long idle.
- 54,230
January 15th, 2021 12:03 PM #14570
Yung support lang talaga. May vlog si Autorandz nito, nagpa repair ng hybrid battery sa kanila....
China cars
