Page 1384 of 1549 FirstFirst ... 128413341374138013811382138313841385138613871388139414341484 ... LastLast
Results 13,831 to 13,840 of 15485
    #13831
    Quote Originally Posted by attyallanlatras View Post
    Mga bossing, yung Innova ko is 2008 model. Gusto ko sanang mag install ng LED headlights. Anong recommendations nyo on the brand at kailangan po nang magpalit to projector type? H4 po ba yung bulb natin? Bawal po ba yung Led headlight?
    Up ko lang question ko......
    May 2015
    #13832
    Wala namang problem sa pag upgrade from Halogen to LED. Pero may bad experience ako noong ginawa ko yung upgrade na yun. Pili ka lang ng magandang LED at maganda reviews if you're planning to buy sa Sh***e or L****a . I bought it from shop S. 4 months lang tinagal and my experience was static when using the FM Radio while driving at night at syempre naka-on yung Led headlights ko. I switched back to halogen and bought a Pegasus bulbs. Far far better than my stock bilux osrams and slight improvement from my previous LED bulb.
    Regarding sa projector. I be bake pa ata yang headlamps mo? Para matanggal yung seal (based sa napanood ko sa youtube hehehe). Mejo matrabaho if DIY but if you have budget for a retrofit mas maganda
    Sent from my Redmi Note 5 using Tapatalk
    #13833
    1. stick to stock.
    2. remove the front windshield tint (heh heh).
    3. have the lights properly adjusted for throw. if lights are already clouded over, replace them.
    4. have eyes checked.
    5. get feet back on the ground. hey! we're not schumi speeding for his nth win...
    keep in mind, that the maximum allowed speed limit is for ideal daytime driving conditions only.
    at night, it is always prudent to drive more slowly.
    inquire with Keon Sondra on FB
    Aug 2009
    #13835
    Quote Originally Posted by sn0wbLind View Post
    Guys saan maganda magpagawa ng aircon nag pa canvass ako sa isang store sa banawe eto yun quote sakin.
    Cleaning - 3,500
    Compressor - 13,500
    Evaporator - 4,500 (pwedeng x2 kung harap likod ang may leak)
    Drier - 700
    Gasoline 150 for flushing daw
    Condenser - 5,600
    Oring
    Nitro flushing
    Total: more or less 31k
    Medjo malaki po talaga. Hehe. Parang buong aircon system na yun pinalitan. Kaya daw kelangan lahat bnew, may durog kasi yun sa loob ng compressor so pag ni re-use or repair daw mag chance na masira ulit at bumara mga metal particles dun sa compressor papunta sa lines ng mga aircon.
    Need po advice. Thanks.
    05 innova j gas
    Try having a quote kay kirsten near north cementery...
    May 2019
    #13836
    Hi Sirs,
    Ano po kaya ang cause kapag ang brake mo eh nag iba ng pakiramdam, nag palit po kc ako ng brake pads. Kc before, pag press ng brake pedals hndi sya nag ssink ng mejo malalim, may force na nalaban pag pnpress ang pedal dahil ata sa ABS system ito.
    Kaso after mag palit, feel ko may mali, although makapit nmn brakes pero prang may hinahanap pa ko like sa dati kong pag brake. Ano po ba ang solution dito? Thanks po mga sirs
    Quote Originally Posted by archcos_5 View Post
    Hi Sirs,
    how old is your innova? what are you look for exactly?
    May 2019
    #13838
    Innova 2015 po, pero ang isang iniisip ko is baka may air ang brake fluid kaya prng feel ko ang lambot ng brake pedals. Magkano po kaya pa bleed ng system ksma na change brake fluid. Im looking for same experience like mine sir, thanks.
    1000 more or less. nilagyan ng brake grease yun caliper pins?
    May 2019
    #13840
    Not sure sir, pero prang wala nmn silang nilagay. Around banawe kc ako nag papalit sir.
Toyota Innova Owners & Discussions [continued 3]
