Results 14,831 to 14,840 of 15373
November 4th, 2021 12:27 PM #14831
Magka-iba gasket diameter at placement nila. It obviously means the gasket is not sitting properly because of the incompatible mount. If so, the gasket can shift anytime due to oil pressure which can bring about a bigger oil leak. All that filtration with no oil....
Better use the correct one.Last edited by oj88; November 4th, 2021 at 12:33 PM.
- Apr 2010
- 739
November 4th, 2021 01:50 PM #14832di ko na sinubukan ulit with another B2 for the NP300, baka bad oil filter lang. the tancha-meter says it could fit nakapag 3000km din before naging visible leak.
compared the BT223 which i use for a few years already with the B2 and match naman ang gasket. hinataw ko din after the oil change lol.
just found a similar post:
November 4th, 2021 05:11 PM #14833
Was able to get a pic of my OBD. On average, I get up to the Innova's operating temp within 10 minutes if I am able to drive it normally as soon as I start it. In this trip, I got stuck on a 3-minute stop light before I got into the hiway.
However, if I just start the car without moving it. Takes at least 20mins or even more to get up to its operating temp. In my case, it's between 82 C and 92 C.
November 5th, 2021 10:30 AM #14834
I think wala namang problema kahit wala pa sa operating temp tapos aalis ka na, importante dyan wag lang siguro i rev ng mataas...
nakasanayan ko:
start
open windows (half open)
on blower/fan
idle mga 2 to 3 mins, silip silip around car lalo na tires
tapos alis nako..
onthe way bago makalabas ng gate ng subd (mga 500m) close ko na yung windows then on ng aircon ..
- Aug 2013
- 262
November 5th, 2021 10:32 AM #14835
- 52,958
November 5th, 2021 10:40 AM #14836
- Jan 2008
- 4,726
November 5th, 2021 10:45 AM #14837
- Jan 2008
- 4,726
November 5th, 2021 10:46 AM #14838
- 52,958
- Aug 2013
- 262
November 5th, 2021 11:30 AM #14840
Hybrid is the way to go. So you don't rely heavily on the batteries.
Hybrids and EV
