Results 13,811 to 13,820 of 15330
- May 2019
- 14
May 19th, 2019 12:17 PM #13811pag inaapakan naman ang brakes, umiilaw ulit sya, pero pag mnsan nka park ka lng eh prng naiistuck na syang nakailaw ulit. di ako masyado familliar sa kung anong watts un sir bsta ung brake lights na red ang naka ilaw. Ung kanan sir normal lng naka off sya pag on park pero on ang engine, pero once nag brakes eh nailaw. ung kaliwa lang amg problema sir.
thanks
May 19th, 2019 01:09 PM #13812
- 52,763
May 19th, 2019 06:45 PM #13813just for the heck of it... this is what i would do, if i were in your place, because it costs nothing to do it.
remove the housing, un-screw the bulb holder, and remove the bulb.
check if the bulb is ok, that both filaments are ok. clean the bulb's metal base and contacts. clean the bulb holder's contacts as well. then re-install. make sure you install it correctly.
before you re-install everything else, check the bulb's functions, to see if ok na. if still not ok, put everything back anyway. then "call the experts or go to their shop".
if the bulb on the other side was moved as well, do the same.
yes, those double filaments do wondrous things, when a filament/contact doesn't work fine.
while the owner's manual does give instructions on how to remove the light assembly, in truth it is difficult the first time. the DIY-er may get the feeling that something is going to brake. but it won't. and it gets easier, with practice.
...i would also check the fuses, justin. and the brake light actuator switch.
good luck, DIY-er.Last edited by dr. d; May 19th, 2019 at 07:05 PM.
- May 2019
- 14
May 21st, 2019 12:17 AM #13814Thank you sir for all your replies.
May 21st, 2019 04:38 PM #13815
Can anyone help me identify the part no. and/or description of the following retainer/clip pictured below?
The passenger side retainer broke after I've had a techie work on the audio system a couple of years ago. But quite recently, I noticed that it was gone. I think it probably got sucked off when I had the car vacuumed.
It's slightly smaller than a toothpaste cap.
Driver side footwell trim, with the retainer still attached
Passenger side footwell trim, with the missing retainer
I've been searching the web for it but I just can't find it. Last resort is to call Toyota.
- Feb 2008
- 898
May 25th, 2019 12:26 PM #13816Mga bossing, yung Innova ko is 2008 model. Gusto ko sanang mag install ng LED headlights. Anong recommendations nyo on the brand at kailangan po nang magpalit to projector type? H4 po ba yung bulb natin? Bawal po ba yung Led headlight?
- 52,763
May 25th, 2019 12:30 PM #13817
May 25th, 2019 03:51 PM #13818
May 25th, 2019 06:48 PM #13819
Guys saan maganda magpagawa ng aircon nag pa canvass ako sa isang store sa banawe eto yun quote sakin.
Cleaning - 3,500
Compressor - 13,500
Evaporator - 4,500 (pwedeng x2 kung harap likod ang may leak)
Drier - 700
Gasoline 150 for flushing daw
Condenser - 5,600
Oring
Nitro flushing
Total: more or less 31k
Medjo malaki po talaga. Hehe. Parang buong aircon system na yun pinalitan. Kaya daw kelangan lahat bnew, may durog kasi yun sa loob ng compressor so pag ni re-use or repair daw mag chance na masira ulit at bumara mga metal particles dun sa compressor papunta sa lines ng mga aircon.
Need po advice. Thanks.
05 innova j gas
