Page 137 of 662 FirstFirst ... 3787127133134135136137138139140141147187237 ... LastLast
Results 2,721 to 2,740 of 13229
    May 2005
    #2721
    Our innova D4d matic has no problems. 6,000 kms na natatakbo. gamit din namin shell diesel. baka sa D4d na M/T may problema, sa matic na D4d wala.
    Aug 2003
    #2722
    sa mga naka experience ng choking issues:
    larshell- no bd - findings: faulty fuel pump (not clear if priming pump of the fuel filter or the pump itself)
    altec- with bd - correction done: tighten fuel filter.
    Lord - with bd - correction done: reset ecu.
    Especially with Larshell who didn't use BD, similar problem but different ang mga solutions, although I have doubts with the faulty fuel pump findings, because if it is faulty, no remedial measures will make the choking problem go away. I doubt if it is BD as of now, especially if someone else here experienced it without using BD.
    May 2005
    #2723
    Quote Originally Posted by altec
    manual ba innova niyo or matic?
    Aug 2003
    #2724
    yung sa akin, manual. But the choking problem is regardless of its tyranny. Both larshell and lord had their ecu resetted, and the problem went away. I didn't have mine resetted. Imperial mentioned a friend of his experiencing the same choking issues, but didn't mention if his friend used BD or not. Lord, tanong ko sa iyo, when you used estrol, did you check the BD if it was contaminated? I mentioned the possibility of clogging due to contaminated BD, which was discussed at the biodiesel thread both here in tsikot and over at kotse.com. Naka estrol pa rin ako, at 1% blend, but I now have the estrol checked prior to pouring, and by next month, mag bioactive na ako, after maubos yung estrol stocks ko.
    Feb 2005
    #2725
    Quote Originally Posted by Innova G
    Tanong ko lng po kung mayron na po ba dito sa inyo naka try nung Khaos(yun pong kinakabit sa makina to decrease fuel consumption while increasing engine performance)?? Kung meron po share nyo naman experience nyo with the product. Does it really works?? may diesel version na daw ata nun, d ko lng alam kung release na b.
    I have mine installed but not khaos brand, but of similar technology, you can check the pics at my yahoogroups...
    WBR,
    Apr 2005
    #2726
    My Diesel MT model up to now wala naman problems approaching 10K check-up na. Ang tipid nga sa diesel around 9.5 km/liter sa city driving. I just use either Shell diesel or Petron. Very rare ko nga buksan yung hood the car, tingin lang ako kung may coolant pa.
    #2727
    Khaos? Hehehe...
    Read this: http://www.fuelsaving.info/khaos.htm
    Or join the discussion: http://tsikot.yehey.com/forums/showthread.php?t=15780
    Khaos or any similar air-bleed device doesn't work. Period.
    May 2005
    #2728
    Quote Originally Posted by bourbonic
    Hi Guys,
    Im planning to change the stock rims of my tires. Oks ba yung 17" na mag wheels? Rota yata ang magandang brand eh. Have to change the tires also. Ano ba ang recommended na laki na mag wheels na hindi ma co compromise yung performance ng innova natin?
    Mine is 17" tires 225/55/r17 my experience nag improve yong ride ng innova ko ok ang 17" rims ng rota, i also got rota chrome. Dami pogi points nyan. But i suggest wag nalang kasi baka mag loko din supply pump mo sayang lang.
    It's up to you parin
    May 2005
    #2729
    Quote Originally Posted by Takumi
    Lately I've been experiencing the same thing na namamatay agad ang engine pag cold start so kailangan sundan agad ng accelerator para hindi mamatay. Hmmmn... I think my biodiesel is really the culprit. Before naman hindi ko nararanasan ito. Siguro talagang hindi naka design ang biodiesel sa CRDi engines.
    So pang 4th kana dito palang sa mga Innova Thread pano pa kaya yong walang access sa internet and yong mga di alam yong forum nato.This is really bad.
    I remember i did ask yong nag trouble na wont start at all yon Innova nya, baka sirain din ang CRDi ng Innova well sabi ni kuyapete 1 in 5k unit is not bad kaya bumili nako but i dont blame anybody its my own decision. But indi 1 in 5k unit to, So meaning my Bug sa ECU ang Innova diesel or CRDi talaga sana Bug lang sa ECU kasi kung Bug lang mas madaling ayusin.
    Oct 2005
    #2730
    Quote Originally Posted by larshell
    Thanks! So there is a problem pala if you change the rims to 17". How about 16" (meron ba non)? Or are we stuck forever to our 15" rims?
    Oct 2005
    #2731
    Quote Originally Posted by agreyes7110
    i agree with you sir, around 9.5 km/ltr din ang fuel consumption ng diesel m/t ko kasama na ang occasional na hataw, binubuksan ko lang din ang hood ko para hanginan ang makina( so dust and dirt wont accumulate) hindi kasi ako nagpapa engine wash( it might affect the electronics especially the sensors)
    Oct 2003
    #2732
    innova_G, also if you are not concerned about voiding your innova's warranty (given that its not been 3 yrs yet), then you could try putting the fuel saving device in your innova if it helps improve fuel efficiency.
    Aug 2005
    #2733
    MGA BOSSING,
    HELP!! NAMAN.. nagbigay kami ng DP sa toyota pasong tamo kanina lang pero ung unit e ilalabas ng by last week ng november or 1st week ng december. KC uuwi ako by 2nd week ng december, ang first choice ko is G M/T D4D Night mist, tapos pinaplitan ko ng beige mica, then ngaun, nung nagbayad ang mom ko sabi nya ang pangit daw ng beige plus ang dami n daw meron nun, kc ako d nagandahan sa night mist sa picture, kaya sabi ko beige..ngaun pinupush ko ung agent ko na palitan ng night mist..pero ang dinadahilan nya is mahirap daw kumuha ng kulay na iyon pero noong una d nmn nya cnsabi un..tapos daw naipakabit na nya ung spoiler at ung roof rail..e sabi ko bakit mo agad pinakabitan e d pa kami nagbabayad....
    Ganun ba talaga un o pwede ko pa papalitan e kc d p nmn nya nadedeliver...
    Ano ba mas maganda NIGHT MIST or BEIGE MICA!!
    PLease need ur input!
    Salamat mga boss!
    Oct 2003
    #2734
    pag hindi mo tinanggap yung unit na may spoiler and roof rail na, malamang matatagalan ka ulit sa pagkuha mo ng unit. i believe it all boils down kung what you really wanted in the first place. both are nice colors naman IMO.
    Jul 2005
    #2735
    Quote Originally Posted by pugee
    MGA BOSSING,
    Salamat mga boss!
    NIGHT MIST kana, kasi sa G variant lang available yan, di tulad ng Beige mayron kulay yan sa E variant, at least special edition color(Night Mist) ito sa INNOVA.
    Jul 2005
    #2736
    bossing,
    wala naman problema sa pagpalit ni sir larshell sa rims niya, sa engine nagkaproblema ang ride niya, the way i look at it , ang sinabi lang niya ay baka magkaroon ka rin ng problema sa engine kung papalitan mo ang rims mo, he mean't it as a joke lang siguro.
    Aug 2005
    #2737
    Quote Originally Posted by rcl_inno
    Tanong lang, mas ok ba tumakbo ang night mist comparing sa beige since pareho lang itong Toyota Innova?
    Jun 2005
    #2738
    Quote Originally Posted by leinahtan
    Mas OK tumakbo ang Night Mist kaysa sa Beige, lalo na pag GABI na. He he he . . .
    Dec 2003
    #2739
    sarap ng beige coz halos 0 maintenance, pag black yari ka sa dumi at alikabok.
    May 2005
    #2740
    MGA BOSSING,
    Salamat mga boss!
    Biege Mica ka nalang kasi ako Nigth Mist or Gary Mica Metallic yon Unit ko sira agad ang engine.
Toyota Innova Owners & Discussions [ARCHIVED]
