Page 112 of 662 FirstFirst ... 1262102108109110111112113114115116122162212 ... LastLast
Results 2,221 to 2,240 of 13229
    Aug 2005
    #2221
    Seems G owners are not getting the price for their money. Never heard J-variant owners having the same problems like G's. No offense here guys, just an observation.
    Aug 2005
    #2222
    Quote Originally Posted by themann
    pre please pm me if you know someone selling their innova. plan to get second hand lang. thanks,
    Try this link: http://www.buyandsellph.com/.
    You might find it helpful for your query.
    Jun 2005
    #2223
    Quote Originally Posted by czar_ethan
    For those of you who bought the G model, we all know that there are some issues with the sensitivity sensor. So far what have you done about it? May mga modifications na ba kayo? Please share..
    I have this master key/remote control of keyless entry to be malfunctioning. Nung una akala ko mahina lng battery so I bought a new one (CR 2016), kaso d ko ma-lock or unlock ung unit ko. So minsan minamano mano ko na lng.
    Papalitan ba to ng casa incase found be be defective?
    Mga Innova G owners, i just accidentally discovered that G models indeed have sensitivity sensors. Naka-arm kasi ride ko while i was cleaning the car. Nung nililinis ko na mga wiper blade sa harap eh bigla kong nabitawan ang isang wiper blade at sumalpok sa windshield...result, nag-alarm po sya. So meron nga siyang impact sensors pero naka set na hindi masyado sensitive para hindi mag false alarm.
    Aug 2005
    #2224
    Regarding shock sensors, its sensitivity can be adjusted by plain screw driver only. Shock sensors are connected from the main unit which is inconspicuously located most likely near the doors or beside the panel. Wait up, will post later the wire connection diagram.
    Aug 2005
    #2225
    Quote Originally Posted by leinahtan
    Here it is parekoys, the wiring diagram of a typical car security system.
    Jun 2005
    #2226
    Now the only problem is...saan kaya nakalagay yung impact sensor ng innova at pati na rin yung head unit. Sumilip ako sa ilalim ng driver side at wala akong makita.
    Jun 2005
    #2227
    Try opening the driver's side kick panel. This is the usual place the car manufacturers put it. The impact sensor is like a small brick 2x2x1 that's attached to bottom of the A-pillar. They put it here since very often, the point of entry of the theives is the driver's door. Itong area ang unang na-aalog ng magnanakaw.
    The headunit of the alarm should be around that area too, maybe under dash left of steering wheel (just a hunch).
    Feb 2005
    #2228
    TRIED to move or lift my ride thru the front fender and no alarm whatsoever was triggered..
    I checked the driver side steering colun and saw a gadget thing colored blue on the left side of steering wheel but DIDN'T see any thing on it that you can adjust with a screwdriver...
    WBR,
    #2229
    Quote Originally Posted by jaeger
    i don't know if toyota changed the alarm module (TVSS) for the IMV models, i can only speak for toyota models (altis,vios,hilux before 2005, etc) with an alarm remote similar to the attached file (keyless.jpg)
    the original TVSS for the 2003 Revo and up is made by fujitsu (sabi lang po), the shock sensor is BUILT-IN on the main alarm module itself and you can adjust it using a small screw driver, I know it's location on the Revo and it is very far from the driver's door hehe, nasa passenger area sya..
    sa 2003 revo and up, it's very easy to adjust the shock sensor sensivity, and it will be also very easy for the thief to remove the alarm module.. lintek na toyota yan hehe..
    #2230
    Quote Originally Posted by Innova_Boy
    WBR,
    the TVSS alarm will not go off by lifting or moving the ride, you really have to knock on some body panels, try it first on the dashboard, then on the driver door or front pasenger door.. baka lang maka-tsamba hehe
    i'm not sure if this is applicable sa Innova, here's some tip to locate your Innova alarm module, arm or dis-arm your innova while you are inside the vehicle, you will hear a clicking sound (relay to light up the left and right signal lights)..
    Dec 2003
    #2231
    pasingit, we just got a 2005 Innova G D4D A/T, beige mica metallic. just in time before the free comprehensive insurance promo expired yesterday aug 31. For our people hauling vehicle, i like it but hate the overly plasticky interior.
    Feb 2005
    #2232
    Quote Originally Posted by revoGSX
    TESTED.... i did what somebody posted here, lift the driver side wiper and blast it on the windshield and the ALARM WAS TRIGGERED...
    so our motion sensor is useless cause only the wiper can trigger the sensor...
    will find out other areas that will trigger the alarm again....
    WBR,
    Feb 2005
    #2233
    Also does soemone here familiar with our tire?? Does the Yokohama Aspec OEM tires for innova has 4 ply only?? Anybody can confirm this??
    WBR,
    Feb 2005
    #2234
    Quote Originally Posted by BlueBimmer
    Welcome to the club BB... dont worry bout the plastic thingy...
    Once you feel the smooth ride, sure you will forget that plastic thingy...
    WBR,
    Aug 2005
    #2235
    Hey guys, arent we too showy here. Someone might be fiddling his computer and having a heyday getting ideas and information as to where and how our car security works. I was thinking how we can make this confidential.
    Jun 2005
    #2236
    WBR,
    Our motion sensors are not totally useless. I am thinking of buying a lot of wiper blades nga to install all over the car para kahit saan hipuin ang car eh magtritrigger ang sensor.
    Jun 2005
    #2237
    Quote Originally Posted by jimaroquai
    twak2
    Feb 2005
    #2238
    *all
    let's just discuss the nooks and crannies of our ride TVSS in some other medium as some bad elements might be lurking in here....
    WBR,
    #2239
    don't worry leinahtan, the oem stock alarm w/o immobiliser will be very easy for the theif to disarm than some of the aftermarket alarm dahil alam na nila kung saan ito nakalagay and alam na nila kung anong wire ang dapat puputulin, kung minsan nga eh isang hugot lang sa fuse eh disarm na hehe..
    hehe
    madami magrereklamo sa toyota (TMP) if they set the shock sensor to high-sensitivity dahil prone sa false alarm..
    kaibiganin natin ang mga toyota service advisor para malaman natin kung nasaan ang alarm module ng innova, malay ninyo nasa engine bay hehe..
    pero syempre pag nalaman na eh wag na i-post dito.. for security concerns
    May 2005
    #2240
    For me car alarm is just a keyless entry, pag hinarang ka sa daan at may nakatutuk na syo wala ka nang magagawa. IMHO
    Ganda lang ng alarm na kasama ng Innova G, arm n disarm boton attached wd the ignition key.
Toyota Innova Owners & Discussions [ARCHIVED]
